Old 03-06-2017, 10:35 PM   #1
au350hp
Default B Pillar covers
Just purchased a full set of the black B pillar covers (nos Adelaide parts) for my au2 sedan. Each one has some rust bubbles so Im keen to swap em over and clean up any rust underneath. I spoke to panelbeaters and went to 2 ford dealerships and nobody knew how to get em off. I reckon they might be glued on as I cant find any screws/bolts. Really hope someone can help.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2017, 10:43 PM   #2
rayban76
AU3 5.0L Fairmont Wagon
rayban76's Avatar
Default Re: B Pillar covers
They're stuck on with 2 rows of double sided tape
Ray
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar
Ford Performance Club of ACT
[SIGPIC][/SIGPIC]
rayban76 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2017, 10:45 PM   #3
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Remove outer door belts, remove one rivet, put window all the way down, pry baily channel out of door section adjacent to trim, stick a flat scraper underneath to get rid of the double sided tape and work your way from top to bottom.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2017, 06:41 PM   #4
Edxr6
Roostercam,
I have noticed there may be a slight difference from the series 2 and S3 B pillar covers. The S2 have a small plastic trim at the top of the trim where as the S3 don't, they just finish flush to the top of the door. My S3 XR8, finishes flush with no plastic trim at the top of the B pillars. Correct me anyone if my observation is correct or incorrect. Or possibly a difference between the XR6/XR8's.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2017, 11:53 PM   #5
PridenJoy
Correct. Most Series 3 trims are same as B series units.
Old 06-06-2017, 12:00 AM   #6
mcfly94
mcfly94's Avatar
Sam (if ive got that right), could you put up some pics of the differences identifying which is which. I know i have an issue with this, i think i need two rear b-pillar trims without the top plastic edges.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2017, 08:25 PM   #7
PridenJoy
If you've got what right?
They're different trims all together. B series ones have a different shape in how they fit.
Old 06-06-2017, 10:09 PM   #8
mcfly94
mcfly94's Avatar
Your name haha? Wasnt sure if it was Sam or not.
Do you know what style the series 2 ltd had? would be s3 for 2002 year?
Old 06-06-2017, 10:35 PM   #9
PridenJoy
Is it wrong of me to assume everyone around here knows my name? It has been mentioned enough times.
Keeping with Ford's track record, they would have put the same trims on all 2002 cars, so most likely B series style but hard to tell for sure. Only real way to tell is to have both styles side by side and compare to the one on the car. I no longer have any B series style ones so unable to help unfortunately.
PM Dean (hopefully you know who he is?) he went through the drama with the trims as he bought the wrong style and they didn't fit so he may know more about the differences.
Old 07-06-2017, 07:10 AM   #10
BLU-220
FG XR50 TURBO
BLU-220's Avatar
Yes B series B outer trim pillars are different to AU2-AU3 it's the little bit on top of the trim
as i tried this on my AU2 ghia and they didn't fit properly
but going by Adelaide parts they the same so maybe AU3 are the same as B series
http://www.ebay.com.au/itm/GENUINE-F...gAAOSw-jhUA~sx
cheers Dean
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2017, 11:07 PM   #11
au350hp
Originally Posted by Edxr6 View Post
Roostercam,
Reason for late reply is I havent changed them over yet. Just about ready to do the body work now the rear bar and skirts are back from paint shop. Adelaide Spares are great stockists of NOS and Darren knows his stuff. Best to email him your VIN to double check. All four covers I bought were labelled AU Series II by Ford and there is definitely differences.
Old 06-08-2017, 10:04 PM   #12
au350hp
Put them on, very easy. The best thing was there was zero rust on the doors themselves after removing the rust bubbled covers. I took before,during,after photos but cannot upload them atm. Thks for all the advice. Definitely worth doing, especially if your paint is good, it really makes a difference. The next cosmetic thing I would like to tackle is the window rubbers. They still function well but they are 17 years old! Any experience with the huge choice of rubber reco / blackening products that are online and at auto shops? There is one called ''Mothers back to black'' that is supposed to be a conditioner as well as the usual 'clean & shine' finish these products all do. I believe most of them are conditioners rather than actual repairing qualities that can be used on all external rubber trim. Any help appreciated.
Old 07-08-2017, 09:42 PM   #13
superroo
You can't stop the signal
superroo's Avatar
https://www.carcareproducts.com.au/p...rubber_cleaner
Old 08-08-2017, 04:51 PM   #14
au350hp
Originally Posted by superroo View Post
Thks, have you had good results?
