Old 14-01-2006, 06:19 PM   #1
beaverman
Default KE Laser Radiator
Hi,
I've just replaced the radiator on a manual '89 Laser KE.
On the bottom of the old radiator near the drain stopcoc.k is a fairly large bolt. It looks like there used to be 2 wires that fit into the bolt but they've been yanked out.
I've put the old bolt into the new radiator but I'd like to know what its actually there for and what should be connected to it. The temperature gauge inside the car is working fine, the fan is kicking in when required so I'm guessing it might just be some kind of warning light or something.
The car seems to run perfectly fine without it but I'd still like to find out if it should be repaired or not.
If anyone can shed some light I'd appreciate it.
Cheers,
Kev
Old 15-01-2006, 01:01 AM   #2
VippiN
What a performer!
VippiN's Avatar
Not really sure what bolt you're talking about mate. If you can get a picture, I can compare it to one of my two KE's i've got.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 11:20 PM   #3
beaverman
no probs, have got some pictures.
Rad1 is the old radiator. The bolt fits in the big round hole in the bottom of the radiator (second hole from the left)
Rad 2 Is a picture of the installed bolt
Rad3 is the connector that should be fitted to the bolt
cheers for having a look
