Old 27-05-2011, 01:42 PM   #91
Martyvan
Martyvan's Avatar
Default Re: MORE HORSEPOWER, BETTER MILAGE, HIGHER TOP SPEED!! (well...sort of)
Aero undertray, wouldnt make a rats **** of difference around at slow speeds. if you were using it at 80kph speeds for extended periods of time, say commuting from gold coast to brisbane or geelong to melb etc, it would clean up the airflow under the car, and there would be neater airflow out the back, which would reduce drag, and therefore increase economy. realistically, unless you had a full undertray, your benefits would be VERY minimal maybe 2-4%. With a full undertray, and a rear spoiler designed for aero benefit, and not for looks, you could potentially save 10%.
<pops 2c into the tin>
Martyvan is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 11:43 PM   #92
paulo7
paulo7's Avatar
Hi guys,
well, I've had no luck finding out whether to put an undertray on or not from overseas Ford guys, but...
I have found some interesting reading about the subject from a someone right here in oz.
check it out:
http://www.autospeed.com/cms/A_2159/article.html
http://www.autospeed.com/cms/A_2160/...popularArticle
http://autospeed.com.au/cms/title_Mo...6/article.html
And if you have a fish around there are other interesting articles as well
cheers
paulo7 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 08:36 PM   #93
btf-ford
Has anyone analysed the fuel savings and effect of the Cyclone Air intake generators. They are designed to create a swirl in the air intake which they claim helps atomise the fuel and products a better more efficient burn/ignition.
There is a couple of designs on the market.
http://www.ebay.com.au/itm/Air-Intak...item3f02e61893
and
http://www.ebay.com.au/itm/Superchar...item3367656df6
btf-ford is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2011, 08:25 AM   #94
craiggstephens
and
Complete waste of money. These have been around for a few years and all they accomplish is extracting funds from your wallet.
craiggstephens is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2011, 02:06 PM   #95
Caydus
Caydus's Avatar
If they aren't powered, then won't they just serve as a restriction?
Caydus is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2011, 01:48 AM   #96
btf-ford
My thoughts also unless the cyclonic effect out perfoms the loss as does a jet engine
Old 04-06-2011, 02:20 AM   #97
Dave R
Member
Technical Contributor: For members who share their technical expertise. - Issue reason: Valued contributor especially in the FG threads. Offers help and information to all. Posts are always in a positive manner.
Originally Posted by geelong festy
It makes horsepower, it saves gas and adds top speed.....and is a genuine ford part. What is it? answer! Aerodynamic undertray from a Ford WS/WT Fiesta Econectic. Ford claims it's aerodynamically proven and slices 2 litres per 100k (Ford claim),and.....(drum roll please) it cost less than $130 new retail!! It's plastic and ways under a couple of kilos, has a heat shield and bolts straight in (fits all models apparently so the parts guy said) with original fasteners. Purchased this week from Gorell Ford. You don't need to know where to look....you just have to start looking! (for cheap power that is!)
So basically, you gain 100rwkw (give or take, probably give) by installing the sweet undertray, then constantly enjoy all of the newfound power, which in turn ruins your economy when you are repeatedly thundering down the highway blowing away alllll the Corollas (in addition to performing top speed runs, as is the norm when driving a Fiesta), only to later realise that you did not in fact gain 100rwkw and your economy has gone to hell.
Paradox.
Dave R is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2011, 08:06 PM   #98
greenfoam
Gees you guys are an argumentative bunch , I haven't got the tray yet. I did have a quick look at the parts list to see any difference between the WS Petrol and Econetic and from that quick look it seems the front tray is the same on both cars. So the longer one might be a WT econetic part or it's something up the rear of the car that is different. I'm still going to look under a econetic next time I see one in the yard to find these aero parts
greenfoam is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2011, 08:12 PM   #99
greenfoam
btf-ford, devices that disturb the air in an intake can work on carby fuelled cars just by stopping the fuel dropping out but has never been proven to do anything injected cars. But under trays do work and always have worked, it's just matter of how much. There are entire sites/forums for guys dedicated to modifying their cars in this way and when they go to extremes with aero mods they get crazy fuel economy in old Honda Civics that make econetics look like 6 litre v8s
Old 10-06-2011, 07:30 PM   #100
mik
mik's Avatar
under tray would`nt do much for aero at low speeds you would`nt think, engine temp i don`t know, highway runs it sounds feasible, one of the econetic features to help make more use of the Aero aids apparently is its also slightly lower than other models, i have been studying the econetic model recently, and i have seen reviews with fuel consumption as low as 3,4 lp 100k which is bloody good.
will be interesting to see how the tray on the standrd model goes.
