22-05-2018, 07:01 PM | #1 | ||
One of the sites I worked on, they converted the trucks to burn their oil.
ie such that the oil was continuously being replenished and never changed. Obviously that works best in a diesel. Could you implement that on a petrol engined car? Would the engine management cope/ adapt? How would you implement it? Where would you take the oil feed from, bottom of sump or bottom of oil-filter? How would it be injected? Presumably it would clog existing petrol injectors. Could it be rigged to spray into in the manifold at WOT? And what would the effect be? The advantage on the fleet was burning the oil inplace of diesel, but mostly to avoid the cost of changing and disposing of the oil. Not sure, but I imagine the filters were still changed, as they would still have caught all the dirt and particulates. |
22-05-2018, 08:23 PM | #2 | ||
Experienced Member
In my opinion sounds illegal and contravenes EPA laws.
2 users like this post: |
22-05-2018, 08:48 PM | #3 | ||
22-05-2018, 08:52 PM | #4 | ||
That sounds strange but also the only petrol motor I can think of that burns oil by design is a 2 stroke petrol motor. And also diesel (I'm going to use that as my sort of example as its closer to oil then petrol) burns differently then petrol so there are big differences in how a diesel and petrol motor need to be constructed to get the most out of the different fuel. Compression ratios and fuel pressure being a factor but I'm not all over how stuff like that works. You probably could somehow inject a mix of sump into the manifold with petrol and the car would probably run but probably not as well as on petrol alone. And isn't 5L of engine oil more expensive then 5L of petrol?
22-05-2018, 08:53 PM | #5 | ||
5.0 means business
A pretty worn out engine would burn it's own oil but only to it's detriment.
Windsor V8 Enthusiast! Turbo Barra Lover! |
22-05-2018, 09:00 PM | #6 | ||
Shot rings or a cracked piston would also lose compression so that's a tad different to oil injection (yeah I know that's a 2 stroke boat or bike thing but it seems closer to the ops query then running a shot motor)
22-05-2018, 09:06 PM | #7 | ||
My old man was a firm beleiver in this. Not once in his entire life did he change the oil in his smokey old XA fairmont.
22-05-2018, 09:30 PM | #8 | ||
Some car companies are well ahead in this oil burning scenarios - direct injected engines especially.
22-05-2018, 10:11 PM | #9 | ||
Boss 335
Once saw somewhere on the interwebs a device (industrial heater?) that burns any sort of oil you give it, even waste engine oil, and it would put out some serious heat. Once toyed with the idea after experiencing a bill shock of $2k after moving into a new house
22-05-2018, 10:22 PM | #10 | ||
Seems like a lot of trouble to avoid changing the oil once in a while. The cost to change the oil is fairly small. Maybe they just want to keep the trucks moving 24/7? I’m with the OfficeManager; it sounds dodgy.
2017 ZG Escape Trend AWD 2.0L Ecoboost |
22-05-2018, 11:02 PM | #11 | |||
Plus, I think the diesels could burn it quite well, especially in minute concentration. In theory, if properly tuned, even a petrol engine should be able to clean it up with a Cat, but in practice not sure how. NB: On another site we got rid of all our waste oil, included reclaimed, in ANFO Last edited by PG2; 22-05-2018 at 11:34 PM. Reason: No need for the comments. I'm starting to get sick of either deleting or editing your posts. |
23-05-2018, 07:42 AM | #12 | ||
Falcon RTV - FG G6ET
In 1924, my old man went out to western NSW to work on a large sheep station as a Jackaroo.
The owner only brought Ford Model T's, he brought a new one every few years and gave his old one to the manager. The manager gave his old one to the overseer and the overseer gave his old one to the outstation boss. In turn the outstation boss gave his old one to the Jackaroos. In town on a Saturday night, they reckoned you could always here the Jackaroos coming to town form a pretty fair distance as the big ends were slapping pretty well by the time they got to drive it. You see, the Boss always said, it had oil in it when I brought it and I don't see why it doesn't have oil in it now.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
23-05-2018, 08:35 AM | #13 | ||
My Suzuki T500 burns all its oil ..
3 users like this post: |
23-05-2018, 09:07 AM | #14 | ||
I think a much better option is to have the old oil squirt into the rear tyres when stopped at lights so that you can safely burn it off during take off.
23-05-2018, 09:34 AM | #15 | ||
Au Falcon = Mr Reliable
Some trucks have two strokes (diesels) too.
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
23-05-2018, 06:40 PM | #16 | ||
Cabover nut
Yes my 2 stroke 6V53 Detroit, I guess if the injector rack sticks in the wide open position it would burn oil. (and everything else)
4 users like this post: |
23-05-2018, 06:58 PM | #17 | ||
Wirlankarra yanama
A small amount of two stroke oil per tank of diesel helps with the injectors. But purposely adding oil to the fuel with the intent of simply burning it away ... you do realise pistons have oil and compression rings to specifically stop oil and the combustion process from interacting.
23-05-2018, 07:07 PM | #18 | ||
Cabover nut
I use my used engine oil on the hardwood fence posts to stop termites and them drying out.
Three of my trucks use used filtered canola oil mixed with diesel to produce B50-B90 depending on the season.
23-05-2018, 08:54 PM | #19 | ||
My work ute, a 2002 VU commodore has burned it's oil off since new
24-05-2018, 09:47 AM | #20 | ||
mitsubishi have been doing this for years, been behind an early magna or pajero?
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
24-05-2018, 12:07 PM | #21 | ||
Not sure of the benefits, happy to be proven wrong but:
- If its using the engine oil you would need to continuously top up the engine oil, of risk running low. - surely dirty engine oil in the fuel wouldn't be efficient, and would soon clog a fuel filter. - oil filters would still need changing wouldn't they? - having working in servicing trucks, there's a lot more checks & greasing that are done as part of the oil change -so it still needs a service. - Cant be good for emissions almost certainly illegal.
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
24-05-2018, 12:08 PM | #22 | ||
Craptivas & Cruzes are taking over where the Magnas left off
24-05-2018, 07:34 PM | #23 | ||
Mad Scientist!
24-05-2018, 07:54 PM | #24 | |||
24-05-2018, 08:13 PM | #25 | ||
Experienced Member
25-05-2018, 09:40 AM | #26 | ||
*barks incessantly
Just stick to 2 strokes next time.
25-05-2018, 07:47 PM | #27 | |||
Mad Scientist!
Toyota's answer is to remove the PDF and EGR system. This is happening now on all mine sites(Private land) as well as yodas driven in cities (public). |
25-05-2018, 08:32 PM | #28 | |||
Experienced Member
Just because Toyota advises removal does not mean they are correct and in the end the owner of the vehicle/s is responsible for any breaches of EPA laws, I still stand by my previous post. You must remember cars manufacturers must abide government rules regarding emission laws, any modifications to these are prohibited. |
26-05-2018, 09:26 AM | #29 | |||
Mad Scientist!
On public land however...... |
27-05-2018, 01:54 AM | #30 | ||
*barks incessantly
They burn oil in Formula 1 as a power additive.
