Old 26-07-2019, 01:06 PM   #211
BlueBear
Shockwave
BlueBear's Avatar
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
No need to drop the subframe, just cut the bolt back and the lower arm comes out easy.
Cheers.
BlueBear is online now   Reply With Quote Multi-Quote with this Post
Old 26-07-2019, 06:41 PM   #212
NCII40
XR6T BA 2002
NCII40's Avatar
Cool Thanks for the reply
Sounds good
Will Stock BA Brakes front and back just bolt on ?
I am getting the safebrake stainless Lines
XR6T 2002 BA
284KW
Old 14-08-2019, 09:01 AM   #213
ebv8
ebv8's Avatar
for those that are thinking about territory rear brakes
here are some photos on fitment
first photo is no spacer behind the mounting bracket
you can see the rotor touches the bracket
this one is 2mm washers fitted, still no room
this is with 2 washers (4mm) and it rubs on the other side
and here you can see the stock backing plate touches all over the place
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
BA XR8 - Blueprint
Black VZ LX8 Adventra
AU Futura granny spec
Holden HX 50th Anniversary
1980 GS1000ST - Wes Cooley Rep
1986 TT250
Sea-al Supa Skua
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2019, 07:46 PM   #214
Tyre Licker
Tyre Licker's Avatar
So I think Ive got it now, Ive read this enire thread..
1 AU S1 had a master Cyl Change in late 99 to a bigger bore, this is the master required for FGT 322mm front brakes and Territory 30? rears to match the extra volume required?
2 Need lower control arms, uprights, hubs, swaybar links & brackets from
AU S2-FGX with BF brake lines and caliper bolts to match the above brake upgrade..
3 Territory brakes go on IRS rear with 3mm spacer to center the caliper and require the Territory rear back plate with custom brake line to suit?
4 Territory brakes on solid axle bolts up and also required custom brake line
How did I go?
Previous Fords
TD Cortina 250 6cyl 4 speed (stolen)
MK 2 Escort 2ltr Pinto 5 speed Celica box (written off)
XE Falcon LPG Turbo 2k stall C4 Auto (Tboned)
XF falcon Fairmont stocker (Expired)
TF Cortina 250 6cyl (parted out)
2011 Manual GS 399rwkw (sold)
2011 AWD Titanium Seduce (sold)
My Fords
1998 AU S1 V8 Fairmont Wagon Regency Red
Daily
Kenworth T604 36" bunk
Full house C15 & 18 Gears
820hp @ 1700 2600ftlb @ 1450
Tyre Licker is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2019, 09:47 PM   #215
ebv8
ebv8's Avatar
So in my case my march 99 au1 6cyl most likely has the small master cylinder and i have no issues running the big brakes, they almost pull your face off. The bigger master cylinder might give a better pedal feel but in my case its not required
The AU2/3 front brake lines will fit on BA 298 and 322 calipers but using BA lines would be best as it has a longer bent hardline at the caliper end
Rear territory calipers on a live axle can use AU lines no problem as thats what im using
CURRENT RIDES
BA XR8 - Blueprint
1986 TT250
Sea-al Supa Skua
Old 01-09-2019, 10:37 PM   #216
Xr302
How many guys on here have gone the premium brake upgrade on the front -328mm I think from memory... Would there be much benefit over the 322mm rotors? I think the 328mm are a fair bit thicker too.
Xr302 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2019, 10:42 PM   #217
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Default Definitive AU1 to AU2/AU3 brake upgrade thread
329mm. I've had them since new so I can't comment. The biggest benefit IMO would be the better looking caliper.. Having said that, they probably look worse if you don't dress the backs of the pads like so.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2019, 11:16 PM   #218
Xr302
Yeah they look good silver!
Do you know how you would tell the calipers apart between the 322 and 329?
You probably wouldn’t pick up 7mm difference unless you had both rotors next to each other.
But is there anything on the calipers to identify them by?
Old 01-09-2019, 11:38 PM   #219
superroo
You can't stop the signal
superroo's Avatar
You can identify the calipers by looking at them.
It is all to do with the cooling fins & the front face
322mm
BF 322mm caliper
28mm thick disc
329mm - AU Premiums - Also C4 corvette caliper
Distinction is in the round mounting holes in the face of the caliper
28mm thick disc
325mm - BA Premiums - C5 Corvette caliper
Flat face, cooling fins at top only, central divot
32mm thick disc
Old 02-09-2019, 12:05 AM   #220
Xr302
Thanks Superroo
They are pretty easy to identify after looking at them like that.
The au premiums never come up and every one wants so much for them.
Im going to try and find some of the ba/bf premiums, just for the thicker rotors, my Mrs warps the standard au fronts every time she drives it haha.
Old 08-11-2019, 08:47 PM   #221
Darren290
Darren290's Avatar
Thread mine!!
Has anyone put Safebrake braided lines on the AU2/3? On the rear calipers the brackets supplied with the hoses dont face in the right direction. Did anyone else have this problem and how did you get around it?
Darren290 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2019, 11:09 PM   #222
5LXHR8
5LXHR8's Avatar
What have people used for brake lines when using the territory rear calipers on an S3 IRS? Or do the factory lines fit?
Regards
5LXHR8
Daily- AU 2 Fairmont Wagon V8
Toys- T3 TS50 build 211
- 67 XR ute
5LXHR8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2020, 03:21 PM   #223
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I used Standard AUIII lines and also from BA Ute (they have the same/similar cable mount)
UK
Old 21-07-2021, 03:38 PM   #224
jimmo
Gidday fella's, I've read through the thread but can't find an answer to my question - do I need to change the brake booster/master cylinder for my particular upgrade?
I've got a S1 AU Ghia that I want to put BF turbo brakes on; stub axels, sway bar, control arms have been done. Anyone know if I need to upgrade the booster and master? Cheers..
jimmo is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 03:55 PM   #225
ebv8
ebv8's Avatar
you don't need to, your brakes will still be great but you will have to push harder on the pedal, i have done it a few times and you just have to get used to it.
however a booster will help and will help with lazy city driving when you use your big toe to brake.
so to answer your question: its good to do it but not mandatory at all.
CURRENT RIDES
BA XR8 - Blueprint
1986 TT250
Sea-al Supa Skua
Old 21-07-2021, 07:29 PM   #226
jimmo
Thanks mate, handy to know that..
Old 21-07-2021, 07:33 PM   #227
Ben
Ben's Avatar
Interesting thread what is the best front/rear I can on a AU2 with 18 inch speedlines
2001 AU2 220 XR8 - Build thread
Ben is online now   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 07:43 PM   #228
PG2
#coloradolyfe
PG2's Avatar
Are you talking about off the shelf, brembos or custom?
If off the shelf then the same as what I have.
322mm XR6T/XR8 brakes on the front (excluding BA).
328mm BFI XR6T/XR8 or Territory brakes on the rear.
NOTE: BFII went back to the standard 303mm brakes on the rear.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 21-07-2021, 08:13 PM   #229
Ben
Ben's Avatar
Cheers mate will add it to the to do list.
Old 22-07-2021, 10:09 AM   #230
Peuty
Afterburner + skids =
Peuty's Avatar
I'd love to get some solid intel on what length brake lines are needed for the rear Territory upgrade. Some say the standard lines are long enough, others say they need to be replaced with longer ones. I will be getting braided lines made up, so obviously they can be whatever length i want.
Does anyone have a definitive answer on this? Actual measurements of the line would be extremely helpful.
AUII XR8 220 - Manual + V8 = skid time
Oo\===/oO
Old 22-07-2021, 11:01 AM   #231
ebv8
ebv8's Avatar
sorry not 'definitive' but stock rears should work fine its only the fronts that can cause issues with full lock, they still work but they almost get to full extension.
CURRENT RIDES
BA XR8 - Blueprint
1986 TT250
Sea-al Supa Skua
Old 22-07-2021, 11:35 AM   #232
Peuty
Peuty's Avatar
Sorry, I should have clarified, my question relates to IRS.
Oo\===/oO
Old 22-07-2021, 01:27 PM   #233
Uncle_Ken
Uncle_Ken's Avatar
I have standard BLs on my XR 8 to Terry rears.
Old 25-07-2021, 10:48 AM   #234
Ben
Ben's Avatar
Just confirming for the 328mm rears there are no mounting brackets?
So the caliper cradle bolts straight on?
Old 25-07-2021, 11:57 AM   #235
Uncle_Ken
Uncle_Ken's Avatar
You will need a 3mm (from memory) washer to make to rotor line up. Its in this thread some wear (also in my XR8 build)
UK
Old 25-07-2021, 01:50 PM   #236
lumen8
lumen8's Avatar
Yes bolts straight on, depending on your dust shield you might (probably) have to trim the cut out bigger, since the caliper is bigger/wider than what was there before.
As mentioned use spacers to get it sitting centred over the disc. A good way to see for yourself what is required is to remove the caliper bracket from the caliper body(the body being the bit with the piston).
Then you bolt the caliper bracket on by itself with the disc on, and it becomes quite obvious where it has to live to be centred over the disc, try get the same space on each side of the bracket where its cut out to fit over the disc.
3mm is about right, rolan on ebay sells ARP brand hardened washers which i like, some generic washers arent so great, it depends, you just dont want ones that are soft and crush etc. when torqued.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2021, 02:13 PM   #237
Ben
Ben's Avatar
Thanks mate will go with arp washers for sure.
Just got ordered a set of refurbed terry 328mm rears.
Think I will contact race brakes sydney to see if they can make up some new lines for the rear.
Fronts seem to be elusive as of right now I did see RBS sell a 325mm front kit same as on the ba gt.
Old 25-07-2021, 02:19 PM   #238
lumen8
lumen8's Avatar
Genuine 322 fronts getting more difficult to find, there are the aftermarket brackets on ebay
https://www.ebay.com.au/itm/263136426361
https://www.ebay.com.au/itm/283709614621
Then can use any BA caliper, swap the brackets with the new ones, it is the brackets that are different on the 322, rest of caliper is same as the regular BA.
Old 25-07-2021, 02:25 PM   #239
Ben
Ben's Avatar
Champion thank you!
Old 25-07-2021, 02:38 PM   #240
Ben
Ben's Avatar
Something like https://www.ebay.com.au/itm/254801652084
Those mounting brackets, correct rotors/pads and new lines would work?
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
