Old 11-08-2012, 12:23 PM   #151
STINKY NINJA
Default Re: AU V8 models: Basic questions answered!
Originally Posted by keno49
Hi Guys,
I have put AU series 3 XR8 heads, manifold & cam into a my rebuilt 5lt EB2 wagon. I've been told the ECU has to be reprogrammed and I also need a 90mm MAS and I can't appear to find one in Australia. Can some one give me advice on this Thanks from keno49
I have the exact same combo on my eb bottom end with a standard e series tune 55mm maf and t/b. It runs very well.
It will run lean if you use a bigger t/b and maf.
It is on the limit for the standard eb tune though because ive had mine on the dyno and its around 13/1 afr although ive never had it ping on me using 98 octane.
The guy who dynoed my car told me it will be fine for everyday driving and the odd blast down the drags but refrain from doing burnouts.
Almost 30000km down the track ive had no issues and ive been to the drage 3 or 4 times.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 12:13 AM   #152
BHDOGS
90mm lightning maf on eBay from America mate if you want one cheapest I've seen
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 01:18 AM   #153
Nic302ef
Cocoloko
Nic302ef's Avatar
Originally Posted by XH5LWEPN
Just thought id throw this out there seeing as though this thread popped back up the other day.
I pulled the 200kw engine down out of my AUII XR8 ute tonight to carry out a freshen up.
I got the dial indicator and magnetic stand out and measured the Yella Terra rockers that were fitted to it, and can confirm that they were also 1.7:1 ratio.
Originally Posted by BOTTLEDUP
Agreed Jeff, I've been through all my Crane data, and I cannot find any evidence past or present of Crane making a 1.6:1 ratio pedestal rocker... Only 1.7:1 ratio.
ultra intresting info there, chuck a dial gauge on the crane rockers and confirm ratio.
In saying that the crane ones where made specific for Ford, so maybe thats why there the 1.6's and not avliable in the crane catalogue...
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build.
2010 Territory: family bus.
79 P7 LTD 351.
Nic302ef is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 01:44 AM   #154
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
These are the only Crane/Ford Racing ones we can see, and they are 1.7's.
http://www.summitracing.com/parts/FMS-M-6564-A50/
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2012, 03:47 PM   #155
Nic302ef
Cocoloko
Nic302ef's Avatar
guess will need to confirm the rocker arms from a 200 engine, cant rememeber if there was a part number off the rocker fitted to the falcon or is that the number that is on there?
Was looking at a set of them just the other day too lol.
79 P7 LTD 351.
Old 12-09-2012, 08:59 PM   #156
andoef
Hi there people, been a while since I was on here...
Have a question, I have a 11/01 build AUII XR8 ute,, I have had valve train noise for ages... Long story short, i pulled the rocker covers off today and found a broken valve spring... Howver the suprising part is that It has Yella Terra Roller rockers and double valve springs. Does this mean it is a 220kwe long motor? OR are all 200kw valve springs double and i just lucked out with some 220kw rockers? Heads are cast iron. Basically with the engine open how can I tell which long motor it is? Throttle body has no wings and there is no oil cooler... Need to know because i want to order a spring thru Ford..Thanks fellas
andoef is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2012, 10:07 AM   #157
RG
Back to Le Frenchy
RG's Avatar
Towards the end they just started throwing whatever they had into the utes. b2tf found the same thing, still only a 200 though I dare say.
Old 14-09-2012, 03:47 PM   #158
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
OMG, Russ lives!
Do you miss your AU Russ?
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 14-09-2012, 06:51 PM   #159
b2tf
not here much anymore
b2tf's Avatar
Yeh found the same thing on 2 AU3 XR8 utes i owned.
RAM 1500
Old 10-07-2013, 06:43 PM   #160
iceman123
Yeh hi
ive been looking for a straight forward
answer on engine no"s
I want to know with out looking @ pages after pages of total ********
What are the start off LETERS & NUMBERS
A HAND BUILT 220kw ENGINE
iceman123 is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2013, 07:30 PM   #161
b2tf
b2tf's Avatar
Originally Posted by iceman123 View Post
Yeh hi
The above mentioned 'pages of *********' would actually answer your question if you bothered to look.
The VIN number will not necessarily identify a 220 engine - you need to check a few things on the engine to know for sure.
But you know what - read the above mentioned 'pages' and find the answer yourself.
RAM 1500
Old 11-07-2013, 01:56 AM   #162
iceman123
Thumbs down Re: AU V8 models: Basic questions answered!
Sorry if im missing something
6 years of uni and the last 20 year
A marine enginer its the 1st ford ive owned & through
& through im an GM FAN the trouble ive had with everything ford
LOOKS LIKE I CAN HEAR THE CALL OF THE LION "S
RAWwwwwwww
ITS BACK TO
HSV FOR ME !!!
Old 11-07-2013, 10:04 PM   #163
b2tf
b2tf's Avatar
RAWwwwwwww
ITS BACK TO
HSV FOR ME !!!
Haha! All that education and you still can't read a forum or make a post.
Enjoy your commodore.
RAM 1500
9 users like this post:
Old 14-07-2013, 08:04 PM   #164
keno49
Thumbs up Re: AU V8 models: Basic questions answered!
At long last I have the wagon back on the road again. Thanks for the above advise. Just wondering what your eb produced on the dyno Cheers Keno49
keno49 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 01:41 PM   #165
DaveTE
Back in black
DaveTE's Avatar
Talking Re: AU V8 models: Basic questions answered!
RAWwwwwwww
ITS BACK TO
HSV FOR ME !!!
6 years of uni and the last 20 years a marine engineer, still can not read, spell or type. Thanks god it's back to Holden for you. Correction is "I'm a GM FAN"
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 06:52 PM   #166
revcore
revcore's Avatar
RAWwwwwwww
ITS BACK TO
HSV FOR ME !!!
Six years of uni and you are having trouble reading a few pages of USEFUL information on a forum? I'm a high school dropout and even I can read and understand this stuff
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 06:59 PM   #167
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Ok Gents. This is not a newbie, GM or grammar bash thread. Points have been made, let's leave it at that. Any further posts having a shot at the iceman post will be deleted.
2002 AU II LTD
Old 15-07-2013, 07:02 PM   #168
revcore
revcore's Avatar
Very true...My apoligies.
My Ride...
Old 14-08-2013, 03:03 PM   #169
nstg8a
3..2..1..
nstg8a's Avatar
Were xr v8 engine numbers different to none xr?
Just trying to work out if my lane has had a xr motor or something done to it.
Doesn't have any of the external clues, like the ticky tb or anything like that, but it just seems to go really well for what should be quite a 'sedate' big old car.
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2013, 05:24 PM   #170
Ride
Stay Classy ™
Ride's Avatar
Engine number should match VIN number. If they don't, motor has been swapped out at some stage.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2013, 09:51 PM   #171
nstg8a
3..2..1..
nstg8a's Avatar
Of course, I never thought of that, il check it in daylight tomorrow.
Old 02-11-2013, 03:33 PM   #172
MercurySilver
Isn't it obvious?
MercurySilver's Avatar
ok so this is in an au 5 litre from a fairmont ghia
someone tell me something about it
would be 175kw?
although it does have 3 inch and cold air induction fitted
cheers
08 Strike G6E T.
10 Ergo G6E
Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens
MercurySilver is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2013, 06:06 PM   #173
Ride
Stay Classy ™
Ride's Avatar
Yes, it's a 175kw motor. May have a little bit more power with the mods, but all Fairmont Ghia's had the 175 motor
Old 19-01-2014, 08:33 AM   #174
Gazza440
MoPar man 11
I like this post... Got the same deal man except mine is fully optioned AU111
and has the oil cooler.. and 3.5 inch behind airbox and a 70ml TB (NO WINGS EITHER) and a dotmax windscreen and clear side indicator lenses and colour coded mirrors so Im upset now to read FORD just threw whatever they found on it... What a bitsa
Gazza440 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2014, 08:35 PM   #175
FULSIK
My au 11 xr8 pursuit ute also the 1.72 yella terra rockers, doesnt have the factory c & c ported heads like the 220, the part number on the cam indicates its 200kw spec cam shaft and it doesnt have the tickford throttle body. odd....
FULSIK is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2014, 10:36 PM   #176
b2tf
b2tf's Avatar
Not as odd as you might think, I've had 2 XR utes like that now, both were series III and NOT 220's!
RAM 1500
Old 19-12-2014, 11:29 PM   #177
Dauphin
Irregular member
Dauphin's Avatar
I was wondering if anyone has an an AUII Windsor V8 engine bay diagram of what's what? So I can locate all the components and know what they are before I remove an engine and put it into another engine bay. Thank you...
Old 15-12-2015, 05:57 PM   #178
SSD-85
Bit of a threadmine here, but am needing some confirmation on the AU2 sedan 200kw motor;
- Crane 1.6/1.7 RRs
- E303 Camshaft
- Headers & Exhaust
- Regular 175kw TB
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2015, 06:45 PM   #179
FULSIK
- Crane 1.6/1.7 RRs
- E303 Camshaft
- Headers & Exhaust
- Regular 175kw TB
What about it? I have all the except that tb in my 200kw motor. Made 192kw atw not tuned
Old 09-02-2016, 09:48 AM   #180
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
Originally Posted by JC View Post
While we're picking, the XR8 utes on 200kw guise would have had the EGR spacer as well - all 200kw motors did. The 220 is the only one with a single solid TB/EGR setup.
Austin - as a moderator, can't you go back and edit your original post? I think it's worth doing because anyone that reads it will go, "Oh, OK, so that's the story", only to read further down and find all the corrections, which then makes people question the correctness of any info posted in a "one stop Q & A" type thread. I'd correct it with the right info, delete the below corrections, then close it so it's a one post thread (oh, and sticky it)!
Hi JC
i was just looking at this old thread, I just got a 11/01 xr8 ute, thimking it had the spacer it was a 185kw, but reading this it coild be a 200kw. I havent called ford yet, but is it possiable it is 200kw
Thanks
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
