08-08-2005, 08:36 PM | #1 | ||
G'day all
Last week my "Check ABS" light would come on every now and then. Last night the bastard turned on halfway home, and stayed on. Brett (lunaefghia) drove my car the other night and remarked how firm the brake pedal is - i've been noticing it getting harder and harder to brake lately. The fluid is top notch, the pads are fine..... what could be the problem? Pully
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
08-08-2005, 08:36 PM | #2 | |||
meow
To much ing single spinning and going sideways with said single spinning and thrashing your brakes perhaps?
08-08-2005, 08:47 PM | #3 | ||
Smile
I was finding the check abs light kept coming on freeway trips. Or trips at around 100 kmph.Our front wheels have electronic sensors attached to them.From memory dust gets in and sets the light off.From memory all i did is get the hose and clean the area out.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
08-08-2005, 08:50 PM | #4 | ||
I had a mechanic mate who changed the rotors on a EF, and it seemed the sensor was damaged, and it constantly thought the brakes were locking... wrote off the car through someones front fence, and nearly killed himself.
So yeah, if it's getting harder and harder to brake, watch yourself! |
08-08-2005, 09:02 PM | #5 | ||
Usually a damaged brake booster will caue firmer braking. Can you hear a sucking when you apply the brakes?
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
08-08-2005, 09:10 PM | #6 | |||
08-08-2005, 09:17 PM | #7 | ||
Oops, I slipped....
They're fairly common to crack too as they're plastic.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
08-08-2005, 10:49 PM | #8 | ||
Custom User Title
Mine done the same thing, took it to ford and they said the comp had sh!t itself, and would be worth the $$$ to fix, so they disconnected it for me, brakes atleast work now.
When my Check abs light was on, the pedal would drop while trying to brake without lock up, that was scary!! |
09-08-2005, 01:41 PM | #9 | |||
XR8 v Lee. love you Lee
mine came on the first time only at high speed , stopped turn off , restart , ok . sought advice and (in my case) system self diagnose at start light off ok sensor disabled (1) high speed but computer reset at start . pickup sensor was loose and dirty causing the problem . never happened since , that was 4 months ago. hope it helps . cheers. |
09-08-2005, 04:27 PM | #10 | |||
09-08-2005, 04:43 PM | #11 | ||
Turbo Dinosaur FTMFW
hmmm i think kev's reply could have been structured a bit better.
i think he's saying the abs sensor on the stub axle was loose and dirty, with a clean up and tightening the mounts it worked ok. |
09-08-2005, 04:51 PM | #12 | |||
meow
21-11-2005, 03:53 PM | #13 | ||
Sonic DV8
Hey Pully,
Did you end up sussing this out as I just bought an EB XR6 and the light has come on after the battery was disconnected and it won't go away. Brakes feel fine. |
21-11-2005, 05:41 PM | #14 | ||
RDOmain,
Mate. You prob need to put the ABS system into diag mode and get the error code from it. See here http://www.fordmods.com/forums/documents.php?doc=48 |
21-11-2005, 09:04 PM | #15 | ||
Hey Ritchie, nah I haven't got it sorted as yet. I changed the rotors and pads, now I'm thinking the booster is damaged... $$$
Is your pedal firmer? ps How come you bought an EB XR6? What happened to the ute?
22-11-2005, 10:29 PM | #16 | ||
Sonic DV8
Cheers for the link bdennis. Very helpful. I'll have a shot at that this week and see what goes.
And Pully; the pedal doesn't appear to be firmer. The light came on after the battery was disconnected a few times but now it wont go away. And don't you worry, we still have the ute Won't be getting rid of that baby! http://www.fordforums.com.au/showthr...d=1#post418175 (gf wrote off the other car we had and don't worry, she wasn't hurt and it was only a VT) so we thought we'd replace it with the original XR6 |
