28-05-2006, 11:05 AM | #1 | ||
G'day all
Tried search but no answer. My father has an 85 ghia. Has no spark at the spark plug. Does this model have electronic ignition or points? What are the usual culprits for 'no spark'? Any advice is appreciated. regards mark |
28-05-2006, 07:02 PM | #2 | ||
Over Thinker
electronic module in the dissy of your car as far as my information goes
so do the basic check coil leads and plugs and cap for cracks etc then you need a muti meter to test the module itself and current from the ignition any fuses have a look there as well ? that might be a ford genuine part as well but no to sure other stuff is in my post about the telstar below
My car goes Brumm Brumm |
28-05-2006, 09:14 PM | #3 | ||
My 85 TX5 Ghia refused to start a few months after I got it. I had both the Distributor Moduel and the Ignition Coil replaced, and no problem at all since then (they were both Bosch parts).
29-05-2006, 07:51 AM | #4 | ||
Thanks all,
Anywhere in Bris for cheap wrecker parts? |
29-05-2006, 10:56 AM | #5 | ||
Over Thinker
luckily mazda 626 and the telstar were the same car with different badges
for this model sometimes parts from a ford are cheaper dont ask me why ? so parts are not so hard to find north or southside
02-06-2006, 07:48 AM | #6 | ||
Twas both the coil AND the distributor...
thanks for the advice everyone :Reverend: |
02-06-2006, 12:36 PM | #7 | ||
Over Thinker
well thats good you got it fixed well done
