Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Bendix
Bendix BENDIX – Put your foot down with confidence
Old 17-03-2019, 04:34 AM   #1
motorculture
motorculture's Avatar
Default Question: We fitted new brake pads and they squeal. Why?
Brake noise after fitting new brake pads, Bendix investigates why.
Follow Bendix Brakes on Facebook HERE.
To learn more about the Bendix Brakes range of products visit: www.bendix.com.au
Automotive social media http://motorculture.com.au or call us on 02 9418 9008
For some daily car culture check out http://zengarage.com.au/
motorculture is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2019, 05:13 PM   #2
Default Re: Question: We fitted new brake pads and they squeal. Why?
All brakes make noise (see https://www.researchgate.net/publica...E_SQUEAL_NOISE )it just usually not at a frequency you can hear. e.g. https://www.knowyourparts.com/techni...g-brake-noise/
When the friction material makes contact with the rotor, the coupling causes the brake pad and rotor to oscillate and vibrate. In engineering terms, this is called “force coupled excitation,” which means that the components are locked as a combined system that will vibrate at the system’s natural frequency’s combined modes of vibration.
The amount of excitation and the frequency generated can be influenced by variations in brake torque (or changes in the coefficient of friction) across the rotor’s face. As the components heat up, the rotor may develop hot spots that could cause the rotor to have different regions of friction that produce different levels of brake torque. This friction coupling is where most brake noise is generated.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 17-03-2019, 08:15 PM   #3
Honest Gaza
Had the brakes replaced on my GT in the last couple of weeks ...they provide great grip and stopping power but they squeal terribly when applied with light pressure only.
A Google search indicated it was common with the type of pads (DS2500).
2013 FPV GT (....well, the Wife's....after we traded in her FG XR6...after she broke our BA XR6T)
2015 Renault Megane RS265 - 2L Turbo 6Spd Manual
Honest Gaza is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2019, 08:25 PM   #4
Also see my post here: https://fordforums.com.au/showthread...t=brake+squeal
Old 18-05-2019, 08:33 PM   #5
Honest Gaza
After a couple of months of constant squealing I couldn't put up with it any more....embarrassing.
Fortunately, the mechanic I use offered to replace the pads with a softer pad and this was done this week. Silence is golden
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
