17-08-2017, 09:29 AM | #1 | ||
Au Falcon temperature guage not working an cluster. New cylinder head switch fitted. How do I fix this?
20-08-2017, 09:10 PM | #2 | ||
Next upgraded Mk1 Leopard
how did you go with this?
uk
23-08-2017, 02:37 AM | #3 | ||
Temperature guage is still not working. Can anyone suggest the next course of action
23-08-2017, 03:22 AM | #4 | ||
Check to see if you're getting temp data to the cluster:
http://www.fordmods.com/ford-technic...iagnostics-d34 If so, the analogue meter might be faulty, so you can swap it out. |
26-08-2017, 02:51 PM | #5 | ||
Thanks for the info. I will try this next
