Old 17-09-2006, 06:45 PM   #1
reded
ThUmPeR
reded's Avatar
Default weird light on dash
hey, ysterday i put in an EA sports cluster into my ED falcon. and now there is a weird light in the middle bottom of the dash that im not sure what it's for. i've put the oil presure sender in so it wont be that.
heres a drawing of what the light looks like.
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
2.5" exuast, Pacemaker extractors
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
clear indicators all round
Full EL Ghia interior
reded is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 06:48 PM   #2
Mickus
Mickus's Avatar
yep thats telling you that your coolent level is low. Time to top her up. Hope that helps.
Mickus is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 06:57 PM   #3
reded
ThUmPeR
reded's Avatar
Thanks heaps for that. helps heaps!
cheers
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 17-09-2006, 07:05 PM   #4
reded
ThUmPeR
reded's Avatar
hey i just topped up the coolant and the light still comes on???
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 17-09-2006, 07:07 PM   #5
LUXO_8
windsor user
obviously you dont have the coolant level sender in your radiator overflow bottle... so the light will be on constantly....
IMO remove the globe from your cluster.....too much trouble to wire it up
Old 17-09-2006, 07:16 PM   #6
kyro_02
V8 wannaabeee
kyro_02's Avatar
i've been having that problem since over a week ago.... i top it up and it still does it !
.. i find it does it when i first start the car up (after leaving it for an hr.. then when it warms up when water rises it turns off) .. also happens when going around a bend :(
i filled it up 4 days ago so meh.. i got a leak some where
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 07:16 PM   #7
ORSMEB
Steve
ORSMEB's Avatar
Or is it actually the wiper fluid level...?
Silver PJ Ranger XLT
...with goodies...
ORSMEB is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 07:30 PM   #8
reded
ThUmPeR
reded's Avatar
thanks for the help guys.
cheers
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 17-09-2006, 08:03 PM   #9
Allen
You win again, gravity!!!
Allen's Avatar
I found in my fairlane, that the float in the coolent level sender didn't actually float anymore...
The float is a magnet encased in plastic, so I just cable tied the float up against the sender's magnet and the light went off.
Anyway, did the EA cluster go in easily? does the smartlock effect it? Is the oil pressure sender difficult to install?
I want a sports cluster for my ED, but the smartlock ones are always more expensive...
1994 ED Ghia
SOON TO BE A TRACK CAR
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:14 PM   #10
NZ
NZ's Avatar
All the smartlock one has is a spot for you to clip in the LED. If you can't find one use a regular cluster and extend the wiring and mount the LED elsewhere.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:30 PM   #11
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
what are you on steve! why would you need to know if you wiper fluid is low?
btw putting in the sensor is really eay you will need the coolant over flow bottle witha hole where the sensor goes and of coures the sensor the plug that connects to it is hidden under the overflow bottle itself tucked away plug it all up and you light will be acctually useful or you could do what i did and many others just remove the globe.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:31 PM   #12
LUXO_8
windsor user
no joke, the high end cars had a washer fluid level light.....it doesnt look like the one pictured in the first post though
Old 17-09-2006, 09:34 PM   #13
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
crazy why don't they have one for the temp in the passengers that would be more useful .
Old 17-09-2006, 09:35 PM   #14
LUXO_8
windsor user
heh...no idea......they have the ambient temp for outside on the EB2 on climate.....
Old 17-09-2006, 09:41 PM   #15
Xplode0185
Xplode0185's Avatar
my ed xr6 has the washer flued level
Xplode0185 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:42 PM   #16
5L
[ 5L ]
5L's Avatar
when my washer fluid is low that light comes on, also if the radiator level is low the same light comes on
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:44 PM   #17
Xplode0185
Xplode0185's Avatar
mine are 2 differant lights
Old 20-09-2006, 04:09 PM   #18
MotherNature
MotherNature's Avatar
XR-6000 hit the nail on the head ........... I had exactly the same thing happen in my old EA when I put in the sports cluster ..... if the water level wasnt right in the washer bottle this light would appear ....... As too if the water level in the coolant bottle ........
1994 ED XR8 Sprint
2005 PH XLT Courier
2006 Silhouette SY Territory Ghia 6spd
MotherNature is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2013, 05:29 PM   #19
91ebxr8
Default Re: weird light on dash
I have the same light coming up on my ed 5L but it's straight after I start it up and I read some where that it could also be a temp sensor on the engine causing the car to go into limp home mode. I only have 1st and 2nd gear and to get it to change into second I have to back off the throttle and it changes any one ha this or heard of it
91ebxr8 is offline   Reply With Quote Multi-Quote with this Post
