01-09-2017, 08:30 PM | #1 | ||
I seem to be hanging out in your forum quite a bit but seeing as I'm here I have another question for you lot.
What's the solution when you're at a garage getting fuel and the bowser's end tally is more than you think it should be? Innocent mix-up, technical explanation or garage owner intentionally ripping people off? From time to time I cut it real fine and let my tank run until it estimates less than 10KM left (yes yes I know, bad for lots of reasons, no amount of scolding is going to get me to stop). Not that long ago I filled up from a particularly empty tank and the bowser ran until it said I'd filled 65 litres. I think the tank in a BA falcon is supposed to be 68 litres but in 10 years-ish of having that car and doing around 500km/week, it has never filled more than 62 litres even right from naughty near-dead-empty. Except at one garage. An extra 3 litres per car would get around $4 extra per car and that'd add up pretty quickly. What say you, fordforums?? Innocent case of bowser not reporting correctly, a perfectly logical possible technical tank-related explanation or garage owner ripping people off? |
01-09-2017, 08:38 PM | #2 | ||
Some gauges are actually wrong. I am not well enough to get into detail, but I know they can be wrong.
01-09-2017, 08:43 PM | #3 | ||
Bowsers are checked regularly by the ACCC. When was your fuel gauge last calibrated against a known measure?
Unless the servo is out in the sticks, I think it unlikely the pumps have been fiddled. As an aside, franchisee servo's make SFA from fuel sales. |
01-09-2017, 08:58 PM | #4 | ||
It could simply be a case that the particular pump you used at the service station in question, had a less sensitive bowser nozzle shutoff (the first click).
I've been to servos where pump nozzles failed to sense the tank was full (did not click off) and petrol kept flowing and overflowed out the tank filler.... I'm sure many members here have had that happen to them as well. I know that at the first click shutoff, I can keep trickle filling and can often get another 5 - 6 litres into the FG's 68 litre tank. (naughty I know). However, you should NEVER do this, as trickle filling beyond the rated tank capacity will damage the emission control (carbon canister) in the fuel tank. |
01-09-2017, 10:15 PM | #5 | ||
Fuel temperature will have an affect on how much you will uplift. Warmer fuel/warmer day= less fuel that will fit in the tank.
Cheers 2010 FG XR6 Ute |
01-09-2017, 10:40 PM | #6 | ||
I think when the car indicates 0km left, there is probably 5-10litres still left in the tank... But accuracy of the float/sender and the computers interpretation of the level can vary...
01-09-2017, 10:53 PM | #7 | ||
Happens. A few years back in canberra I pull into the servo with a quarter tank and some how magically squeeze 84 litres into my 70 litre tank. Dodgy...
01-09-2017, 11:18 PM | #8 | ||
02-09-2017, 12:34 PM | #9 | |||
FG XR6T trayback
I think I know what you are meaning is that the energy value in the expanded hot fuel is less than that in cold fuel. Two different things. |
02-09-2017, 01:04 PM | #10 | ||
IWCMOGTVM Club Supporter
Your dte and how much you put in your tank are not a good way of verifying if the pump is dodgy.
As someone else said there is a reserve left in the tank. So 3 litres left at about zero is fine. It's when the car tells you have fuel and you run out there is a problem. IIRC some fg's had a bad can on the cluster and it did this.
Daniel |
02-09-2017, 01:29 PM | #11 | ||
I suspected this one time. Spoke to the attendant. I think we were in Moe at the time. He pumped fuel into a bottle to prove there was no discrepancy. We were satisfied.
02-09-2017, 01:39 PM | #12 | ||
Experienced Member
If you think the petrol station has an inaccurate fuel bowser then you can report it.
http://www.measurement.gov.au/Pages/contact.aspx http://www.measurement.gov.au/Pages/...the-Truth.aspx |
02-09-2017, 02:05 PM | #13 | ||
Like most substances, petrol expands or contracts depending on its temperature. In the U.S., 60o Fahrenheit (about 15o Celsius) is recognised by the fuel industry as the zero-point on the temperature scale where fuel is considered “normal” in energy content, weight, and volume—the actual space it occupies. So at 60oF, a normal gallon of fuel will occupy 231 cubic inches of space, but that same gallon at 80oF would expand to 233.7 cubic inches, and at a colder 40oF, would contract or “shrink” to 228.3 cubic inches. |
02-09-2017, 02:08 PM | #14 | ||
They are absolutely wrong sometimes. When I was younger I helped a friend replacing them because of this.
02-09-2017, 03:22 PM | #15 | ||
I have had this. A car i've had for 15 years, done hundreds of thousands of k's in it, and in all that time it had taken more than 90L ONCE. I knew it was down to fumes that time as I got caught out.
There is a servo near where I lived and filled up regularly, and all of a sudden it's taking more than 90L EVERY time, even when I thought it wasn't that close to empty. I changed pumps and same thing. Tried another servo and all was back to normal. I checked my logbooks (Work car so I keep them for tax) and every time I had filled up there the books showed abnormally high fuel consumption on the previous tank - or that there was more fuel going into the tank than there should have been room for. You be the judge.
2006 BF RTV 1980 HZJ 60 |
02-09-2017, 04:12 PM | #16 | ||
Peter Car
The DTE is always on the conservative side. When it goes to 0 km DTE it doesn't just die straight away. There is a margin of error built in to help stop people getting stranded.
Plus the fuel in the fuel lines isn't measured either. Could be a litre or 2 in there. |
02-09-2017, 04:41 PM | #17 | |||
Rob
The fuel pump itself needs fuel for cooling, but i believe the fuel pump sits in its own recepticle that doesn't drain as the fuel is emptied. I'm not too sure on this bit, and perhaps some cars are affected by running low but in the 25+ years i've been driving, I have always ran my cars from full to empty every time. none of this just chucking $10 bucks in or whatever. Fill it up, and drive until its empty, and then fill it up. Never have i ever had any issues with burning out a fuel pump or clogging a fuel filter. maybe i'm just lucky, but i don't think so. |
3 users like this post: |
02-09-2017, 11:35 PM | #18 | |||
Warm environment= Less fuel in the tank. It's something I have to deal with daily (1000s of Litres).
02-09-2017, 11:42 PM | #19 | ||
Rob
the fuel storage tanks are underground, no doubt partly due to better temperature stability.
i doubt the temp would vary enough to make any meaningful difference in your tank. |
03-09-2017, 08:05 AM | #20 | |||
Whether you pump in the snow or pump in 40 degrees a litre is a litre at the nozzle. |
03-09-2017, 05:53 PM | #21 | ||
FG XR6T trayback
03-09-2017, 06:32 PM | #22 | |||
Cabover nut
04-09-2017, 11:01 AM | #23 | ||
Boss 335
One thing I can't grasp, why are there so many servos if it isn't a profitable business? Owners might as well park all that money in a fixed deposit or investments instead of struggling operating a dud business
04-09-2017, 03:36 PM | #24 | |||
Have a look how many petrol brands are still around, 3 or 4 ? When I was a kid it was dozens & there was almost a servo on every corner in the suburbs. Servos make most of their money out of selling you milk, bread, newspapers & ice creams etc., not petrol. Look at Mobil, they sold their retail outlets to 7-11 who run very low overhead outlets. These guys rely on volume. Also have you seen the % return on fixed deposits these days ? Around 2% !!! Dr Terry Last edited by Dr Terry; 04-09-2017 at 03:48 PM. |
04-09-2017, 04:58 PM | #25 | |||
Go the Hogster!
I've always filled up after the first click but I find I can't do this in my FG. If I go past the first click, it always overflows. But every other car I've owned, I've always put in a few more litres after the first click.
Nitro XR50 - the last brand new one in OZ first registered Oct 2011. |
04-09-2017, 05:03 PM | #26 | |||
Peter Car
But I guess it's wether or not you actually have dirt or whatever in your fuel tank to start with, and that is more a result of which servo you fill up at rather than anything else. |
04-09-2017, 09:28 PM | #27 | |||
Rob
Either way, as mentioned, I've never ruined a pump or filter because of it. |
05-09-2017, 03:45 AM | #28 | |||
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
05-09-2017, 08:55 AM | #29 | ||
The one and only
Owning a service station is profitable, selling petrol isn't.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
05-09-2017, 08:50 PM | #30 | |||||
Sorry, had a busy couple of days and sort of forgot about my thread!
I run it down to 10KM estimate here and there but I've been caught out 4 times in 10 years and run it all the way down to zero. So yeah, turns out that zero isn't actually zero. No idea how much leeway there is but I made it 4KM past the point of 0 before I made it to a garage so it's at least 4KM in a BA falcon! Also good to know. I'm moving to a diesel soon and just when I think I'm comfortable-ish with understanding how a petrol engine works (or doesn't work), I have to start all over again with a diesel. I'm told that I also can't ever get lazy with oil changes with a diesel and they absolutely must be done regularly, is that true? My BA falcon burns through so much oil (long story) that I'm constantly filling it up and if I forget for a few months, it burns itself near dry. Hearing the tap tap is sometimes the only thing that reminds me but I do have to say that falcons are incredibly tolerant. It just keeps going, even when semi-crippled it still seems to want to keep going. But I hear that diesels just aren't as forgiving? Granted, the diesel doesn't have damage that will result in burning a lot of oil either. Quote:
My biggest suspicion is what happens in the event of a flood? If those tanks are underground, are they water tight so that nothing can get in? Or does water/debris end up in there during a flood? If it's possible, are there any regulations that require underground tanks to be drained and cleaned after floods? The one thing that I DO do (perhaps naively) is avoid petrol stations if there's currently a tanker there delivering fuel. My layman mind thinks that it makes sense that if there is debris in there, it's more likely to be stirred up when the tank is getting filled? Maybe in reality they are filling a separate tank and let it settle before allowing people to pump fuel out of it, who knows. Last edited by leesa; 05-09-2017 at 08:57 PM. |
