Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items
Spare Parts and Other Accessory Items For all other Car Parts and any general items for sale. Note: ALL transactions in these forums are done at your own risk. FordForums Australia Inc. does NOT take responsibility for any aspect of any item or transaction that may take place via the site.
Old 30-03-2018, 07:09 PM   #1
Juicy330
Juicy330's Avatar
Default BA BF Territory aftermarket headunit harness
Just testing waters to see if much intrest out for a quick plug and play power, ground and accessories wire harness for aftermarket installs on BA, BF and territory's, these harness will be 25 each and make life easy for people who don't want to pay upto 300 to get someone else to install a headunit.
Sent from my SM-G935F using Tapatalk
Juicy330 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2018, 07:40 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: BA BF Territory aftermarket headunit harness
Hi. You would need to put male and female plugs on the end that goes behind the fuse box so that any accessory plugged in to that power feed can be re-connected and make sure it is long enough to be cable tied to the existing loom that goes across the dash behind the cluster to ensure that it doesn't get caught in the adjusting bracket or pull on the existing wiring at the steering column. I have made a few when needed but that looks like a quality bit of work. Cheers MD
HI
I'M MICHAEL
Old 07-04-2018, 12:22 AM   #3
Juicy330
Juicy330's Avatar
Small update...
I Have just made up V2 of the looms, have added in extra plug for people looking to do headunits thru the icc to keep the steering wheel function and premium sound ect... the plug is for people running the powered AUX cord.
Price still same $25 but also postage anywhere is $5 extra cheers
Old 21-04-2018, 08:50 PM   #4
FordFalconBF
2008 BF Futura
FordFalconBF's Avatar
So this plugs in to where?
2008 BF Falcon Futura
2009 BF Falcon Wagon Dedicated LPG
Previous Cars:
2003 BA Falcon Wagon Dedicated LPG
1999 Ford Fairlane Ghia
XF Fairmont Ghia
Escort MK2 RS2000 Replica
FordFalconBF is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2018, 09:53 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. It plugs into the mobile office power connector behind the fuse box (the same connector that is used on falcons to provide power for phone kits, amplified aux input kits and VDO navigation kits and also on some territorys it supplies power for roof mount DVD screens.). Looks like a good bit of gear with a tough nylabraid sheath to protect it alough it could have done with the mute wire as a pass through so a phone could be plugged in as the last thing in a chain. Cheers MD
HI
I'M MICHAEL
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
