Old 05-01-2022, 02:43 PM   #1
neil3087
Default LZ Hatch Door Switch Removal
The hatch door switch has failed and feels like the button is stuck. The remote will still unlock the hatch and the reversing camera is still working.
After removing the hatch door interior trim there appears to be no access to this switch. It appears that this switch / camera assembly just clips into place without screws.
Is someone able to advise the method of removing this item?
neil3087 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 10:42 AM   #2
russellw
russellw's Avatar
Default Re: LZ Hatch Door Switch Removal
It's probably not a lot of help but the only instructions in the WSM is the diagram below:
Old 06-01-2022, 05:58 PM   #3
nobbystang
nobbystang's Avatar
I've found searching for Mk2, 2.5, 3 etc has been helpful for troubleshooting my LV.
Hopefully this link has the info you're after. CLICK HERE
Current:
2016 Camry
1966 Mustang Coupe
Previous:
2011 SZ Territory Titanium
2008 Ford Edge AWD Limited
Silhouette BF XR6, ZF Auto
White EF GLi, XR look alike
VH Commodore
nobbystang is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 09:29 PM   #4
neil3087
Thanks. I'll take the interior trim off again and have another look at this.
Old 10-01-2022, 02:20 PM   #5
neil3087
To close off this thread.
I was able to see the right end retaining clip with the interior panel removed. Once pressure was applied the switch assembly was released and then all was required was the disconnection of the 2 wiring plugs.
Thanks.
