13-09-2016, 08:25 PM | #121 | ||
Next upgraded Mk1 Leopard
Sorry Standard AU
UK
15-09-2016, 08:18 PM | #122 | ||
Ok thank you. I can get a set custom made. Would you suggest the standard AU ones lengthened slightly? If so by how much? Are we talking IRS or beam here too?
21-10-2016, 11:48 PM | #123 | ||
Ok guys. I have started the conversion and started to tackle the rears tonight.
The catch is, that I got these calipers in a box so ibdont know which is left and which is right. Can someone please confirm if, when the BF rear caliper installed in the car, brake line should be above or below the bleed nipple? This will confirm orienation for me. Any tricks to getting the front left and right confirmed? Thanks? |
21-10-2016, 11:56 PM | #124 | ||
Common sense would suggest the nipple should be at the top but they do weird **** on Falcons that makes no sense at all.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
22-10-2016, 12:05 AM | #125 | ||
This is also a live rear axle if that's worth anything. Can anyone who has done the conversion confirm which brake lines they used on the rear (live axle)
22-10-2016, 01:18 AM | #126 | ||
Just checked a picture of mine and the bleeding nipple is above the brake hose. I also used the standard AU brake lines front and rear.
22-10-2016, 08:53 AM | #127 | ||
Thank you! Is yours a live rear end or IRS?
22-10-2016, 11:06 AM | #128 | ||
Mine's a live rear end
23-10-2016, 12:12 AM | #129 | ||
That's great, thank you for that. I thought I might have yobuse BA lines because the AU ones looked short but obviously not. How did you find the upgrade? Thanks!
23-10-2016, 01:07 PM | #130 | ||
I just bought some Braided Lines of eBay recently and they were to suit the standard AU calipers. The conversion is well worth it. I punish my brakes through the hills and I haven't suffered any brake fade yet.
4 users like this post: |
24-10-2016, 07:36 PM | #131 | ||
Anyone looking for a massive upgrade on the AU Brake Setup should check out the for sale thread now - have a sweet BF Turbo Premium Brake upgrade for sale on the bay.
26-10-2016, 01:17 AM | #132 | ||
Thanks guys!
One last thing. do the BF turbo Rear brakes have the Philips head securing screw in them? The rear rotors that I have don't have any provision for them? The AU ones that I just removed did. |
26-10-2016, 01:46 AM | #133 | ||
No the larger rotors don't have them. Mine, I just drilled them out using old AU ones as the template. Remember you will need to countersunk them to accept the grub screw.
26-10-2016, 09:52 AM | #134 | ||
Ah that makes sense then. I was starting to think that I had been given the wrong rotors.
I guess it's worth doing? Do the BF+ have a different retaining system or just taken care of by wheel nuts? |
26-10-2016, 10:49 AM | #135 | ||
RIP...
The screw isn't needed.
. Oval Everywhere... |
26-10-2016, 11:37 AM | #136 | ||
not really needed, but I use it as it keeps the rotor in place when changing pads and adjusting handbrake. Up to you I guess.
21-06-2017, 12:54 AM | #137 | ||
New Guy
Hey guys,
Just in the planning stages to do this upgrade to my EF sedan as the front brakes are average and are constantly warping. Just wondering if this upgrade changes the front wheel offset to the post AUII offset. If so, will fitting BA brake on the rear change the offset to post AU2 offset for the rear. Thanks in advance |
13-09-2017, 09:30 PM | #138 | ||
Hi guys. Can some one please send me a link to the definitive au 1 brake upgrade thread. I just can't seem to actually find it. Thanks
13-09-2017, 11:32 PM | #139 | ||
Is this it?
https://fordforums.com.au/showthread.php?t=11263967 Yes that's it, view in Chrome to see picks. UK Last edited by Uncle_Ken; 14-09-2017 at 03:51 PM. |
20-09-2017, 02:40 PM | #140 | ||
Thanks mate, cant get the pictures to work but the write up is excellent anyway. Just to make sure i got everything i need was it.....
au3 uprights au3 lower control arms with spindles and hubs au3 front brake lines au3 front sway bar, mounts and clips 4x8mm-100mm bolts with washers and nylon nuts au3 braker booster au3 brake master cylinder bf front brake callipers $275 from the wreckers bf 322mm brake upgrade caliper supports from ebay bf 322mm discs pads $250 from ebay dot 4 brake fluid Thats everything for the front i need? Also, what options are out there for upgrading the rear brakes on an au1 5.0 v8 fairmont ghia with irs? Thanks guys for ur help and info Last edited by auxlr8; 20-09-2017 at 02:48 PM. |
07-10-2017, 03:37 PM | #141 | |||
Miami Pilot
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, ShockWorks and GT335 replicas in 19 x 8.5 & 9.5 35p offset with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, FG 19” Lux packs with 245/35/19 Toyo and Pirelli tyres, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT |
23-10-2017, 12:14 PM | #142 | ||
So I've got everything i need together for the upgrade. Decided to go braided lines front and rear instead of changing the booster and master cylinder. My questions is; If I'm putting an au3 front end on my au1 with bf calipers the correct brake lines are au3? Also if I'm putting rear ba brake calipers with spacers do i need ba rear lines or standard au 1 lines and do i use my existing au1 bolts for the calipers or do I need the ba bolts? Just want to make sure i order the correct braided lines.
Thankyou Last edited by auxlr8; 23-10-2017 at 12:25 PM. |
23-10-2017, 12:17 PM | #143 | ||
I got custom braided for the rears. AU2/3 fronts you'll be fine.
23-10-2017, 12:39 PM | #144 | ||
Unfortunately there's no one where I live who can custom make the lines so i have to order from safe brake online, that's why i was hoping for a definite answer on if I need standard au1 irs rear lines or if i need ba rear lines to match the ba calipers?
Thanks again |
23-10-2017, 12:43 PM | #145 | ||
Give them a call. SafeBrake are pretty good with replies, in fact I think they may have lines for this conversion. Its not so much the lengths, its the connections that are different A series to B series, if I can remember.
23-10-2017, 12:45 PM | #146 | ||
Ahh, ok, make sense. Thanks for the advice
23-10-2017, 03:02 PM | #147 | ||
I got a reply from safe brake stating they dont do a line from au irs to a ba caliper so can anyone please confirm that au irs rear braided or standard brake lines for that matter will bold to the ba caliper?
Cheers |
23-10-2017, 03:25 PM | #148 | |||
#neuteredlyfe
When I changed my rear brakes to 303mm I didn't even disconnect the rear calipers. |
23-10-2017, 03:44 PM | #149 | ||
Thanks for your reply. When you say u didn't even disconnect the rear caliper, how did that work? Standard ford au irs is a solid 287 mm disc and single piston caliper. The ba rotor is 302 mm ventilated and the ba rear caliper is twin piston from what i understand. Either way thanks for clarifying that the standard/braided au irs rear lines will attach to the ba caliper. My apologies for the extensive questions, just getting my head 100% before the job is tackled.
Cheers |
23-10-2017, 03:49 PM | #150 | ||
The BA is still only a single aswell, but larger piston and pad area, plus of course larger rotor to suit.
Don't know what PG2 means either ? But aren't you changing to the 328mm rear rotor (territory/BFGT) |
