Old 08-03-2019, 01:24 PM   #1
Fgrocks
Default Hard starting when engine is warm
If i go out in the morning and start my 95 ef fairmont 6 it starts sweet as but when i leave it for half an hour or longer it winds over for about 4-5 seconds before finally starting,if i leave it until it is completly cooled down it starts fine.I have changed the fuel filter/spark plugs and leads/coil/cleaned the throttle body/cleaned out the ISC/checked the tightness of the battery cables and am wondering if it may have something to do with the fuel system but not sure where to start,anyone else had this happen?.
Fgrocks is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2019, 01:42 PM   #2
Peter B - CV8
Default Re: Hard starting when engine is warm
A faulty "evaporative purge canister" can cause those symptoms + longer to start after immediately filling up with fuel (often with a small cough of black smoke from unburnt fuel).
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2019, 01:59 PM   #3
Fgrocks
Where abouts is this located?
Old 08-03-2019, 02:46 PM   #4
A test would be to manually activate the fuel pump before attempting a hot start. Either separate the cover of the relay and press down the contact wafer for ten seconds, or key on/off 2-3 times with a delay of about ten seconds between cycles.
If there's no change you've reduced the chance of it being the fuel system at fault.
Old 08-03-2019, 03:06 PM   #5
Peter B - CV8
Not sure on the EF's - but usually at the back of the engine (between engine/firewall area). Google search evaporative "fuel purge solenoid" & you might get a few pics of engine bay location.
Old 08-03-2019, 03:09 PM   #6
burnz
VFII SS UTE
burnz's Avatar
fuel regulator diaphragm failure, the diaphragm leaks into the vacuum hose causes minor flooding..
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2019, 01:46 PM   #7
Fgrocks
ok,is it an easy straight forward change over,do i depressurise the fuel system before changing.
