Old 29-11-2014, 07:15 PM   #1
Cable
Cable's Avatar
Default Noisy disc rotors
Hi,
Hopefully you can answer this...
I have recently had a set of Brembo 6 pots installed on the front of my 2011 FG XR6T, they look awesome, work as expected but I have a constant noise which best I can describe sounds like a child's bike which has a playing card rapping through the spokes which gets louder when I brake.
The mechanic that did the install said its due to the slots and dimples on the rotors!
Does this sound right? Will a disc change get rid of the noise or am I stuck with it?
Any advice would be appreciated
Thanks
Cable is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2014, 12:08 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Noisy disc rotors
Originally Posted by cableboy View Post
Hi,
Thanks
Some noises like the one you described do happen when fitting certain style slotted or dimpled rotors and in most cases once the pads wear in and the slots deburr it can go away or reduce the noise. I suggest you wait a bit first as it isn't going to effect the brake performance but it can be annoying.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 01-12-2014, 02:51 PM   #3
Cable
Cable's Avatar
Thanks for the info, will wait a while and see what happens.
Thanks again
