Old 16-01-2012, 02:58 PM   #1
Grug1
Default AU series I front 6 piston Brembo upgrade
I phoned the other day about upgrading front brakes on my AU series I Fairlane to a 6 piston Brembo 355mm rotor setup.
Wondering if you were able to find out if my current MC has enough fluid capacity to support this upgrade?
Thanks in advance
Grug1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2012, 04:06 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: AU series I front 6 piston Brembo upgrade
Your master cylinder is a stepped bore which the front brakes use a 28.57mm bore and although the AU onward models have a 31.75mm i think it will be fine as we have run 6 pot master cylinders on 1" bore master cylinders with a minimal pedal difference. If you can fit 04/2000 model AU11 onwards it would be a definet yes.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 16-01-2012, 04:11 PM   #3
Grug1
Thanks for the prompt reply.
