Old 18-09-2013, 09:25 PM   #1
last fairlane
last fairlane's Avatar
Cool smoky 2.3 Sierra
Hi all Ive got a 1986 Sierra XR4ti 2.3 four cylinder turbo
and it pours a lot of smoke out of the timing belt/chain cover
it looks like steam /oil vapour and settles back on the motor as oil
I borrowed a trade plate and took it out for a run
and smoke came through the air con vents
the other thing is with the gear stick I have trouble finding gears they are all over the place from 1st to second sometimes you get 4th if you are not careful
the same with 1st and reverse no lock out it says press for reverse but you dont have to other than that the car runs very well with plenty of stick
also the clutch has to be pushed hard on the the floor to change gears
is there a seal of some sort behind the timing cover and can it be got to easily or am I in for dramas
Ive never seen one of these cars before
so Im hoping someone on here knows
thanks John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2013, 12:01 AM   #2
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
Default Re: smoky 2.3 Sierra
Yes John, I bought a whole engine gasket kit for mine, which came with the seals for the shafts at the front of the motor, as well as every gasket in the engine. There are seals at the camshaft, distributor shaft and crankshaft at the front of the motor.
This is where I got mine from: http://merkurmidwest.com/catalog/i111.html
From experience, you'd be better off pulling out the engine to do all the seals, as with the age of the car, the rubber seals dry out and shrink. Your valve seals will probably need doing as well.
Swanny
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay 100km Bike Ride
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2014, 09:22 AM   #3
Rs turbo
Hi I'm based on the Gold Coast and do a lot of work on ford sierra Xr4ti/xr4i and Rs Cosworths if you need a hand with sorting yours or are interested in selling please call mine self Aarron on 0431649697
Rs turbo is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2014, 10:37 PM   #4
Captain Stubing
I'm positive he sold it on Ebay, Aaron.
1971 Fairlane 500
