11-05-2020, 09:17 AM | #1 | ||
Been batting this back and forth with my mate in the workshop.
Does (say) an 11A0700 belt have the same ratio of taper as a 10A0700? So the tip of the 10A will be 10/11ths of the 11A’s tip width? Or is it different? It came about from his insistence on using an 11A where the original was a 9 or 10A but the sheaves worn. “Same taper” he says, “It will just sit higher in the pulley”. No beer or pride is at stake, just a quest for the actual truth. |
11-05-2020, 09:31 AM | #2 | ||
Bolt Nerd
He’s mixing up DIN and ISO standards.
I’m used to ISO (Z, A, B sections) DIN is numbers... Hope this table helps.. Sent from my iPhone using Tapatalk
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
11-05-2020, 09:32 AM | #3 | ||
No no no no. Make it interesting. Put some beer and pride on the line!
11-05-2020, 10:11 AM | #4 | ||
Next you’ll want girls dancing on the bar!
Here’s the belt (OK, the packet) which kicked off the discussion. My mate contended this was the same cross-sectional ratio as 10A0545 (the spec’d belt for an application). So in fact, this would be just riding on the “root” of the belt, compared to the correct item? |
11-05-2020, 10:25 AM | #5 | ||
Bolt Nerd
Ahh ok... 10a 11a etc...
11-05-2020, 10:30 AM | #6 | ||
Gracias. So the taper is not constant, assuming the sectional drawings to scale?
11-05-2020, 10:40 AM | #7 | ||
Bolt Nerd
Appears that way!
In my day, an A section belt was simply an A... It was 1/2” or around 13mm across the top. A “Z” was next smaller section being 3/8” (10mm) across the top. I’m talking industrial though. I’d suggest Jap auto makers were behind the A section increments?
11-05-2020, 11:54 AM | #8 | ||
Modern narrow-profile automotive belts (10A, 11A, 13A etc.) all have the same wedge angle of 34 degrees. 10A & 11A are interchangeable in most cases.
The old style industrial belts V-belts (A-size B-size etc.) are 40 degrees. An A-size is often interchanged for a 13A automotive & works fine. The 6 degrees difference between the two types equates to only 3 degrees per side, hardly noticeable with rubber to metal contact. Dr Terry |
3 users like this post: |
11-05-2020, 12:12 PM | #9 | ||
Thanks. That figure of 34° is what I was unable to find.
