Old 18-04-2018, 11:49 AM   #1
bundybear75
bundybear75's Avatar
Default Engine malfunction warning and P244C DTC
Hi All,
Sunday evening driving home from work i was greeted by the cursed triangle of hate and the engine malfunction warning. Couldn't get a code from my eds scantool or ultragauge. Borrowed an ELM Bluetooth scanner and got the P244C trouble code using Forscan.
I was able to reset the warning but i haven't yet driven it to see if it will come back.
Dr Google tells me it could be a turbo, a dpf or the fuel vaporizer. Car gets a daily long run (120km each way to work) so I'm hoping not the dpf. Vaporizer would be the cheaper (?) option.
Anyone else had this issue?
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2018, 06:39 PM   #2
rondeo
Default Re: Engine malfunction warning and P244C DTC
Might be an idea to daily check the soot loading with forscan if you are going to keep driving it, just in case.
If it gets too high (don't know exactly what's too high) the DPF may not regenerate.
The max is usually around 80% on mine.
The differential pressure sensor and hoses are another possibility, and the vapouriser cokes up:
https://www.youtube.com/watch?time_c...&v=AAPSAnB4G2Q
Hopefully a glitch.
Old 18-04-2018, 07:32 PM   #3
bundybear75
Hopefully a glitch.
Worked out how to set up the gauges and watched them today driving to work. DPF soot levels started at 90%.
Almost as soon as I started driving the EGT and CAT temps went up to 650'C. Soot levels dropped down to about 25% over about 15/20km then EGT's dropped down to 200ish.
Then the soot levels slowly started building up for the next 50km to around 45% when I returned the ELM scanner to its owner (Rob the Coffee Van Man) and continued the next 50km to work. Looks like the burn must happen every 150/200km?
Some "Googling" at work and I have a OBDLink MX winging its way to me via eBay - I choose this one as it has good reviews from Mondaveo and supports MS CAN. The borrowed one was a V Gate that could be had for a few dollars.
Can you use Forscan to initiate a manual burn on the Mondeo? I had a quick look but didn't have much time to play with it
2002 BMW R1150GS
Old 18-04-2018, 10:33 PM   #4
rondeo
The OBDLink MX doesn't quite fit in the closed compartment. I use an extension cable
eg
https://www.ebay.com.au/itm/30cm-50c...Z1O37__CHII_uw
I velcroed mine outside the compartment where the leds can be seen. The OBDLink MX has a power saving mode where the green led blinks slowly.
I don't think a manual burn should be done willy nilly, only when a fault has prevented regen and has been repaired.
I think regens vary from about 100km to 500 km. I once checked mine at 350km.
Old 19-04-2018, 09:45 AM   #5
manchu
Thumbs down Re: Engine malfunction warning and P244C DTC
That's pretty much the frequency I found when I was actively monitoring DPF burns for a while. That was because of a different fault (P269F), which hasn't returned since.
https://www.fordforums.com.au/showthread.php?t=11460529
My advice is to not stress too much unless the fault comes back again after being cleared.
manchu is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2018, 05:58 PM   #6
GTLEGEND
Mondeo Vehicles built after 4/2012 have 3 EGT sensors. What your describing and the DTC logged can be caused by a EGT3 sensor malfunction. EGT3 is the one at the rear end of the DPF between the heat shields. EGT2 is in the middle of the DPF, between heat shields and EGT 1 is on the non heat shielded part of the exhaust near the flange of the DPF towards the engine front side . EGT3 has a part number of CG9A-12B591-AC.
I would be checking the EGT3 sensor operation..
Old 19-04-2018, 06:29 PM   #7
bundybear75
Thanks GTLegend, I have a Bluetooth dongle on the way and I will set some meters up to monitor whats happening when it arrives. I replaced the middle EGT sensor 12 months ago after a run in with a roo carcass. All seems to be going OK so far, I have done around 400km since resetting alarm and no new faults.
Hopefully a glitch when initiating a burn and dropped the error message
2002 BMW R1150GS
Old 26-04-2018, 07:35 PM   #8
bundybear75
So it happened again today. Luckily enough my OBDlink turned up in the post today. Same code, i reset it and went for a drive and the egt's went up to 400C, vaporizer on and then malfunction warning again. Couldn't reset the alarm this time so i took it to a mate who reset it using his snap on scantool.
Went for another drive and burn started again, some of the egt's went to 650C and some only to 400C.
I'm assuming i have a faulty sensor as GTLegend suggested but can anyone tell me which gauge goes to which sensor and also suggest what actual points i should monitor using Forscan?
Thanks in advance.....
2002 BMW R1150GS
Old 26-04-2018, 08:21 PM   #9
rondeo
Some explanation of sensor labeling here:
http://forscan.org/forum/viewtopic.php?f=6&t=1496
And further reading here:
http://www.talkford.com/community/to...roblems-p244c/
What month/year is it?
Old 26-04-2018, 09:10 PM   #10
bundybear75
It's late 2012. December i think.
I'm off to bed now 3AM start but i will have a read through those forums tomorrow. Cheers
2002 BMW R1150GS
Old 30-04-2018, 09:55 AM   #11
bundybear75
Replaced the EGT3 sensor yesterday (Funnily enough they had one on the shelf at my local Ford).
I'm going to monitor over the next week or two to see how the regens go. Before replacement there was a 200'C difference between sensors during a burn. Hoping to see a smaller differential after replacement.
Bastard of a job to replace. After getting the car high enough to squeeze my (ample) frame underneath I found that the old sensor needed a different size spanner to the new one. I also needed to unbolt and bend out of the way the heat shield to access the probe.
It was #%$^ing tight, I ended up using a larger spanner over the smaller 13mm one to get enough leverage to get it started. I also cut the plug off the old sensor so I could use a ring spanner as I didn't think the flare spanner would take that much force
Hopefully this will stop my DTC issues. This week I will do nearly 1500km commuting to work so any issues should rear their head fairly quickly.
2002 BMW R1150GS
Old 30-04-2018, 06:30 PM   #12
cobrin
Challenge Accepted!
cobrin's Avatar
I were hoping for your sake it weren't the vaporiser so fingers crossed you've got it.
Undecided replacement...
Old 02-05-2018, 04:49 PM   #13
bundybear75
So nearly 1000km since last error message and its back. So it wasn't the sensor, next up I guess is the vaporizer?
I had Forscan up this time and was watching the burn when it errored. When it first started CATEMP11 was 492°C and CATEMP12 was 582°C. After a couple of minutes temps dropped to CATEMP11 497°C and CATEMP12 496°C. Then malfunction warning and vaporizer off.
Previous successful burns have had temps of approx 470° and 620° so something isn't right.
I have reset the CEL and will try again for a burn after the kids bus gets here.
Any ideas?
2002 BMW R1150GS
Old 03-05-2018, 08:17 AM   #14
rondeo
The regen temp should be 600 deg +
Relay 4, on stage V cars switches the vaporizer glow plug. Test by substituting with another. Fuse is F6, check contacts. Yours is stage VI though?
The vaporizer is fed fuel from a pump. The pump is controlled by an ecu using pulse width modulation, I google 4Hz and ramping up. I don't know how to test it.
If the vaporizer is fully blocked a vacuum tester will hold vacuum. If partially blocked
it's more difficult to assess, and will need to be removed for inspection.
So I gather googling.
Old 03-05-2018, 09:14 AM   #15
bundybear75
Any ideas?
So after clearing DTC and a restart it immediately went into burn mode and completed a successful burn. Buggered if I know...... Not so keen to replace the vaporizer (@$400) if that isn't the problem.
Seems like every 5th (?) burn is unsuccessful.....
2002 BMW R1150GS
Old 03-05-2018, 05:26 PM   #16
rondeo
Possible DIY solution to vaporizer carbon blocking is to drill and tap into the end of the vaporizer and plug with a 4mm stainless hex head bolt, as per Meguinnes on Talkford.
It's hard to DIY if you're working though. You need expensive tools, and the technology has changed. Ford's information policy doesnt help either.
I'm retired so time is not an issue, and have spent lots on tools. Problem is Ford's unethical attempt to profit.
Information which might help the consumer with mechanical problems such as you are experiencing, is withheld in the hope of earning money. They try to profit by monopolising the service of Ford cars, pathetic really. Are they really that desperate?
Old 04-05-2018, 09:23 PM   #17
Mondaveo
Mondaveo's Avatar
I watched some videos. Might be useful to you?
https://youtu.be/AAPSAnB4G2Q
https://youtu.be/yop_WFCHvuc
https://youtu.be/9Tm_y02fGPw
Seems like for P244C it may be the vaporiser.
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2018, 04:31 PM   #18
bundybear75
Yeah thinking you may be right.
The code is starting to come up more often now, so I need to sort it out. I did consider drilling it out and plugging the end as per Meguinnes on Talkford method but I can't afford to have it off the road for too long if it doesn't work (my other car uses $150 in diesel per 3 days if I have to drive it)
I'll order in a new vaporiser and change it out. Does anyone know if it comes with the glow plug or is that ordered separately? Hopefully that will solve my issues as I'd like to get a few more years out of this car.....
2002 BMW R1150GS
Old 05-05-2018, 06:53 PM   #19
rondeo
The vapouriser part includes the glow plug and nozzle.
When replacing the vaporiser keep an eye on fuel dripping from the supply hose. Best to plug it with a drill bit or similar when you disconnect. Reason: the pump may not self prime if emptied of fuel.
Best to test first before replacing, but won't hurt to have a new unit at this stage (200,000km).
Normal resistance of glow plug is about 1 ohm, I see.
Old 05-05-2018, 07:04 PM   #20
bundybear75
My only concern with replacing this is at this stage it is an intermittent fault. Usually after resetting codes the system does an successful burn. Hoping to get 400+K km out of this so I am a bit concerned that I'm starting to have some niggling issues at 200K
2002 BMW R1150GS
Old 06-05-2018, 04:08 PM   #21
Highway cruser
I had a similar issue, didn't get the code the first time so assuming the code was the same the first time as it was the second. There was a few weeks between the first fault code which cleared its self. The second time I got the code P269F which is a similar thing as I understand it, relating to the vapourisor. I also do about 1500kms a week and this happened on the Friday afternoon so no time to do anything to sort it out at a shop. So I striped the vapourisor out the exhaust. The first time I tried to blow through the fuel line it felt very restricted, not what I was expecting. I gave it a few good squirts of MAF cleaner, the only thing I had at the time and didn't want to use anything to harsh. Afterwords I blew through fuel line and it was a lot easier to blow through.
I tested the vapourisor before this and got the 1 ohms that has been mentioned earlier so wasn't convinced the vapourisor was the issue, but had found information that they can carbon up as also mentioned.
I refitted to the car and went for a drive and as soon as I hit 100kph a regen started. That was over a month ago and I haven't seen a reoccurance since and I've done several thousand kilometres since.
The vapourisor is very tight to get out. I gave it a soak in WD40 for 20 minutes or so after trying to get it out without it. After the soak it moved but still was very tigh to move.
I would recommend a good quality long handled spanner not the statandard length.
Highway cruser is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2018, 07:03 AM   #22
bundybear75
So I bit the bullet and replaced the vaporiser. Trade price was a little over $420 at my local Ford. I could of got one cheaper off eBay but as the Mondeo got to the stage that it wouldn't complete a burn it was costing me $50 a day to drive my Cruiser.....
Attempted to change it myself but laying under the car (on ramps) using a long handled 22mm spanner and 3 foot of pipe I couldn't get enough of a swing at the nut to undo it.
I took it in to my mate the mechanic and lifted it up on his hoist and one of his boys changed it for me. Took a crows foot socket and a 3 foot bar to get it undone.
Definitely the cause, the hole was all but blocked up with carbon. After changing it did a complete burn and the soot levels have remained lower (only building up to 40% after 200km) than before where it was burning every 150/200km.
Time will tell but hopefully a win.
2002 BMW R1150GS
Old 19-05-2018, 09:47 AM   #23
bundybear75
Well the saga continues.....
When I got home Thursday PM the Mondeo had just started a burn, so I left it running (at idle) for 10 minutes whilst it completed.
Started up this morning to drive to work (i didn't have Forscan up) and Engine Malfunction warning again and this time limp mode.
Pulled over and scanned, got DTC P2002C - DPF efficiency below threshold
Reset OK and monitored the gauges. the DPF_LOAD gauge was at 0% and DPF_SOOT_LD at 25%
After about 5 minutes of driving the DPF_LOAD jumped from 0% to 25% and climbed as normal to 61% by the time I got to work (120km). It should be due for a burn about half way home so hopefully will complete a successful burn and continue on.
I have to say I'm about over these DPF problems.....
2002 BMW R1150GS
Old 19-05-2018, 11:02 AM   #24
rondeo
Maybe prolonged idling can lead to P2002, which is a temporary loss of regen efficiency due to low engine load?
With my car I don't allow the engine to idle if a regen is in progress. I just switch the engine off. It will sort itself out next time.
Old 19-05-2018, 11:18 AM   #25
bundybear75
Might be the better option. For the last two years I have just turned it off at the end of a journey blissfully unaware of what the DPF was doing. Maybe a lap up the road and back whilst it finishes would be better (or just leave Forscan turned off...)
These problems are concerning, I have just had the DPF's and injectors replaced in my Landcruiser (under warranty thank god $13000 in parts alone). This was due to an overfuelling issue with the early DPF Cruisers leading to excessive soot and smoke.
My next step will probably be a (off road use only) DPF delete.....
2002 BMW R1150GS
Old 27-05-2018, 11:58 AM   #26
bundybear75
Fingers crossed the problem is solved!
I have done over 2000km since the last error message and all seems to be working properly. Burns seem to work at a regular interval and car is running well.
2002 BMW R1150GS
Old 27-05-2018, 10:59 PM   #27
cobrin
Challenge Accepted!
cobrin's Avatar
Thanks for the update bundy
I had to back out of the garage last week cause I noticed mine were doing a regen, fuel consumption display were high at idle ~3L/hr and any pedal input saw it rise from 9L (light input) to 53L (foot flat) and the fan going full tilt, temp nice and hot and slight rough running from normal. So back out I go and give it 'a darn good seeing to'.
Well one massive black smoke cloud from standstill in sport mode 1st gear, must have cleared its bowels cause it settled back to normal after that. I never got to give it a run this week/month will do next weekend.
Have Behana Gorge to check out.
Old 28-05-2018, 08:28 AM   #28
Highway cruser
Its interesting that you and others I’ve heard of getting black smoke out the back, I’ve never managed to get any noticeable smoke out the back despite my best efforts.
Old 28-05-2018, 10:39 AM   #29
cobrin
Challenge Accepted!
cobrin's Avatar
yeah my missus has short trips to work and back so it builds up quickly. Just worked it out to 4.5kms each length so 9km return. Very short which is why I try and give it a run on the weekends after the kids sports/grocery shopping/other.
<off topic>
Well I try to organise roadtrips as much as I can, but you know life gets in the way sometimes. Last major trip were in March, Cairns to Townsville return in the same day. It were great with good tyres/timing belt done/new brakes/suspension still performing like a champ....it ate it up like it were nothing
Old 28-05-2018, 11:12 AM   #30
bundybear75
<off topic>
Mine gets a good run (240km) every day commuting to work. I have not noticed any black smoke from mine but it would burn almost every day.
I found my fuel consumption increased a little after the T belt change but I also got new tyres the same week.
It has felt a little better this week after I changed all the filters and oil last weekend, and has been happier since the vaporiser replacement.
I couldn't believe how black the fuel filter was when it came out. 30K and looked like a dirty oil filter.....
2002 BMW R1150GS
