Old 20-01-2017, 08:17 PM   #1
Toby R
Default Suspension type AU 2000 Futura
Hi guys,
I was just wondering if anyone knew if the 2000 model AU futura had IRS? I have clunking from the rear right side. From what i have read the IRS would not be in this model but its hard to see as the car has been lowered and attempting to jack up from chasis does not lift the tyre. I am leaning towards the Watts Link live axle hopefully and also hopefully does not need the mounts.
Any thoughts would be appreciated.
Regards Toby.
Toby R is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2017, 09:56 PM   #2
BuuBox
Default Re: Suspension type AU 2000 Futura
It was optional on every sedan, but chances are it'll have the solid axle.
If you really can't stick your head under there, could always check the VIN on http://www.etis.ford.com/vehicleRegSelector.do
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2017, 10:04 PM   #3
Toby R
Hi,
It has been lowered and all i can see is the petrol tank, i checked the site you linked entered vin number but i dont know how to check suspension from there.
Primary Features
Build Date: 24.02.2000
Vehicle Line: Falcon
Body Style: 4 Door Saloon
Version: Futura
Engine: 4.0L SOHC EFI (MP) ACS
Transmission: 4 Speed Auto - Floor (M95LE)
Drive: RHD RWD
Emission: Australian Design Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"AUS"
Paint: Liquid Silver
Minor Features
Broad Meadows (Australia)
With Driver Air Bag
Rear Axle Less Limited Slip Diff
4 Wheel Anti-Lock Braking System
For Unleaded Fuel
With Speed Control
Regards Toby.
Old 21-01-2017, 05:28 PM   #4
GasoLane
Former BTIKD
GasoLane's Avatar
It shouldn't be that hard, look under (or put your hand up) just in front or behind the rear wheels.
If it's got leaf springs it's not IRS.
Old 21-01-2017, 05:34 PM   #5
Toby R
Ah ok it definitely does not have leaf springs, but there is coil suspension for IRS and non IRS, so i thought it didnt need leaf suspension......
Old 21-01-2017, 05:58 PM   #6
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Lol, No Falcon sedans have had leaf springs since XD
But I do agree it can't be that hard to tell. It's got to be easier to have a look under their than try and diagnose it via a forum.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2017, 06:07 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
Oops, I stand corrected
Old 21-01-2017, 07:15 PM   #8
Toby R
Sorry guys not trying to be a problem, but i can see what appears to be cv joints coming to the wheels, now would this indicate IRS since its not a solid axle?
I am new to fixing suspension and try to learn quickly, i have done a lot of work on a Holden Jackaroo including pulling injecters out and installing new ones, so good information and good guides i try and do the work myself. All i ask is a little patience.
Old 21-01-2017, 07:26 PM   #9
Raptor
Raptor's Avatar
CV joints = IRS
Click through the rear suspension pics here; http://www.superpro.com.au/tradeview...&cid=999500216
It shows diagrams of;
  • front and rear view of a live (solid) axle AU Falcon
  • front and rear view of a IRS AU Falcon
Old 21-01-2017, 07:35 PM   #10
roddy1960
roddy1960's Avatar
G'day ..Unless modified it should be a Watts multi link IRS system on the rear..
Most regard it superior to the BA suspension..
... If you have a good AU , you have a very good Falcon indeed..
Cheers Rod..
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2017, 07:47 PM   #11
Raptor
Raptor's Avatar
No Rod, the one with the watts linkage and the trailing arms is the live axle.
Though the option was the very good IRS that is in many ways superior to the Control Blade IRS introduced in the BA's.
Old 21-01-2017, 09:57 PM   #12
Toby R
Next question, if from what i have read the mounts can go common problem, does anyone know where to source replacements from, i rang bursons and got quoted 943 for a pair, Bursons are a Superpro distributor. I have a knocking in rear passenger side when bumpy, but tends to get better with distance, so i am hoping its just shocks, but throwing out the question for cheap mounts just in case.
Old 22-01-2017, 01:02 PM   #13
roddy1960
roddy1960's Avatar
G'day..Sorry about that...My 2001 Series two Futura is Watts Multilink ..live axle....You are correct...I never really studied the system before..It's still totally original , still works perfect... IRS shows here in the link below as is mentioned for some models XR6,XR8 I expect the mighty T's too without checking..Interesting read via this feature actually... http://australiancar.reviews/reviews...Falcon&gen=237 Cheers Rod...
