Old 07-07-2008, 06:07 PM   #1
351capri
windsorman
351capri's Avatar
Default wsid nostalgia meet
anyone get a chance to go out on the weekend? results? photos? please.....
351capri
351capri is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2008, 10:18 PM   #2
Rural 351
1000+ passes
Rural 351's Avatar
Yeh I was there in my XY ute didnt go to good I had no luck hooking up ran 12.1 and 12.2 at 116.2mph with full exhalst and drag radials in qualifying, when it came to the bracket hooked up OK got in front did a big back off and ran a 11.84 at 101mph on a 11.95 dial in. So that was it for me, Track could have been better or the drag radials and my badly set up ute could have been better. still had fun chucking it through the gears with out worrying about double points. Rain ended up putting a stop to the meeting
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2008, 12:32 AM   #3
paddy351
Ford Nut
paddy351's Avatar
Good efort there nobono , how was you 60's and what rearend setup have you got for the ute ?
Clevo + toploader = :
paddy351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2008, 11:17 AM   #4
Rural 351
1000+ passes
Rural 351's Avatar
The rear end is all stock so is the front for that matter. the 12s had high 1.9 60 footers then it did a 1.68 60 I think it would have run its best number sorry I shut it off thats the bracket racer coming out in me. still the 116mph is its best Ive just given it a set of rings. Now I cant wait to have a good run to see what it will do.
Old 11-07-2008, 09:44 PM   #5
Rural 351
1000+ passes
Rural 351's Avatar
This must be the one when it hooked up
