01-06-2018, 12:40 AM | #1 | ||
Yeah tis a camry(2002/3) - but presume the problem is the same. Will not open even with the key. can access boot -but the seats release is on the inside.
No doors open -can't climb through the boot, doubt I can access bonnet release open to all suggestions. -preferably without smashing glass. |
01-06-2018, 12:50 AM | #2 | ||
If you get under the car, can you access the power cable bolted to the starter?
If so attach a charger to it and then attach earth to anyplace on the chassis. Let it sit for a while before attempting to start. |
01-06-2018, 12:52 AM | #3 | ||
Hook a jumper pack or jumper cables to the body and positive of the starter motor. Then try the remote If its accessible from underneath on jack stands. Safety first.
4 users like this post: |
01-06-2018, 09:27 AM | #4 | ||
Join the local motoring club...NRMA RACQ RACV?? and they will open it. Probably better than paying for glass replacement and you have a years assistance.
GT450 |
01-06-2018, 11:17 AM | #5 | ||
I would have thought the key would manually open the door on an 03 Camry?
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
01-06-2018, 10:28 PM | #6 | ||
Hi. One would hope so, BUT after fifteen years of using a remote to unlock the doors this toyota like many I see will have the key barrels in the door handles seized. A good spray with CRC/WD40 etc etc etc may bring them back to life and you may find that the drivers door will only lock the car while the passengers door will only unlock the car. Cheers MD
02-06-2018, 12:51 AM | #8 | ||
Careful of snapping the key.
It can happen. |
02-06-2018, 07:48 PM | #9 | ||
Yep, use a spare, or get one cut.
03-06-2018, 01:15 AM | #10 | ||
true n tried age old method
youll need a brick
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
06-06-2018, 08:12 PM | #11 | ||
had to get into a ba falcon like this was lucky it had some wiring i could hook into i think i used the park light and feed back to the dash worked a treat.
sorry number plate light i meant |
06-06-2018, 10:19 PM | #12 | ||
I don't think that will work as you won't have a circuit from number plate light unless the lights are turned on.
07-06-2018, 12:17 PM | #13 | ||
actually I think its the same key as our 04 Prado. they snap real easy
07-06-2018, 12:20 PM | #14 | ||
Ooops !
Be very careful then. |
07-06-2018, 09:34 PM | #16 | ||
06-06-2019, 11:57 PM | #17 | ||
07-06-2019, 12:04 AM | #18 | ||
07-06-2019, 10:45 AM | #19 | ||
How to double the value of an 02 Camry? Replace the battery.
2 users like this post: |
07-06-2019, 10:58 AM | #20 | ||
One would have to wonder how stupid you would have to be to design a car in this way.
They must live on another planet to the rest of us. |
07-06-2019, 11:00 AM | #21 | ||
You couldn't open the door with the key and pull the bonnet catch lever?
07-06-2019, 12:20 PM | #22 | ||
I locked my AU and then disconnected the battery and closed the bonnet, realised the key didn't open the drivers door
so i jacked it up and got under it and "reached around" and while pressing the central locking button and tapping the battery cables i got it open, i disconnected both cables so it was PITA but i got in also jumper leads to ground and starter or alternator positive should get it powered up note to self: if i disconnect the battery again i'll leave the bonnet ajar and/or door unlocked
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
07-06-2019, 12:25 PM | #23 | ||
This is why you should leave your kids in the car.
2014 Ford Ranger XLS 4x4 Dual Cab. 2003 Ford BA Fairmont Ghia sedan. 1994 Ford EF Fairmont Ghia sedan. 1994 Ford ED Falcon GLi wagon. Discovered my love for Ford 4L. |
07-06-2019, 12:37 PM | #24 | ||
Take the door lock barrel out and get it matched to the key - then you have no worries about forgetting the other things, otherwise, it will bite you on the a*se again - I'm talking from experience .
07-06-2019, 08:40 PM | #25 | |||
I can turn that off with a key in the engine bay after getting a nice blast but pretty sure I can't start the car anyway |
08-06-2019, 01:52 AM | #26 | ||
Sounds like someone replaced the ignition barrel at some stage but didn't think it would ever be necessary to match the door lock, or at least keep a key.
08-06-2019, 08:59 AM | #27 | ||
08-06-2019, 09:03 AM | #28 | ||
10-06-2019, 01:26 AM | #29 | ||
B1 - J & D Services
When Ford used those Tibbe locks, Ea to AU, every single Tibbe key would lock the door, but only the right one would unlock it. I got reminded of this just the other month when I learnt my AU does not have matching door and ignition locks anymore!
Mr. Brett Johnstone. 2007 Honda Odyssey 2002 Ford Laser 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1982 ZK Fairlane 302 six seater 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
11-06-2019, 10:28 AM | #30 | |||
I don't think an 03 Camry has an audible alarm, you can enter/start our Prado just by using the key.
