Old 17-01-2018, 06:27 PM   #1
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Default Lost all gears 00 festiva.
Hi guys and girls,
My neighbour has a 00 festiva and has lost all gears. The shift moves moves around loosely and I can see the selector shaft moving but won't select any gears. Is this a simple job or does the box have to come out.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2018, 07:14 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Lost all gears 00 festiva.
Hi. Auto or manual? If its an auto there will only be one selector and the box will need to come out. If its a manual there could be two selector shafts (one that moves when you push the lever back or forward and one that moves when you move the stick sideways). If you have both motions on the box it would need to come out, if there is only movement when the stick is moved sideways it may have a broken cable. Cheers MD
HI
I'M MICHAEL
Old 20-01-2018, 12:45 AM   #3
73 4V XB
Frankenford pilot
73 4V XB's Avatar
5 speed manwell, can only see the one universal joint selector input and it moves in line with the shifter. Have managed to get reverse only. Can the box come out with out the motor? Doesn't look like there's enough room to the L/H chassis rail to slide the box away from the clutch.
I haven't pulled one of these out before so I'm going in blind.
Cheers Bretto
73 XB GT
Old 20-01-2018, 12:29 PM   #4
GTLEGEND
Below is the image of the linkage set up on a 1.5 WB Festiva, 1.3 is very similar. Check the linkage bushes and pins (numbers 2,6,7,9,16,17 and 19) it is common for them to wear and cause excessive movement in the linkages. It is also common for the base plate number 5 to fall apart with the internals numbered 10-15 breaking off. This may help on the shift side of things, otherwise its a transmission internal issue and trans needs to come out and pulled apart. Pulling the trans out is not so hard, but pulling apart is another thing and best sent to a trans place.
WB Festiva Manual Gear Linkage.pdf
Old 20-01-2018, 02:05 PM   #5
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Attachment 98207
Thanks mate but I'm unable to view the link
Cheers Bretto
73 XB GT
Old 20-01-2018, 02:16 PM   #6
GTLEGEND
Open with adobe acrobat.
Old 26-01-2018, 08:46 PM   #7
Pursya
Or better yet,
https://www.foxitsoftware.com/pdf-reader/
Pursya is offline   Reply With Quote Multi-Quote with this Post
