Old 24-04-2016, 12:51 AM   #31
NZ XR6
Originally Posted by ope126 View Post
I was using Total Oil when I had my EcoBoost and got it locally in Brisbane from Onshore Oils; http://www.onshoreoils.com.au/
For me the issue was (at the time) they could not source 1L bottles so could only get the 5L and needed more for the oil change. And I believe the EcoBoost needed 5.4L on a change and now my TDCi needs 5.5L on an oil change.
That is the only real reason I went with Penrite HPR5 which is readily available in a 6L bottle; http://www.penriteoil.com.au/product...&id_products=1
The first time I did an oil change with the Total, I topped it up with some leftover oil - it only needed about 300ml. But I bought a 1 litre bottle last time.
The TBN and sulphated ash levels of HPR5 aren't that much higher than the C3 specs, probably because it's a full synthetic. It also looks like a perfectly good oil for my motorbikes!
Old 24-04-2016, 02:02 AM   #32
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Ford oil spec M2C913-D
Originally Posted by bundybear75 View Post
I plan on using these.
http://www.sydneyfilters.com.au/genu...-mini-peugeot/
I've been buying various filters from these guys for years with no issues.
Interesting when I changed my filter for the first time it had a mann filter. I've always liked the quality of it over fords own. I might chase a few down. Thanks for the reminder.
Old 24-04-2016, 01:19 PM   #33
ope126
ope126's Avatar
cobrin, that is a fuel filter, not an oil filter.
But good to see that the (Ford) FoMoCo filters are being made by Mann Filter (Made in Germany).
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2016, 02:23 PM   #34
bundybear75
bundybear75's Avatar
Here is the Mann filters I got from Sydney Filters, I also got some Mann air cleaners and some Cooper fuel filters. I plan on changing the fuel filter at 30,000 instead of the recommended 60,000km interval. I've been through the "replace common rail fuel pump" game before on another vehicle.....Not so much fun.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2016, 09:11 PM   #35
cobrin
Challenge Accepted!
cobrin's Avatar
I know, I thought my fingers had typed 'fuel' but my brain didn't send the signal ;)
Bundy yeah I figured I stagger a few items myself:
Trans. fluid every 30K, only the pan.
Fuel filter every 45K.
Coolant, Brakes and Steering as required per scheduled or I'm doing work on them.
Multi V belt 100K unless signs of abnormality.
Coopers a great filters imo, they have good anti-drainback-valves in the spin on kind and are quality.
Old 23-08-2016, 06:20 PM   #36
rondeo
Revisiting the oil saga, there's a fairly recent pdf by Penrite:
https://www.penriteoil.com.au/tech_p...MAY%202016.pdf
which has on page 3 an interesting statement that some dpfs do not require a low saps oil, since they are 'high flow types'.
In any case, it seems from the talkford forum most problems involve soot clogging due to failed afterburners and other issues.
On that basis oils on the shelf labelled 'unsuitable for DPF' would be better labelled 'unsuitable for most DPFs'? etc etc etc
Old 24-08-2016, 02:38 AM   #37
cobrin
Challenge Accepted!
cobrin's Avatar
Nargh it's better to air on the side of safety and say straight up 'unsuitable for DPF's' than get the already near uninformed suing for damages kind of scenario.
I find $80-110 for 10L of oil is acceptable for 15K km services personally. I went a bit crazy the last couple of years and got far to many drums so I'm a bit too far ahead in that respect.
Old 24-08-2016, 02:38 PM   #38
rondeo
I confess to having 30 l in the shed. Nulon C3.
Old 24-08-2016, 04:56 PM   #39
bundybear75
I brought 2 x 10L of Nulon when they were on special a few months ago, Already on to the second bottle. Eagerly waiting the next 20% off sale....
2002 BMW R1150GS
Old 25-08-2016, 12:52 AM   #40
NZ XR6
My understanding is that the Mondeo DPF is not high flow.
I still do not understand why Ford does not recommend a "low SAPS" oil. As far as I'm aware, every other car manufacturer requires a C2 or C3 spec oil if a DPF is fitted.
Sent from somewhere using Tapatalk
Old 25-08-2016, 02:11 PM   #41
rondeo
So maybe 'high flow' refers to 'flow through monoliths' as opposed to 'wall flow' mentioned here:
https://www.dieselnet.com/tech/dpf_wall-flow.php
Old 25-08-2016, 07:50 PM   #42
NZ XR6
Could be. Ash buildup would have less effect on flow through.
But how does the filter work unless there is wall flow?
Old 26-08-2016, 01:08 AM   #43
cobrin
Challenge Accepted!
cobrin's Avatar
ha ha ha same here though I'm out of engine oil filters and fuel filters now, I must get some and I'm due a charcoal cabin filter now I think of it.
Old 26-08-2016, 10:18 AM   #44
rondeo
With less effectiveness:
http://www.hussgroup.com/huss-umwelt...filtration.php
I'm still in the dark whether 'high flow' and 'flow through' are equivalent, and why Ford don't specify low SAPS. All a bit academic maybe, my cars seem to use very little oil, don't need topping up in 15000km anyway.
Maybe there's a high flow wall flow filter.
Old 26-08-2016, 08:12 PM   #45
NZ XR6
I think you're right. There's some info on the Peugeot website that says that the DPF is the wall flow type.
Old 27-08-2016, 08:48 AM   #46
NZ XR6
Came across this from Ford:
"Coated Diesel Particulate Filter (cDPF): Ford's cDPF system traps carbon deposits as they exit from the combustion system, preventing their release into the atmosphere.
"Under favourable conditions the system then cleans itself with a controlled 'burn-off' process, thus providing a self-contained clean air system without the need for service maintenance.
"This system contains a ceramic filter body of around 4 litres volume mounted behind the exhaust manifold plus a special regeneration support unit on the engine's intake manifold. Together these components enable the filter system to regenerate in any possible drive condition automatically without requesting any input from the driver and without compromising driveability noticeably during regeneration.
The advantages of the system are:
* Additive systems have an additional additive tank that primes the fuel tank with the additive (a metallic catalyst) at every refuelling. On the Ford cDPF the additive is embedded in the filter washcoat, hence no additional complex priming system is required and no refilling of the tank.
* Long life – a ‘normal’ additive DPF tank needs refilling after approx 60k km, whereas the new Ford cDPF has been developed to last at least 200.000km."
Old 24-04-2017, 03:13 PM   #47
stefcio007
I use Penrite, this one. Recommended by their tool and meets the spec apparently.
My 2c.
Old 24-04-2017, 03:26 PM   #48
bundybear75
My 2c.
Is it suitable for DPF's?
Penrite also recommend HPR Diesel 5 but it is not suitable for DPF's.
2002 BMW R1150GS
Old 24-04-2017, 03:33 PM   #49
stefcio007
I checked soot levels once a month. Last time I checked it was about 60%, so normal. Only had dealer services before I bought it.
I'll monitor levels and report back.
It's confusing since some oils only have the spec written, some have for vehicles with DPF fitter, and some say NOT suitable for vehicles with DPF.
(I'm coming from a petrol V6 VW Golf, and always used Penrite no problems so I trust them.)
Old 24-04-2017, 04:53 PM   #50
cobrin
Challenge Accepted!
cobrin's Avatar
I thought it were Enviro+ that were suitable, I've been cautious with penrite because of they conflicting labels, thus have settled on Nulon.
Undecided replacement...
Old 24-04-2017, 05:17 PM   #51
bundybear75
Same here - I've been buying it at the 20% off sales from Supercheap.
Had my Land Cruiser serviced last week - It has DPF's (2) and requires a 0W-30 oil. My mechanic only uses Penrite and had to special order me some Penrite Enviro C2 to suit. Very thin oil, not sure how its going to perform loaded on a hot summers day........
2002 BMW R1150GS
Old 24-04-2017, 05:21 PM   #52
stefcio007
Might give the C2 a try then next change. Would be nicer if it came in 6L bottles though.
Old 24-04-2017, 08:27 PM   #53
cobrin
Challenge Accepted!
cobrin's Avatar
I hear ya, that was my dilemma also, so decided the way forward was 10L drums, Penrite was much more expensive and that solidified Nulon.
Old 25-04-2017, 12:35 AM   #54
cobrin
Challenge Accepted!
cobrin's Avatar
you might be interested in Nulons 0W30 diesel dpf stuff. Just realised it's a new addition (to me that is).
Old 25-04-2017, 02:33 AM   #55
NZ XR6
The Peugeot oil specification for the Mondeo engines is a C2.
Having looked into the ACEA oil specs, I've decided to use a C3 oil as it provides more engine protection than the C2. The downside is it's slightly less fuel efficient.
I can highly recommend the Fuchs XTL oils. The parts guy where they sell Fuchs sold me Pro Flex, but I should have bought the C3.
Fuchs even make a low SAPS Ford oil for diesel engines!
Sent from my SM-G9208 using Tapatalk
Old 25-04-2017, 01:22 PM   #56
stefcio007
C4 is available too, why not go for that?
Old 25-04-2017, 07:31 PM   #57
NZ XR6
C4 is low SAPS, C2 is mid SAPS.
Sent from my iPad using Tapatalk Pro
Old 25-04-2017, 07:33 PM   #58
cobrin
Challenge Accepted!
cobrin's Avatar
C5 back to mid saps lol
Old 25-04-2017, 08:01 PM   #59
stefcio007
FoMoCo is short for Ford Motor Company, but it also has MANN FILTER printed on it
Old 26-04-2017, 07:26 PM   #60
NZ XR6
I've noticed there is a C5 but haven't looked at the spec yet.
