Old 11-08-2009, 02:37 PM   #1
Tony Martion
Default Wierd electrics
Got a funny problem with my NF Fairlane. When the engine is running all the lights from instruments to headlights flicker. They dont when the motor is stopped. Anyone had the same problem? Tony M
Tony Martion is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 06:56 PM   #2
malazn mafia
Boss 335
malazn mafia's Avatar
Bad alternator, or the voltage regulator on the alternator is gone and putting out A/C voltage instead.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 07:47 PM   #3
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Yep, either the alternator or volt regulator. In the AU Falcon's the volt reg is actually inside the alternator.
Use a multimeter to test the voltage of the alternator output at the battery terminals. The DC volts should be between 12 and 15v, most likely around 13.8V to 14.2V
NB Do NOT disconnect the alternator output leads, it will therefore open circuit and potentially blow the diodes which make up the volt reg pack.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 10:14 PM   #4
..or battery dying.
