Old 07-03-2018, 07:03 PM   #1
sednwol
sednwol's Avatar
Default PCV Valve
Where is the PCV valve located on the VCT Au engine? The engine is burning oil and it's only done 250,000km. I want to check to see if the valve is blocked.
Thx.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2018, 08:36 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: PCV Valve
On the top of the engine cover at the front, connects to the intake
UK
Old 07-03-2018, 08:44 PM   #3
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Hi sednwol, its plugged in to a grommet next to the oil filler hole on your rocker cover, a rubber hose is connected to it & its either made out of metal or black plastic.
Edit - I didn't see ya there UK, you too quick lol.
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2018, 10:35 PM   #4
sednwol
sednwol's Avatar
Thx to you both.
