Old 04-04-2017, 03:00 PM   #31
Mercury Bullet
Default Re: boss 260/290 into another car
Great choice!
I too had a 3v in a BA xt. Loved it and never had a problem.
Torque on tap down low but it's completely out of breath at 5000.
They originally went into the F-150 so they are most definitely a truck motor but purrrfect for a cat.
Well done mate, I reckon you've just built the best jag conversion in the land.
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2017, 03:27 PM   #32
deano2469
deano2469's Avatar
Originally Posted by Mercury Bullet View Post
Great choice!
Yeah cheers man. I will be a lot happier once she runs. I've installed a manual pedal set up already and will be looking out for a 5 speed. It was a v12 so has an lsd already and had pedders lowered coils and shocks on it. It has an injected lpg set up on too so might be able to daily drive it... early days but positive so far...
Sent from my HTC_0PJA10 using Tapatalk
deano2469 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 07:07 PM   #33
KBC
Good luck on the project mate, I too had haters when I said I was going to put a 5.4 DOHC boss into my cortina. It goes like stink.
As for parts hit the net and look in the states, plenty of parts from spark plugs to after market plug and play ecus. There are also plenty of performance camshafts available for the SOHC's over there to.
FGX XR8 auto 402rwkw- The new daily
NC Fairlane 5.0 STD
TC Cortina 5.4 Quad cam Boss 260
XD Fairmont 5.8
XB GS Coupe, no engine, future project
VG Transit, AU 5.0
TC Cortina ute, finish 1 day
I need to find a hobby
KBC is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 07:27 PM   #34
deano2469
deano2469's Avatar
Thanks man, yeah USA is the go. I found an engineer near me with a mechanic who can do the harness, also the lpg set up, I can't wait to get it all going now, bugger the haters, I had a boss 260 in a 59 third but had to sell due to finances...this time I will get it going.
Old 11-04-2017, 07:36 PM   #35
tweeked
N/A all the way
tweeked's Avatar
Love this for a swap, actually better for this sort of car than the quad cam. Would keep away from the t5, the tr 3650 is mor suitable as far as 5 speeds
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 07:44 PM   #36
deano2469
deano2469's Avatar
Oh ok, I will have a look, any ideas on what they came in, I'm not really on it as far as modern Ford stuff.
Old 26-04-2017, 06:14 PM   #37
deano2469
deano2469's Avatar
Hi again guys, I got my new sump with pan at rear off a crown Vic. Dipstick on crown Vic goes through block not into sump itself. There is a plug in it though. Does anyone know if it's a snap bolt? I assume it is and will drill and easy out if I get no other option. Also, the plastic sensor that plugs into the side, is that really necessary? Is it just for level warning?. Any clues appreciated. Dean
Old 27-04-2017, 06:13 AM   #38
KBC
The plastic sensor, is that in the crown vic sump? If not which one and where abouts mate?
The dipstick hole im not so sure but I will be finding out in a couple of months when I too will have to place a crown vic sump onto a 5.4 but a DOHC.
The early engines were just a ball bearing pressed into the hole.
NC Fairlane 5.0 STD
XD Fairmont 5.8
VG Transit, AU 5.0
Old 27-04-2017, 08:22 AM   #39
deano2469
deano2469's Avatar
Hi man, the plastic screw in sensor is in the original sump from Barra 3v 5.4. It screws into the side of the deepest part. The ball bearing thing might be right, I've noticed the crown Vic dipstick tube is smooth with an o ring on it so threaded seams unlikely. Cheers
Old 27-04-2017, 10:18 AM   #40
deano2469
deano2469's Avatar
Well there you go, found plug to be alloy tapered affair...with sump off, rolled engine on side and with air chisel lightly hit it till it fell out, put stock tube in for now, might be able to bend it a bit to suit, won't know till exhaust etc....
Old 27-04-2017, 03:41 PM   #41
creative
I am Batman
creative's Avatar
Originally Posted by blue sleeper View Post
"mkiv supra...." Wait what? Why would you put a worse engine into a Supra? A Coyote I could understand but a boss 260/290, that's like putting a 1UZ into a Boss 260 XR8......
why not? Simply because I have a 500hp supercharged V8 engine ( you do know its not a stock 260 dont you?) sat in the garage doing nothing and I like supra's having had one in the uk.
I also like to do things differently and am not a purist at all. Rip out the asthmatic N/A 2jz and drop in what I have.
Rebuilt Boss260 with #Kellogs 1500hp forged and balanced crank#Manley forged flattop pistons with a 9.5/1cr#4340 forged h-beam rods with arp bolts#Clevit performance rod and main bearings#full ARP headstud kit#total seal rings#Mantic twin plate development clutch and lightened flywheel#Mellings uprated oil pump#Mainforce Performance Supercharger kit#AU motorsport 345mm big brake kit.
Now producing 369.7rwkw/496rwhp@6000 and 515ft/lb torque @ 11 psi.
Now sat on an engine stand going nowhere
creative is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2017, 03:15 AM   #42
KBC
No dramas, it must be a 3v thing. All the 4v's I've got don't have a sensor in the sump.
I will have to look at the 4v going into this ftruck to see if the block has the
dipstick bung for the rear mount sump. If not I'll cut the dipstick section from the front sump and weld it into the rear sump.
NC Fairlane 5.0 STD
XD Fairmont 5.8
VG Transit, AU 5.0
Old 28-04-2017, 09:52 AM   #43
Elks
Elks's Avatar
3V is great engine. Minor issues aside.
I still wonder if it's actually going to fit into the engine bay. Jag engines bays are long but narrow. Not trying to be hater, just interested, I hope you can make it work.
If all else fails, there is always the Barra Turbo option. I think that's already been done. It won't sound as good as a 5.4, but it would certainly be fun.
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2017, 10:21 AM   #44
deano2469
deano2469's Avatar
Hi man, it will fit, no bonnet mods either, I have a crown Vic rear sump on it now, and gearbox on the way...once here I can make mounts...so 99% in. Will post updates, intake may or may not fit as height may be able to go down another inch or so, apparently an extra inch is always good......sorry.
Old 01-05-2017, 11:22 AM   #45
Elks
Elks's Avatar
Man you don't muck around. Well done. I had a 5.4 SOHC motor in a BA ute, it was awesome. You won't be disappointed.
Old 09-05-2017, 02:11 PM   #46
deano2469
deano2469's Avatar
Hey guys, I have a problem. I bought a tremec t5 box from BA XR8. Issue is that starter motor sticks to side of bell housing. It's really wide with solenoid sticking out. Is there an option of a smaller unit or a starter with solenoid on top 90° to where it is now? It looks like it will hit chassis rail by an inch or so...any ideas appreciated.
Old 09-05-2017, 02:14 PM   #47
deano2469
deano2469's Avatar
An idea of what I'm on about...
Old 09-05-2017, 10:10 PM   #48
LukaPuka
Gen Y Falcon nut
LukaPuka's Avatar
This thread has me very interested... I did not think a modular would fit into a jag, i have a boss 260 sitting around and a daimler double six with no engine in it. Great job!!
BA XR8, Boss 315, T56, Herrod Cams, BPR CAI, X-Force head to tail,
LukaPuka is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2017, 01:13 AM   #49
KBC
An idea of what I'm on about...image
This is one of the reasons I never used the original BA manual in my cortina. I would have had to modify the chassis to much for rego.
I ended up getting a C4 conversion bellhousing from the states, it uses a mustang starter on the driver side now. It points towards the front like a early windsor or clevo.
I've never seen an alternative one for these, mind you I never looked either. If I find something that may work for you Ill sing out mate.
NC Fairlane 5.0 STD
XD Fairmont 5.8
VG Transit, AU 5.0
Old 10-05-2017, 07:24 AM   #50
Bonn
Bonn's Avatar
As you'd know, the Boss plenum will stand higher than the bonnet.
FG Falcon Ute
Daily: E-Gas 4.0 I6, 3 seat 1 tonner, 2300kg Tow Pack, Carryboy, XR6 rims.
6 Stacker, Sat Nav, Reversing Camera, Sunnie Holder, XR dash & St Wheel - thanks Mr FPV!
Jaguar XJ-S: Eaton S/C, I/Cooler, Haltech, DB7 rims, 1:15 Wakefield.
Jaguar XJ6 Wife's daily :2006 Quartz Metallic, FORD Duratec 3.0 V6, ZF 6sp
Previous relationships: FG GT, FG XR8 (+BA XT 5.4, BA AU, EF, EB, EA, EA & XF work cars)
Jags XJ12 & XJ6, BMW E39 Wagon, BMW F11 M-Sport wagon, 20 of GMH FC-HQ
Bonn is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2017, 08:39 AM   #51
deano2469
deano2469's Avatar
Yeah, there is another problem too, the stick will end up too far back, about 100 to 200 mm somewhere. Might have to look for a shorter box as well. I was trying to find a different bell housing and rear extension housing that's shorter...might be easier to change box, really don't want to go back to auto...thanks for any info guys.
Old 10-05-2017, 10:41 AM   #52
GasoLane
Former BTIKD
GasoLane's Avatar
One of my old XJ12's was converted to a manual.
However this was using the original V12 along with a Dellows bellhousing and Supra 5spd box.
Old 10-05-2017, 10:46 AM   #53
deano2469
deano2469's Avatar
Hi man, yeah I've seen that kit, I've found that the box I have is a tr3650, if I can change bell housing to mustang and rear gearstick housing to mustang all might be easier...just hoping I can get a smaller starter at moment....the rest might be fixable, with a hammer.haha.
Old 12-05-2017, 03:23 PM   #54
deano2469
deano2469's Avatar
Well, I put box behind engine and sat it in place, fits almost too good. Need to make a bracket to move stick a few inches forward easy ish , starter at its widest point sits just above chassis rail so hammer time into passenger foot well. Just need a bigger hole in tunnel to allow shifter to come up an inch of so. And you won't believe the stock Ford gearbox bracket looks like it will fit perfectly...custom exhaust manifold will be a must , need pipes to drop in middle like Chev rams horns....
Old 17-05-2017, 05:45 PM   #55
deano2469
deano2469's Avatar
Box with mount hard up against chassis. Bracket made to move stick forward...I'll get used to it for now...
Old 17-05-2017, 06:39 PM   #56
GasoLane
Former BTIKD
GasoLane's Avatar
The sight of that wiring brings back memories ......................not necessarily good ones
Old 17-05-2017, 07:26 PM   #57
deano2469
deano2469's Avatar
Oh yeah, that's another story, mostly ok now, replaced most as was butchered with scotch locks everywhere prior...
Old 17-05-2017, 07:39 PM   #58
GasoLane
Former BTIKD
GasoLane's Avatar
Just remember to replace everything with Lucas written on it
6 users like this post:
Old 25-06-2017, 04:03 PM   #59
deano2469
deano2469's Avatar
Well, weeks go by, can't do much as injured but got ****s with bodgey selector mod so made a better one, even fits under console and through original hole where auto selector went. Next to cut tunnel to fit starter motor ...it's gonna be a drama...engine mounts arrived. The engine side, gotta fabricate the bottoms off cross member. Got pics if anyone interested. Will keep posting as I go anyway.
7 users like this post:
Old 11-03-2018, 02:38 PM   #60
Fairlane 500
Fairlane 500's Avatar
Any updates Dean?
Fairlane 500 is offline   Reply With Quote Multi-Quote with this Post
