03-05-2018, 09:49 PM | #1 | ||
Hi all
Last weekend my poor lil nephew was sick when he was staying over at my house for the weekend... I have tried many cleaners but the smell won't go... My question is what does everyone recommend? Was also considering buying a carpet shampooer from Godfreys or getting a contractor in. What would everyone do?
2005 BAII Falcon XR6T - Velocity Blue Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim. Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder. [B]2000 AU2 Fairmont Wagon - Congo Green Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps. |
04-05-2018, 12:45 AM | #2 | ||
Google vomit & carpet and read away. I have always flushed the stain with water, pad it dry, flush again, pad it dry, over & over. Never scrub, never use hot water. Good luck
04-05-2018, 08:48 AM | #3 | ||
PURSUIT 250
Just get a bloke in. Should cost less than $200 and it will be spot on.
04-05-2018, 08:52 AM | #4 | ||
i think if its gone through to the underlay, you will probably never get rid of the stench.
a good steam clean may get it out, but may also just mask it till the top dries.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
04-05-2018, 01:17 PM | #5 | ||
*barks incessantly
White vinegar and water in a spray bottle can do wonders to neutralise odor. When I bought my previous BA it smelled really bad inside but I got rid of all the bad smells within a few days with just this mixture. (50/50 water-to-vinegar mix)
04-05-2018, 02:18 PM | #6 | ||
Seasoned One
just had my daughters boyfriend do a sprinkler spew in the back of my g6et, cleaned it all, put bi carb of soda on carpet (after dry) and leave it a day or two then vacuum. also, put a take away container or similar down in area full of bi carb, will absorb smell
AC Cobra 351w G6E Turbo FG mk 2 2007 Territory 1967 xr Falcon ute 289 1966 xr Fairmont 289 |
04-05-2018, 02:23 PM | #7 | ||
I'd suggest hiring a carpet cleaner from the likes of Kennards or Woolies. Cost about $70- for a full day (probably closer to $100- by the time you buy shampoo etc) & you can do the whole house while you're at it. Very easy to use & give a good result.
04-05-2018, 03:38 PM | #8 | ||
There is a product that car detailing company Bowden's make called Pong go. I have used it on a spot that one of the dogs had pee'd on, applying after cleaning as described previously and have had good results with it. About $25 for a 750ml spray bottle from Repco & the like.
04-05-2018, 04:29 PM | #9 | ||
Use Nil Odour. You can buy it at Woollies or Coles. You will only need to use a couple of drops. As the Nil Odour has a strong smell.
Thread Tools | |
Display Modes | |
