Old 18-01-2017, 03:27 PM   #1
Vortex-98
Vortex-98's Avatar
Default EB,ED tickford headlights for AU xr8
Hey im just wondering how to replace the low beam headlights on xr8...will the headlights off a EB,ED tickford front end, coz they have the round quads as well,so will it have the same wiring loom plug as the xr AU an can it be used
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2017, 11:56 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: EB,ED tickford headlights for AU xr8
Probably could be done, but are a much different size light and would look a bit odd, That and the low beam on the AU is also the part of the hi beam set up
Originally Posted by Riksta
Old 20-01-2017, 08:14 PM   #3
Vortex-98
Vortex-98's Avatar
are they the same size as the au low beam lights.
What do you mean part of the low beam setup
Old 21-01-2017, 01:10 AM   #4
snap0964
The earlier XR's had projector style low beam lamps, while the AU's had a reflector headlamp.
If you're just replacing lamps due to damage, this might help you:
http://www.fordmods.com/ford-bodykit...e-t130945.html
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2017, 09:51 AM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
AU main light is a H4 Hi/Low beam globe inner light is a spot light
