26-12-2015, 05:38 PM | #1 | ||
When we start our Titanium and put it into drive or reverse the parking sensors make a solid beep then the light flashes for a few seconds and then stops.
Anyone got any ideas to fix this? If it's an individual sensor will disconnecting them one by one identify it? The adaptive cruise control still works. Does that use the front parking sensors? |
26-12-2015, 07:04 PM | #2 | ||
XY,XC,XEx2,XA,EF,AU,BA,XY
I have exactly the same issue with out MB XR5 at the moment. Hoping it's an easy fix, but haven't rushed to get it looked at. Will just hold out till the next service then get it looked at then.
I'll second the question of if anyone else has had this happen to their Mondeo?
A sad day when there's no Falcon variant in the garage! |
27-12-2015, 07:20 PM | #3 | ||
Tippy-tronic Free Zone
my MB XR5 2010 has also started doing this in the last month....hmmm
very interested in cause / solution BCM? |
29-12-2015, 12:29 PM | #4 | ||
I've worked out that it's the rear sensors that cause the issue.
If I put the car in drive and walk past the front sensors all is good but as soon as I get close to one of the rear sensors it's trips the system out. So I'm guessing it's either the rear sensor speaker or whatever controls the rear sensors. It seams to trigger on either side so I'm guessing that means it's not an individual sensor? |
