10-01-2010, 07:36 PM | #1 | ||
EF Falcon
hey thinkin of buying a escort mk2, is it possible to fit a v8 in the bays? was hoping for a 5l winsor but could go smaller. has any one done it before or know any one or any links to someone who has?
10-01-2010, 08:11 PM | #2 | ||
Search for MD Conversions. They made a few of them before the govt outlawed them lol. Not sure about SA but you can't register them in nsw anymore. Largest engine you could fit there legally in nsw is 3L n/a or 2.5 s/c or turbo. If that helps
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
11-01-2010, 04:05 PM | #3 | ||
Yes, I remember a white RS2000 with the NSW plates - DMT351. It had a 351 in it. A fair bit of work required to the engine bay sheet metal.
Also the NSW branch on the Small Ford Car Club have a member with a White replica RS2000 with a V8. Contact Roy Rogers for more details if required. |
11-01-2010, 04:06 PM | #4 | ||
Heavy right foot
MD conversion fitted clevelands
and they were also blown burnout cars so a windsor will fit much better |
28-01-2010, 06:59 AM | #5 | ||
In WA we have the worst laws for any and everything anything not factory ! But even hear the 'tec sec' run by reno markise say's going from 4cyl to 6 cyl is ok with approval,brake up grade ect ect, but going from 4 cyl to 8cyl would never be regoed hear in good old "Wait Awhile"
any one know whats the story for tassie ? mine is a 1959 P/Van |
28-01-2010, 07:42 AM | #6 | ||
I was told that if u V8 it u will have fun in a straight line buy nothing else, turning, stoping and ride.... GONE !
31-01-2010, 03:42 PM | #7 | ||
: To get a v8 into an escort you need to find an engineer that will allow you to put an escort body on a chassis of a vehicle of similar size but with a weight over 1100kgs like a japanese ute.
31-01-2010, 09:39 PM | #8 | ||
EF Falcon
cant the frame and chassis of the escort be modified then stress and twist tested to be engineer aproved?
31-01-2010, 09:56 PM | #9 | ||
RTA rules go off original weight of the vehicle so it doesn't matter what you do to an escort unless you make it a rebodied car. At least thats the NSW rules
02-02-2010, 10:57 PM | #10 | ||
EF Falcon
any one know anything about SA
03-02-2010, 10:48 PM | #11 | ||
MD conversions?
Mark Dalla'qua's green one and the red one? http://www.youtube.com/watch?v=PLAHd_0P4qw
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
04-02-2010, 11:29 AM | #12 | ||
Ute Forum Moderator
bivo7 - check with Transport SA
11-02-2010, 08:01 PM | #13 | ||
are we there yet ?
had a 460 big block in a mk2 ...why? coz they said it wouldn't fit : ...although did have to make it left hand drive because of where the starter motor sits .Also had to hand make extractors. In all its not a 5 minute job but it does make for a fun car . As far as i know 302 as big as they will engineer for road use, unles you go for (VIC) street rod rego .
11-02-2010, 11:46 PM | #14 | |||
EF Falcon
derkdebone do you have any mor pics of your build would be interested in any v8 mk2 convertions cheers |
12-02-2010, 08:33 PM | #15 | ||
are we there yet ?
Mine was only ever built for fun ,never ment to see the road .Street rod rego doesn't require engineers reports but does involve you being able to join a street rod club and each drive has to be log booked. you will need to find out your local requirements (SA) but in vic its stock 302 , no extractors , 2 barrel carb and no engine mods for engineering . also body has to be seam welded , different engineers will have different requiements as far as cross members , brakes etc but seen as they are the ones putting their names on the certificate to say its safe then i guess thats understandable . i think if i was goin to do one for road use i'd try to track down a rover v8 as theyre all alloy , small , light weight , rev hard and because theyre only 3.6 litres should require less for a report(maybe). So first thing first , find and talk to an engineer or 2
14-02-2010, 07:11 PM | #16 | ||
EF Falcon
thanks will do got a week off soon will ring around and see where i stand. do you have any more pics of your v8 escort
15-02-2010, 02:53 PM | #17 | ||
Ute Forum Moderator
Not sure if they have Street Rod rego in SA, and their car club/historic rego is for standard-ish cars only, so you will be looking at normal full reg.
Saw a 302 Escort at Hanging Rock on the weekend, it had a custom firewall (heater pod removed) bivo - why not make a trip to Regency to ask your questions? |
15-02-2010, 07:26 PM | #18 | ||
EF Falcon
do you recon they will be able to tell me or is it worth contacting the engineers first
16-02-2010, 08:58 PM | #19 | ||
Matakana NZ
Find a P96 alloy V8, heaps lighter
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
17-02-2010, 06:59 PM | #20 | ||
Ute Forum Moderator
Bivo - I understand that is where all the tech guys are based so they ought to have the answers and requirements. If not they ought to at least direct you to the right place. If you have an approved engineer I'm sure they would know the ins & outs too.
17-02-2010, 11:43 PM | #21 | ||
EF Falcon
what is a p96 out of
18-02-2010, 09:29 AM | #22 | ||
Ute Forum Moderator
I think he means P76 V8. Could also go Rover V8 (the P76 is a larger version of this)
18-02-2010, 02:03 PM | #23 | ||
Heavy right foot
this was at hanging rock on sunday
18-02-2010, 02:35 PM | #24 | ||
Thats AWESOME!! Not a fan of the wheels but the rest is damn awesome!
If you see that guy again tell him Street Fords Magazine is looking for him for a feature hahah
