Old 19-07-2018, 02:20 PM   #1
watersnake
Default Exhausts
Hi guys I just want to ask what is the best sounding exhaust system for my 2008 GT
watersnake is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 02:49 PM   #2
radler
radler's Avatar
Default Re: Exhausts
Ok , here goes for a response
If it has the stock system on it, then in my view, that is the best ..
My former boss was a GT fanatic and modified his exhaust on both of his gt ‘s and for me the car was better before the mod
Also for me, when I often contemplate buying a gt I always skip past those that have been modified
I am certain many will disagree with my view and I understand there is a big thing for aftermarket, but for someone like me , a stock GT is worth more than a modified ....
Ross : n/a fgx xr6 - manual
radler is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 03:51 PM   #3
au350hp
It really depends on what you want. Radler makes an excellent point and many would agree. Then there is the other brigade (including myself) who understand that aftermarket headers, cats & well thought out exhaust systems can wake an engine up enormously and deliver that brillant sound only a V8 configuration can create. Mufflers are so good these days, you can have a fairly quiet sound for light driving but when you floor it, it really screams along with the noticeable torque/hp improvement. If you can get to a show or meet up with another owner with a exhaust, at least you can hear what they sound like. Ceramic coating adds $500 but lowers under bonnet temp substantially I have found. It is easy to spend over $3500 for a complete system fitted. Extractors will set you back around $700 and there is custom made systems or bolt on ready made like this. I don't recommend this myself, it is just an example of whats available ready made. Keep your old system if you do get a new one just in case.
https://www.ebay.com.au/itm/FORD-FAL...t+exhaust.TRS0
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 03:53 PM   #4
five 7
five 7's Avatar
Look at Rage systems from nz, believe they are available over there. Had one on my old 260 boss, well made and prob cheapish now.
five 7 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 05:18 PM   #5
watersnake
What I'm after if the V8 sound while its idling
Old 19-07-2018, 05:31 PM   #6
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Chop the mufflers out with a grinder and weld straight pipe in their place. It won't be droney or anything.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 05:32 PM   #7
ebv8
ebv8's Avatar
just an observation i have noticed headers take away the burble at idle but make it crack more on WOT
i don't have headers but my cats are empty as they fell out the exhaust and the exhaust is a high noise xforce with duel outlet
a mate has the same car but with headers and quad tips and his is much smoother and to my ear sounds worse
our cars are early BA GT's so not quite a 315kw
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 05:55 PM   #8
au350hp
This will give you more attention than you have ever had and put a huge smile on your face every time you drive it. https://www.ebay.com.au/itm/Pacemake...sid=m570.l1313
Whilst this will probably do what you have asked for and is a little cheaper.
https://www.ebay.com.au/itm/3-CAT-BA...sid=m570.l1313
Old 21-07-2018, 12:37 AM   #9
stock1991
Limited supply
stock1991's Avatar
Mitsubishi exhausts are wild, notwithstanding they were made in Tonsley
stock1991 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2018, 10:23 AM   #10
PooDog
PooDog's Avatar
its like asking whats the best car , you need to find out what sound you like then try and replicate it on your GT ...and you should get close to what YOU like
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2018, 11:30 AM   #11
slowsnake
Hello water snake,I see you are a fellow reptile, it should not matter, as you know we have no ears,but you may be a modified reptile with mini cochlear implants.
So whatever you do to your car you will not hear it, but you will feel the vibration, but good luck with it.
Cheers Slowsnake..( the land version )
slowsnake is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2018, 12:15 PM   #12
Hardtopxb
Once PHASED.
Di Filippo are excellent. Noticeable performance gains and great sounding at Idle/WOT High end quality. JMO
2006 BF XR8 Bionic.
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2018, 12:18 PM   #13
watersnake
Thanks everyone for all your valuable advice , I have put a resonator before a 3in Lukey . Sounds ok for a 70 yr old like me
