30-07-2012, 02:04 AM | #1 | ||
Hey guys i just got myself a cheap NL and today the indicators stopped working.The hazards word and they flash when the car is locked and unlocked.
Any idea where to start? |
30-07-2012, 05:02 PM | #2 | ||
Just to confuse things,they are now working
30-07-2012, 10:32 PM | #3 | ||
check the harness connector on the colum. i have had one come loose there. i also have had the stalk pack it in too
I have cars that is all |
30-07-2012, 11:28 PM | #4 | ||
Hi. Another thing is the contacts in the hazard switch, If it happens again just work the hazard switch a few times which cleans the muck off the switch contacts. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
30-07-2012, 11:34 PM | #5 | ||
Cocoloko
smart lock flash is seperate from the indicator flasher system.
As above, common problem is lack or nill use of hazzard switch, since the contacts in them dont get used, the eletrical current needs to pass through via the hazzard switch prior to it reaching the stalk contacts. Or if the flasher unit has been in there since 98 high chances it highly worn and on its way out
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build. 2010 Territory: family bus. 79 P7 LTD 351. |
02-08-2012, 03:07 AM | #6 | ||
Thanks guys.
