07-09-2017, 09:57 PM | #1 | ||
Just disconnected my battery while fitting new coil packs to my xr8,all hooked up again and the ac compressor wont turn on now.
Am I missing something? It worked a couple of months ago when I checked it? The ac button light comes on when you press it but the comp isn't kicking in,i read that low gas can cause the comp to not kick in? |
07-09-2017, 10:10 PM | #2 | ||
Drive'n Cruise'n Live'n
Check the fan switch is actually switched to 1,2,3 or 4. I had it only partially engaged and Air con switch wouldn't illuminate .Cheers.
07-09-2017, 10:37 PM | #3 | ||
Yeah fan switch is definitely on,fuse is good,relay has been swapped for a good one,when you press the on button the relay doesn't click on.
Almost like the ecu isn't telling it to turn on. Ac button lights up when pressed. I thought there was some trick I missed after reconnecting the battery. I read in another ba thread if you wait for the error symbol to go out from the dash after you connect the battery again but it never went off. |
07-09-2017, 11:09 PM | #4 | ||
Was hoping it may have been a simple fix I could sort tonight.
Ill book it in to get sorted. |
08-09-2017, 12:45 PM | #5 | ||
As I kind of suspected,something was telling the compressor to not turn on,it was because the gas was low/non existant.
Leak near the receiver drier most likely the a/c guy told me,hopefully it doesn't turn out to be a dash out job if its not the drier... |
20-09-2017, 08:15 PM | #6 | ||
Just for the record if the ac system is low on gas the compressor will not kick in, like a self preservation function to save the compressor from damage,just in case someone else has the same issue.
