11-11-2011, 03:55 PM | #31 | ||
All LE BTR autos run in overdrive in power and economy. The reason the suggestions are made to use power mode after a trans service is to try and protect the lock up clutch in the converter,because time and again the converter is the first clutch to fail. They still go into lock up, but at a higher speed.When the converter goes in to lockup(usually 85-90 kms)it is in effect closing the converter which is direct drive through the box to the diff with no slip.At this point,the BTR shows up one of its flaws,which is the weak point in the converter clutch.It gets more load in economy because it comes in at a lower road speed than it would in power mode, causing heat.He probably said these things to you because experience told him the oil that came out of it was very contaminated and after servicing and driving it he would have thought `this box is pretty loose,its probbly going to fall over soon, and I`ve just serviced it,so hes probably goin to blame me. Better tell him to be gentle on it`Sorry for the drawn out post. Been with Ford for 20 years. Seen heaps of it.
XC GXL Warm 351c AOD 09 VE SV6 Sportwagon BA Fairmont Ghia |
11-11-2011, 05:37 PM | #32 | ||
I have never had one change into overdrive if in power mode???
11-11-2011, 05:47 PM | #33 | |||
FG XR6T trayback
11-11-2011, 09:15 PM | #34 | |||
Peter Car
11-11-2011, 09:32 PM | #35 | |||
Cobblers!
In an EAII to AUIII, Normal Mode (Called Power Mode in EAII to ED), you get all gears. My EF in Power Mode won't lock 4th until about 85, but you do get 4th.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
11-11-2011, 10:03 PM | #36 | ||
Sorry if I miss informed. My experience was a BA m1 and M2 XR6, a Mk1 V8 Ghia and a Territory. However I have a hot rod with a Clevo running a V8 au BTR and a NA TCM unit and the V8 TCM control unit does not seem to select 4th with the power mode on. However it does not drop out of fourth when power mode is selected while cruising. Oncve the vehicle is pulled up and started again 4th does not seem to be selected. Maybe the V8 early TCMs where like the BAs???? Interested if anyone has similar experience.
11-11-2011, 10:44 PM | #37 | ||
Peter Car
I've owned EB, ED, EL, NL, 2 BA's and an SX Territory and the only ones that locked out 4th were BA and SX.
All of them V8's except the Territory. |
11-11-2011, 10:48 PM | #38 | ||
Cobblers!
Deleted.
11-11-2011, 10:49 PM | #39 | ||
Ok I'll take it for another spin and see what happens.
22-11-2011, 12:11 AM | #40 | ||
BA locks out the Lock up(in effect a 5th gear if you like) in performance. You will still get 4th gear,but the converter is open.You can select 4th in tiptron it will display it on the cluster in manual mode for Falcon/Terri. Sorry I thought we were talking E series.E series and AU will get lock up in power,at a higher road speed. Amazing the garden path we walk up.LE BTRs are a little diferent in B series on, they have a different strategy with the tip shift.Anyhoo, be gentle on it if you`ve had a fluid change after neglect,the converter is the weak link.Once the oil is black, most of the time its pritty much over.
22-11-2011, 11:42 AM | #41 | ||
i think the mechanic is right.. not for fuel economy but for wear..
In power mode, my box doesnt change up into 4th until your off the throttle so lockup and load is not there when changing. In economy mode it changes up under load putting more stress on the box as your cruising through.. might change at a lower rpm but under load. |
22-11-2011, 11:53 AM | #42 | ||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
ok well you can take a mechanic's word over logic if you like, but it's certainly not a theory i subscribe to.
I very rarely ever put any of my transmissions, BA/BF/EL/AU/NC/ED/EB into power mode as it's not necessary. In my opinion you'd do more overall wear to the engine and driveline if you did. My EL has 280,000KM with the original transmission, 200,000KM of that being Nepean HWY stop start yuppy-area daily driving with the previous owner. My AU has 253,000KM on the original transmission also. Ask how many taxi drivers use power mode? lol It may increase the fun factor of driving, but i see absolutely no reason why it would improve the longevity of the components, quite the opposite in fact. |
22-11-2011, 12:12 PM | #43 | |||
Flairs - Truckers Delight
back in the EL days we used to do some trials with different cars. Power or Econ made little difference when it came to box longevity, the main issue with power mode is greater fuel use. What we did find though, is keeping the box in 3rd around town was beneficial. When maintaining roughly 60kmh, often your trans will be doing 3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4 all in the space of a kilometre or three. So we used to tell the drivers to keep the box in 3rd unless you're in a 70 or greater zone, which for a cab, is only about 5% of the time. Box longevity increased by about 15%.
22-11-2011, 01:12 PM | #44 | ||
Making superman jealous
Are you guys talking about the 4 speed mainly?
in manual select in the ZF you can select 4th, i was under the impression that if you just leave it in performance mode it only locks out overdrive (6th) as well as increasing the shift points and being funner to drive Im thinking this uses more fuel and are not sure really which way is better but to me reving more seems like it would put more strain on all components but than again it is worse if its too high a gear for the sitch.
If life deals you lemons dont complain just get on with it and make lemonade 2006 SY Territory Ghia AWD in ego with roof mount DVD, tints, 7 seats, iPod input 2005 Crewman Cross 8 with 350 cubic inches, AWD, black on black rims on black leather, tints and polished racks NEW TOY Bayliner 185, inboard 3L 4 cylinder pushing us along at 50MPH whenever i get a chance I love Aussie cars and are gonna really miss them soon....... |
22-11-2011, 01:49 PM | #45 | |||
2011 FG XR6 Sedan |
22-11-2011, 08:35 PM | #46 | |||
22-11-2011, 09:47 PM | #47 | ||
Yes, its been commonly said for years that the Falcon 4 speed should be driven in power mode, it keeps the torque converter out of lockup mode during normal driving which saves wear and tear on the torque converter clutch.
Funny hearing people question the wisdom of a transmission mechanic who probably spends 8 to 10 hours a day around transmissions. |
22-11-2011, 09:50 PM | #48 | |||
I remember getting a brand new company car EB Falcon 4 speed auto and the dealer told me to drive in 3rd to prolong transmission life, funny being told that on a brand new car! Weve come a long way. |
23-11-2011, 12:21 AM | #49 | |||
23-11-2011, 12:38 AM | #50 | ||
I have a AU BTR with V8 TCM from windsor 5Ltr fairlane, the lock up only seems to occur on down hills or very low load flat runs, it drops out almost instantly if you apply any throttle over cruise. To me this would indicate very low chance of damaging the clutch.
23-11-2011, 01:03 AM | #51 | ||
they call me Tibbo
to throw a curly one into the works... my BTR guy told me many moons ago...POWER mode was the go... it built up line pressure to the solenoids and saved the friction bands....
23-11-2011, 01:06 AM | #52 | |||
23-11-2011, 01:13 AM | #53 | |||
they call me Tibbo
I can remember the good old days where I'd drop a tang off the convertor or slip the gears and blacken the oil after two shifts of work.... Me = minus $2500 I am not saying he was right, but he built my g/boxes and whatever he said was good enough for me... If he told me to hold the damn thing in first I would of... THe engine could throw a rod @ 6k but an engine at 1/5th of the price of a reco 4 speeder I still would of done it .....
23-11-2011, 01:20 AM | #54 | ||
lol fair enough
no i haven't owned them for that time but the EL was a one owner before me and i did a lot of digging on both of the cars, previous owners said the transmission was never changed. Don't see why they'd lie about that. |
23-11-2011, 03:48 PM | #55 | ||
I know people are talking about causing less wear and tear on the gearbox but what about the engine. Being in performance mode in a BF/BA 4 speeder will cause the engine to rev higher, which will cause more wear and tear.
I like to think from BA onwards the automatics are smart enough to work out where they need to be most of the time (well my 4 speed in my BF does).
BF 06 FALCON XR6 |
11-11-2019, 05:21 PM | #56 | ||
From the BF II Owner's Manual:
PERFORMANCE AUTOMATIC MODE When the gear selector is moved to the left, the transmission is in Performance Automatic Mode. The transmission will automatically select the appropriate gear for spirited driving. PEF will be displayed on the instrument cluster for 5 seconds (on some models PEF will be constantly illuminated). At normal highway speeds, the selection of this mode will choose third gear. The transmission wii automatically shift to fourth gear only at speeds above 150kmh. I own a BFII Egas Ute with the BTR 4 speed. I find the selection of PEF suits hilly terrain and around town driving. I thought it locked out the fourth gear, but on reading the above (and not exceeding the speed limit) I understand why it never selected fourth gear on me. PEF stops the car from accelerating as much downhill and hunting on uphills. It's really hard to tell that the gearbox locks out fourth gear in PEF, as the shifts are so smooth that it is almost impossible to tell when it shifts unless you are constantly watching the tachometer. it almost feels like the shift points are moved in PEF. |
11-11-2019, 07:40 PM | #57 | ||
The EB V8 prefers power mode in city driving and click into economy when cruising above 80
11-11-2019, 08:03 PM | #58 | ||
BA and pretty much always drive in economy. If I'm hitting a large hill I usually just flick it into power then straight back to economy. This makes it shift down. It stays down until you reach the top. Use it to overtake too.
2014 Ford Ranger XLS 4x4 Dual Cab. 2003 Ford BA Fairmont Ghia sedan. 1994 Ford EF Fairmont Ghia sedan. 1994 Ford ED Falcon GLi wagon. Discovered my love for Ford 4L. |
11-11-2019, 08:15 PM | #59 | ||
Power mode in my EL XR8 was stupid, it just held onto the gears way too long.
It was much nicer to drive in econ mode.
11-11-2019, 08:34 PM | #60 | ||
Just to add but what would a factory of engineers know? I bet your mechanic could design a better car than them /s
