20-05-2017, 11:03 AM | #1 | ||
I recently changed over the centre console on my wifes car as the display and controls were intermittently not working and now the radio comes up with CODE. It apparently needs a reset using something like Forscan, I am ordering an adapter but it will take up to 10 days. My wife is not happy as she has a long commute to work.
Anyone got one they are happy for me to use this w/e? Am in Melbourne, happy to leave deposit etc. |
20-05-2017, 11:27 AM | #2 | ||
HSV - I just ate one!
have you gotten the security unlock for FORSCAN?
I havent yet found any way to change any settings without getting the unlock....
20-05-2017, 11:42 AM | #3 | |||
If you give them the VIN number they might even be able to look up the code. |
20-05-2017, 11:55 AM | #4 | ||
20-05-2017, 12:23 PM | #5 | ||
if your near croydon north drop me a pm, have cables and software
20-05-2017, 06:20 PM | #6 | ||
20-05-2017, 07:31 PM | #7 | ||
Have you tried the following... Hold AM + Menu. That clears the code on the B series.
20-05-2017, 08:07 PM | #8 | ||
Hi thanks, yes this works, but only for 5 minutes. not a permanent fix.
20-05-2017, 08:14 PM | #9 | ||
Not sure if this will work on the B series.... But on an FG series, if you change the ICC (which of course is mated to the car) with another replacement ICC, you can get around the coding problem by simply installing the CD player from the original ICC into the replacement ICC.
It appears the mating of an ICC to a car is coded into the CD electronics |
20-05-2017, 08:14 PM | #10 | ||
Gazza!
Just register the program, it's free.. I've done it a few times and done coding stuff.
2005 Silhouette BA Fairlane Ghia Turbo 2017 AFF Nats best burnout chariot ZF 6spd converted, GTX3582R, plazmaman and xforce goodies, tuned by BluePower Racing Developments. 11.79 @ 122mph RIP 2006 - 2017
20-05-2017, 08:20 PM | #11 | ||
Slightly off topic, but will one of these allow you to re code ICCs, clusters etc
Vixen Red FG MkII Ford Falcon XR6 EcoLPI My Show and Shine thread: https://fordforums.com.au/showthread...27#post5975027 |
20-05-2017, 08:20 PM | #12 | ||
you are probably right,
20-05-2017, 08:22 PM | #13 | |||
20-05-2017, 08:46 PM | #14 | ||
21-05-2017, 11:07 AM | #15 | ||
Hi. The fault in your old unit may be repairable, have a look at this thread, https://www.fordforums.com.au/showthread.php?t=11462915 . The symptoms are different but the reason for the fault may be much the same, just a different pin (or pins). Cheers MD
21-05-2017, 01:28 PM | #16 | |||
22-05-2017, 09:09 PM | #17 | ||
still looking
28-05-2017, 07:32 PM | #18 | ||
pm sent pundit
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time. Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies http://www.fordforums.com.au/showthread.php?t=11447916 |
05-06-2017, 06:03 PM | #19 | ||
My unit has arrived so no longer required, bit strange the offers made did not respond to PM's
09-06-2017, 09:19 AM | #20 | ||
OK, have used the forscan tool and reset the radio code successfully. Looks like you can do keys, change radio units etc.
09-06-2017, 01:28 PM | #21 | ||
Fred which adapter did you buy, I have 2 here & both work with torque but refuse to work with forscan.
Hoping 3rd time's the charm. |
09-06-2017, 02:03 PM | #22 | ||
09-06-2017, 02:35 PM | #23 | ||
Thanks Fred.
