Old 10-06-2021, 01:17 PM   #1
50423736
Default Focus 2007 LT XR5 Turbo ESP System fault
Hi Guys, Thanks for having a look at my thread. I removed the Throttle body to clean it opened it right up to give it a good old clean. Refitted it sparkling clean, when I started her up it came up with ESP SYSTEM FAULT and was running rough as a badgers ****. I'm wondering if I've damaged the Thottle Body? any advice would be greatly appreciated. Cheers.
50423736 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2021, 10:01 PM   #2
11ford11
Default Re: Focus 2007 LT XR5 Turbo ESP System fault
First check all connections are in the correct place and tight
Scan for codes copy clear then rescan
Old 11-06-2021, 08:35 AM   #3
Peter B - CV8
These are electronic (ie not cable operated) ?? If you've opened the throttle body butterfly by hand, then you're likely to cause damage..
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2021, 05:56 PM   #4
marg99
if you are really lucky it may just need to relearn the calibration. plenty of videos on Utube to help you.
