05-02-2010, 08:24 PM | #1 | ||
WOGBOY69
Hi All
i have a 72 v6 capri with a 4 speed box and reverse is left down .iam rebuilding the box back to new if i can get new sincrons and i think i can from burtons profomance in the uk but there are so many gear boxs out there i just dont want the wroung gear to arive the number on the box is .....69eg7a040a.a and its a 4 speed box all cast iron even the bellhousing.. single rail box with the likages on the outside left ,can anyone help me and tell me what box that is ...or is there a cheaper way on inproving this matter cheers wogboy |
06-02-2010, 12:05 PM | #2 | ||
WOGBOY69
so yerrr just asking like is it a type 3 box or type 5 box does anyone know .......
06-02-2010, 05:06 PM | #3 | ||
Hi Gerry,
Does it look like this: http://burtonpower.com/technical_1/type_f_gearbox.aspx It's probably a type F if it's an original Capri V6 g/box. Cheers Jamie |
06-02-2010, 06:31 PM | #4 | ||
WOGBOY69
HAY JAMIE
yes it does look like that just not with a aloy case at the back of the g/box its all cast iron and the the linkages look slightly differant not alot but preaty close to it, a f box is it i ave been looking looking every were i dont know i heard a silica g/bos or a supra box is dam good for these cars ....but then you have to change the bellhouseing.. cheers gerry |
06-02-2010, 09:20 PM | #5 | ||
I'm using a supra box(dellow bellhousing) in my v6 capri and I think its a much better cruiser for it.
06-02-2010, 11:07 PM | #6 | ||
Hi Wogboy, I am just recoing the original v6 box and I got all the bits I needed from Burtons,
Its actually the later gearbox for the v6 (type 5) that you need bits from. The front and rear seals, 4synchros, front, middle and rear bearings, and layshaft needle rollers are as per type 5. You can make up your own gaskets, and the side linkage seals can be had localy. |
07-02-2010, 11:06 AM | #7 | ||
WOGBOY69
hi caprispecail
so the box i have is a type 5 box is it ..were they dear in money side of things ... all new and did you get bearings as well .....and do they have a full gaskets kit for it cheers gerry |
07-02-2010, 11:08 AM | #8 | ||
WOGBOY69
hi tony
yes i have heard that as well for highway driving ..5th gear is just fantastic in these cars ..you realy need them unless you change dif gears and keep the four speed box..... cheers |
08-02-2010, 07:20 PM | #9 | ||
+1 for the Supra box here - it's just fantastic behind the V6.
08-02-2010, 09:02 PM | #10 | |||
I think what Caprispecial was saying is that the internal parts (bearings, synchros and seals) for a Type 5 box fit the Type F also. The Type 5 box has internal linkages, where the Type F has the external linkages - going by your description your box has external linkages so sounds like a Type F. http://burtonpower.com/technical_1/type_5_gearbox.aspx I've heard that the Supra 5 speed is a good conversion but have not driven one myself. Cheers Jamie |
08-02-2010, 11:31 PM | #11 | ||
Guys, the gearbox fitted to australian v6 capris was actualy the old zephyr v6 box type 4m I believe.
The type f box was not fitted to v6 engines only engines up to 2 litre. The type 5 box was developed to do away with the side linkages. The input shaft and mainshaft are the same for type 4m and type 5. The only difference is that the type 5 has a taller second gear ratio. So yes the bearings, front and rear seals and all 4 synchro rings are the same. I know this because when my capri was built ford installed all the type 5 gearbox internals into the original type 4m box which is the one I am now recoing. |
