Old 18-04-2012, 09:22 AM   #1
302 XC
Default ED on a diet
Righto lads ive an ED here (GLi classic ???)
For a little fun i wanna see what can be removed as excess weight to get a better 1/4 mile time
Now its low low budget , so im at this stage looking at weight reduction rather than spending
So what have people removed as excess weight and what if anything did it acheive
Is a full interior strip out that beneficial at the track
Is stuff like running alloy rims as opposed to steel rims that much difference ???
Is there a formula that for every KG you remove will reduce the 1/4 times ???
Or is that another myth ???
Any ideas ???
Edit :
Years ago we done similar to a torrie, but we drilled big holes in the doors,but the metal was alot stronger , will the ED doors go floppy if i went that savage ???
We also removed excess steel from the bonnet and boot shells and removed all hinges and brackets and went to a 4 pin style , is there much reduction doin that to an ED, as its struts on the bonnet rather than hinges ???
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 01:27 PM   #2
LTDHO
The one and only
LTDHO's Avatar
Default Re: ED on a diet
I assume it's a road going car also?
Pulling out the interior for race day will help you go quiker. Any weight loss will. Smaller petrol tank, gut the doors, etc.
Tuned by CVE Performance
Old 18-04-2012, 02:00 PM   #3
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Is it still to remain street reg?There is a fair amount of weight to be taken out everywhere.
-Sound deadner everyhwere under the carpets that's worth removing for a few kgs.
-Aircon and its systems, like condenser and plumbing.
- Stereo
- Back seats
- Window regulators, can just fab a little bracket up to hold windows up.
- Remover the intrusion bars in the doors
- Heater box and fans behind dash. (I just did this and its probably a good 12kg with all the ducting, maybe a touch more.)
- Light rims, I think factory steel rims are probably the lightest option.
- Sway bar, take the front one out, helps with weight transfer and weight.
A 1600kg car with say 110rwkw will do a 16.2@94
A 1500kg with same power will do a 15.8@96
1400kg 15.4@98
So weight is worth taking out, but also horsepower helps lol
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 02:01 PM   #4
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Alloy Wheels are a must - steel wheels are to heavy - get some 15x7 Snowflakes - light as wheel and wide for wide tyres
Also check Progect Bluebird out (EF Falcon) see here http://www.youtube.com/watch?v=N1lJomqHniU
Dry ice to remove the sound deadner
Air Con - Heater removal also
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 02:05 PM   #5
Psi-Pop
Psi-Pop's Avatar
Whats the weight on a snowflake?
8.9x@160mph+
Old 18-04-2012, 02:28 PM   #6
Sorted
Sorted's Avatar
Under 10kgs each if I remember correctly - I will see if I can get a dendintate answer
Tuned by DYNOMOTIVE
Old 18-04-2012, 06:36 PM   #7
302 XC
Thanks for the tips
No the car is not regoed, and probably never will be (another rego)
Now the rims,just on comparing a 12 slotter factory rim to say an old jelly bean style 5 slot,wow there like chalk and cheese in the weight stakes
Be interested in knowing what a 15" snowflake and tyre at say 30 PSI weighs
That aside at present ive a choice between the steel factory 14 " rims or the 5 spoke style XR series rims (alloy ???)
The air con is goin , its not hooked up , so gone , the steer set up will stay
ill throw updates up as i go
Old 18-04-2012, 09:03 PM   #8
Sorted
Sorted's Avatar
I will weigh the 15x7 snowflake with a Mickey T 235 wide tyre on it when I next go to my parents
Make a build thread in the OzEcruiser Build Section - it also helps you keep a time line of what you have done and when you have done it
Tuned by DYNOMOTIVE
Old 18-04-2012, 09:46 PM   #9
Psi-Pop
Psi-Pop's Avatar
Ill weigh a 15x8 stockie with 255 MT on them tomorrow
8.9x@160mph+
Old 19-04-2012, 10:05 PM   #10
Sorted
Sorted's Avatar
15x7 snowflakes with 235 Mickey T's weighed 21kgs
15x6 Steelies/Interceptors with 225 retreads weighed 21kgs
The Steelies/Interceptors felt heavier but didn't read heavier
But that was on really really old human scales which had one foot missing so prob gave me a wrong reading - will have to find some proper scales lol
Tuned by DYNOMOTIVE
Old 21-04-2012, 11:45 AM   #11
Psi-Pop
Psi-Pop's Avatar
15x8 Steelies with 255/60 MT Street Radials are 23kg with a decent set of scales.
8.9x@160mph+
Old 21-04-2012, 05:35 PM   #12
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Get some Space saver's for the front.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 01:08 AM   #13
trick_xd
I build your wish list...
trick_xd's Avatar
if you really really want to put it on a Diet ... PM me
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 10:59 AM   #14
302 XC
From another forum
15" E series 5 spoke XR type rim
Tyre and rim 17.7 KG
