Old 23-04-2019, 12:37 PM   #1
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Default Probably about due to replace or service radiator
Have a 13 year old Ford Territory and as part of the preventative maintenance schedule to try and see the old bus make another 220,000km before any major failures, I am considering replacing the radiator. Are there any subject matter experts on here than can advise as to brands and potential pitfalls etc. I don't just want to buy the cheapest crud available etc. I already have the PWR trans cooler kit on the ZF.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 01:10 PM   #2
71cop
Default Re: Probably about due to replace or service radiator
What is wrong with the radiator ?
71cop is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 04:39 PM   #3
mcnews
Trev
mcnews's Avatar
I believe very little at the moment, the temperature gauge site just below half most of the time. I am not in the city, thus preventative maintenance before getting stuck somewhere or ending up cooking an engine by accident when/if ****s itself, seems wise to replace the radiator as part of a preventative maintenance program.
Trev
Old 23-04-2019, 04:45 PM   #4
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
New genuine ford, Heavy Duty with 26mm core.
https://www.ebay.com.au/itm/GENUINE-...75.c1#viTabs_0
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 05:22 PM   #5
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Amen to arronm.
Stick to genuine & fit the V8 one (thicker).
If you're onto preventative, suss out the water pump.
Again - genuine with new pulley too.
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 05:29 PM   #6
fofo
I got quoted 130 for just a flush. But decided to go for new radiator and flush for 370. Get a new radiator if its older than 7 years.
fofo is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 07:37 PM   #7
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
13 years...buy a lotto ticket on the way home as well!
They are cheap crap these days, 5 years max I reckon.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 07:53 PM   #8
Itsme
Experienced Member
Itsme's Avatar
I do believe if you maintain your coolant correctly your radiator should be ok, I'd be more worried about a hose failing before a radiator if you thinking of age related problems.
Old 23-04-2019, 08:43 PM   #9
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Radiator went on my magna last year. It was the original one from 1992 though so I reckon it lasted long enough.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2019, 08:00 PM   #10
Jastel
Hoses will do 400000kms...radiators are a gamble after 200000kms...you can do the maths with how many years that is for you.
You cant compare an old copper radiator to these aluminium/plastic things.
They were not a big problem back in the E series Falcons either.
Old 24-04-2019, 08:32 PM   #11
hayseed
^^^^^^^What He said..^^^^^^
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2019, 10:46 AM   #12
vbvbvb088
vbvbvb088
Magna's very much underrated....
vbvbvb088 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2019, 08:22 PM   #13
mcnews
Trev
mcnews's Avatar
Thanks guys, some great advice there.
Trev
