06-01-2012, 01:43 AM | #31 | ||
Critical Thinker
If u have live rear axle i recommend a eibach spring and koni shock combo. the spring height sits in between low and super low. gives enough clearance and rides nice for lowered car. handles awesome.
06-01-2012, 08:29 AM | #32 | |||
Resident AFF detailer
06-01-2012, 03:50 PM | #33 | |||
Virtuous Bogan (TM)
06-01-2012, 03:53 PM | #34 | ||
Critical Thinker
The dampening on the shocks can play a part on ride quality. The koni adj at least have the adjustable setting to help with a bit of ride qual and handling. These are the next shocks I will be getting. The BOGE has been good, but I require something better now.
06-01-2012, 06:30 PM | #35 | ||
rexnet
pedders. Koni then Bilstien's in that order is the word on the street.
KYB AGX's have adjustability though. |
06-01-2012, 10:42 PM | #36 | ||
Its on super lows now so I think anything will make it smoother. I would also consider ditching the dark argents in favour of the p250 18's
06-01-2012, 11:45 PM | #37 | |||
Me, brakes want doing (slight shudder under low/moderate application particularly at low speed)... last year put it back to stock height, shocks, trans service + Cooler, New Rad and new steering rack so not much left. |
07-01-2012, 11:38 AM | #38 | ||
Sales Representative
Hopefully something more than just adding fuel...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
07-01-2012, 02:29 PM | #39 | ||
Haha maybe I've compressed the springs! No seriously all my Falcons have done it even before I've owned them
08-01-2012, 01:42 PM | #40 | ||
Stay Classy ™
- Pull out stroker from Ghia .... DONE
- Put stroker into donor car .... DONE - Transfer interior from Ghia into donor car .... DONE - Transfer exhaust from Ghia into donor car .... DONE - Transfer audio gear from Ghia into donor car .... DONE - Paint & fit bobtail spoiler .... AT PAINTERS - Change handbrake shoes and steering shaft .... PARTS ACQUIRED - Strip & part out Ghia .... IN PROGRESS Wow, it's been a busy 2012 already! |
08-01-2012, 04:32 PM | #41 | |||
08-01-2012, 05:09 PM | #42 | |||
3..2..1..
kit - done ghia trim - done lol, not even halfway through january... gonna be a long year |
17-01-2012, 10:03 AM | #43 | ||
Get rid of the 18s and return to a smaller rim size
Replace all 4 springs and shocks and replace a few suspension bushes Replace all 4 manual window winders and inner door handles ( Correct colour ) Reinstall my speakers into the rear parcel shelf properly Install the matching rear seats i bought Then basically drive the bloody thing till i can get rid of it
17-01-2012, 11:33 AM | #44 | ||
My plans have changed a bit.
Gotta add replace driveshaft to my list :/
1988 XF Panelvan - Cam, 5 speed conversion, LSD, interior swap, 235/60-15 front, 275/60-15 rear, extractors/exhaust, Kings super low front and 2" blocks rear 1993 Honda VFR750F |
17-01-2012, 07:38 PM | #45 | ||
I have to concede I know bugger all about cars, so I'm just doing cosmetic things to my AU for the time being. Thinking about lowering it a bit and getting the Fairmont kit from Fibresports.
Oh, and wheels, I need to get wheels sometime soon. |
17-01-2012, 08:09 PM | #46 | ||
Have had the AU sitting in the garage waiting for me to finish the EB and since it's nearly done have started on "Baby" to get it looking and going better than it has before.
Things to be done:- Fix water leaking from pedal box permanately (remove dash and repair box support) Fit AU2 Ghia leather interior Fit 330mm front brake kit Fit 328mm Terri rear vented brakes Fit Koni Yellow shocks all round (looking for springs to use) Replace clutch and recondition T5 Fit Crow cam, timing chain and Trickflow manifold Will be starting a build thread soon.
We salute those brave souls that enter the DARK side |
09-02-2012, 05:06 PM | #47 | ||
New rims - DONE
Cut n polish - DONE Brakes & Suspension - Seeing someone in two days, found some S2 brakes S2/3 XR rear lip & side skirts - will be looking for closer to respray Respray - Poison Ivy (that green colour that SS commos are) Once I'm off the plates in 2013, that's when I'm looking at either a) Dart 347 stroker, or b) Coyote 5.0 conversion Was dreaming about it but with how I've been saving it's so much more achievable gonna be epic
DAS IT MANE
09-02-2012, 06:19 PM | #48 | |||
Wheels = all one colour now Paint = goes in on the 20th Speakers = installed Subs = still need replacing Exhaust = done with 2.5 cat back So only one thing to go in that list Also installed a tow bar the other day and got drilled and slotted front brakes with new pads for the front on the way
11-02-2012, 05:08 PM | #49 | ||
Define definitive
-get my bodykit on
-get the BA brakes on -front sway bar -bonnet respray -maybe a cam upgrade -drive it alot more since im on my P's soon
BF F6 TYPHOON in NEO #718 ~ 356rwkw : BF XR6 TURBO in SILHOUETTE |
11-02-2012, 07:36 PM | #50 | ||
Walking with God
SR
Respray rear spoiler Touch up stone chips Change theromostat, coolant and a few hoses Change tailshaft uni joints Aircon regass Money no object options V8 conversion, keep the manual SVI LPG Ghia Interior Sunroof Total respray - Congo Green Brembo brakes Tickford 17s rerolled and repainted Diff clunk removed Futura Replace swaybar bushes. Change tailshaft uni joints. Change header tank hoses. Aircon regass. Money no object options V8 conversion with reco auto SVI LPG Ghia Interior Sunroof Total respray - Sparkling Burgandy Brembo brakes Tickford 17s rerolled and repainted "Sigh!" GK
11-02-2012, 08:03 PM | #51 | ||
Stay Classy ™
GK, check out my part out thread, some bits and pieces there that could help you with your 2012 plans http://www.fordforums.com.au/showthread.php?t=11356290
11-02-2012, 08:32 PM | #52 | ||
for mine
New front end and bonnet fix rear end - bumper and boot lid have roof resprayed wheels refurb'd |
11-02-2012, 08:42 PM | #53 | |||
Walking with God
I'd take almost all of that if I had the coin, but I sadly do not! GK
11-02-2012, 08:45 PM | #54 | |||
Stay Classy ™
21-02-2012, 02:34 PM | #55 | |||
Brakes also upgraded. I purchased the 330mm upgrade kit of Matt a Race Brakes Sydney. Looks so much better behind the 18's. Haven't given them a hard time yet, so I can't comment on the performance.
HIS: AU III XR8 220, 5 speed manual, short shifter, MSD coils, ACRON CAI, Front 330mm brakes with C4 calipers and braided lines HERS: BA Fairmont, vapour injected LPG I reject your reality and substitute my own! |
21-02-2012, 02:48 PM | #56 | |||
Critical Thinker
21-02-2012, 04:30 PM | #57 | |||
Just looked at autotechnica. There are some nice designs there, but there isn't any info on them and the look like they are also universal fit. Do you know where you can buy these retails, as the website looks like it's only for wholesale customers.
21-02-2012, 04:43 PM | #58 | |||
Critical Thinker
21-02-2012, 04:44 PM | #59 | |||
21-02-2012, 06:06 PM | #60 | |||
Critical Thinker
http://www.autotek.com.au/shop/gear-knobs.html http://www.autotek.com.au/shop/a-tek-gear-knobs.html http://www.modyourcar.com.au/index.php?cPath=1_21 http://www.carpartsaustralia.com.au/...?cPath=229_230 Sure they might be universal but surely something in these links must appeal and still fit?
