Old 09-05-2025, 01:10 PM   #1
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Default Territory AWD systems
Know of someone looking to buy a Territory AWD and was wondering if theres any point of difference from SX to SZ2 in terms of how they deliver power to each wheel, reliability, things to look out for.
They want to be able to launch/retrieve their boat on slippery/sandy ramps and have had trouble with single spinner RWD's.
I said diesel is cheaper to run but more expensive to maintain but they're not too worried either way.
I was thinking SY2 AWD 4.0L 6A?
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 01:37 PM   #2
Travesty
Default Re: Territory AWD systems
Too old and tired, best bet would be a petrol RWD SZII.
Travesty is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 02:40 PM   #3
kypez
kypez's Avatar
There was a change towards the end that made the AWD an on-demand type system from the previous continuous system. Think it was in the final SZ series that the change came in. For the boat ramp, they might feel a bit of slip before the centre diff engages and the front wheels provide propulsion. I believe the change was made to reduce fuel burn (increase fuel efficiency).
Happy to be corrected here.
My Ford Family...
2014 GT-F, Manual, Kinetic with Black Stripes
2021 Mustang Mach 1, Manual, Velocity Blue
kypez is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 07:31 PM   #4
Toiler
The SZII AWD is almost always running the front wheels - about 15% traction. If you have the TOD bypass switch you will feel the difference if the front axle is disengaged - the steering becomes lighter.
But "almost" means a sharp hard turn will turn front wheels off temporarily and I seem to remember at low speeds and low throttle it may also be disengaged - engaged at low speeds and light throttle applied - I remember this from when I was looking at mods for snow driving - the mod to lock the transaxle to engage the front wheels at all times ie in the snow need low power low speed traction.
But in any case I never had an issue on boat ramps with my AWD Terry. ie no spinning of rear wheels.
The SZII AWD system is a hack however by the Ford accountants - it could have been much better by including the input shaft output shaft speed sensors but that is history.
Ford Territory 2016 SZII TX diesel 17" rims
Escape 2022 ST-Line AWD (wife's car)
Mercedes SLK280 (toy car)
Toiler is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 08:26 PM   #5
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Thanks Kypez,
So can I assume up to and including SZ1, drive is directed to all 4 wheels 100% of the time and if so do you know if its an equal balance of power or more rear?
Cheers.
Old 09-05-2025, 08:30 PM   #6
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I had a SZ1 RWD petrol and it'd spin the right rear pulling my jet ski out on the same sandy ramp with anything more than slight throttle on new tyres, which was why I suggested he look at AWD as he wants a Territory.
Old 09-05-2025, 08:48 PM   #7
kypez
kypez's Avatar
Originally Posted by BENT_8 View Post
Thanks Kypez,
Cheers.
Think it was 38/62 split. It was never symmetrical like the Subaru
My Ford Family...
Old 09-05-2025, 08:51 PM   #8
mad2
Regular...with metamusal
Thanks Kypez,
Cheers.
Hi. my SX is AWD with approx 35% drive to the front wheels. the front diff is not a LSD and all wheels driven full time.
just checked an owners manual [SY?] .... the torque split [going by the book] is 38% front and 62% rear.
with 6sp and the revised front suspension.
Old 09-05-2025, 11:10 PM   #9
fordomatic
fordomatic's Avatar
Here is a list of what I’ve replaced in my SYII Barra in the last 3 years (now at 180km). Another forum member who is my mate also had an SYII and replaced similar things. If you can’t work on these cars yourself, stay away.
Useless offroad but I’ve found mine good in the sand and stable on dirt roads.
Rebuilt rear diff
New fuel pump
New power steering pump
New steering rack
New fuel pump
Front diff pinion seal
New tailshaft
New starter motor
New gear selector cable
New oil pressure switch
Rebuilt front brake calipers
New headlining
Deleted heat exchanger
New Bendix rotors and pads at 100km
3 new door actuators
New drivers window switch
New tailgate hinges
New drivers abs sensor
New rear lower control arm bushes
New rear upper control arm bushes
New front sway bar links
New rear diff bushes and rebush whole rear cradle
New front diff bushes
New upper ball joints
New lower ball joints
New suspension and springs at 100km
Proud owner of the ugliest Ford ever made
fordomatic is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 11:16 PM   #10
kypez
kypez's Avatar
Rebuilt rear diff
New fuel pump
New steering rack
New fuel pump
New tailshaft
New starter motor
New headlining
New tailgate hinges
Yikes!!
My Ford Family...
Old 09-05-2025, 11:23 PM   #11
Sprintey
Sprintey's Avatar
SX AWD petrol full time 38/62
SY AWD petrol full time 38/62
SYII AWD petrol full time 38/62
SZ AWD diesel Haldex, will declutch when stopped to improve fuel economy.
SZII AWD diesel Haldex, will declutch when stopped to improve fuel economy.
No petrol SZ or SZII AWD. More's the pity.
SYII is king of the Territories as it gets proper AWD and had the good ball joints at the front.
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2025, 11:34 PM   #12
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
This was my thoughts too,.
SY2, TS, AWD, BARRA, 6HP26.
Old 10-05-2025, 08:39 AM   #13
Toiler
. . It was never symmetrical like the Subaru
Not really relevant here I know but I get annoyed by the Subaru marketing . .
Pretty sure that the manual gearbox only was/is 50/50
The slush boxes were (at least in the 2000 model I had) 30 front and 70 rear
. . . marketing = never let the truth get in the way of a good story
Old 10-05-2025, 08:51 AM   #14
kypez
kypez's Avatar
Thank you! Learnt something new.
My comment was more that it was at least offered on Subaru models vs it never being an option in the Territory.
My Ford Family...
Old 10-05-2025, 09:28 AM   #15
Dr Smith
I've had 4 and while I read fordomatics pain, never had one issue as listed apart from rear diff replaced under warranty.
Our current one is a 2016 built AWD Titanium diesel with 75K km...we've never gone off-road and the most I've towed with it is right on max tow rating 1600kg (tongue not h/duty hitch) and does it with ease.
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2025, 10:12 AM   #16
Toiler
Attached from my Forscan records. The bottom trace is the TOD clutch operation on my SZII AWD. You can see the engagement of the front wheels when taking off in first gear. Exactly what is required on a slippery boat ramp.
File Type: png Screenshot 2025-05-10 at 9.09.36 AM.png (69.2 KB, 13 views)
Old 10-05-2025, 02:36 PM   #17
mad2
the 'only' thing differant with my SX .. it has the 4.10:1 diff ratios . . for a standard motor it helps it get up to speed
Old 10-05-2025, 07:45 PM   #18
Came here to say the same thing.
SX through SY II had a permanent AWD system.
That changed for SZ with the introduction of the diesel engine and Ford-build 6R80 6-speed auto. As mentioned, it was a part-time AWD system that disconnected at rest, Ford saying it was for refinement and fuel economy. There was no AWD petrol SZ, from what I gather, they rationalized AWD to the diesel to save developing a specific version for the Barra + ZF 6-speed combo, and/or not wanting to put the 6R80 behind the 4.0 engine.
Old 10-05-2025, 08:53 PM   #19
From memory the SZ-on diesel AWD had greatest towing capacity at 2700kg vs 2300 for petrol and diesel RWD models.
Old 10-05-2025, 09:14 PM   #20
Toiler
Correct. With proviso. WDH mandatory over 1600kg (weak rear axle).
The increase from 2300 to 2700 presumably is due to the assist from the front axle during takeoff - reducing load on the diff?
Old 11-05-2025, 05:46 PM   #21
ben5
Not really relevant here I know but I get annoyed by the Subaru marketing . . Pretty sure that the manual gearbox only was/is 50/50The slush boxes were (at least in the 2000 model I had) 30 front and 70 rear . . . marketing = never let the truth get in the way of a good story
"Symmetrical AWD" was never about even front/rear torque bias...https://www.sportsubaru.com/why-all-wheel-drive-.htm
ben5 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2025, 06:30 PM   #22
Correct, it was about how the whole layout of the powertrain. In that I mean if you drew a line down the middle of the car front to rear, from centre of the crankshaft to the centre of the rear diff.
The unique NS layout of the boxer engine that is slung so far forward with the gearbox being a transaxle is where the symmetrical part comes in. A transverse engine/driveline can't do that.
Thread Tools
Display Modes
