Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > KPM Motorsport
KPM Motorsport Leading BA-FG Performance Development Adelaide/Australia. Website Link
Old 08-08-2014, 11:16 AM   #1
KPM Motorsport
Home of Mustang in Aus.
KPM Motorsport's Avatar
Default Streetfighter 1500HP Fuel System
After several years of running our highly successful 1000hp in tank fuel system on many of Australia’s fastest Fords, Streetfighter is ready to release
Australia’s most advanced fuel system options for the BA-FG Falcon models range.
Streetfighter 1500 Hp In-tank Fuel Pump Module
Suits BA-FG Falcons
ALL models*
Advantages
  • 650 Litres per hour fuel delivery @ 400 kpa capable of over 1500 hp.
  • Supplies cool dense fuel for maximum power possible.
  • Highest supply direct fit fuel system in Australia.
  • Correctly supports engine boost levels up to 30psi.
  • NO FUEL SURGE / 1500 hp delivery on near empty fuel tank.
  • Whisper quiet operation.
  • 2 x Premium Walbro 460 fuel pumps.
  • Huge swirl pot volume supplies cool dense fuel.
  • Manufactured to suit Petrol, E85 (ethanol) and alcohol fuels.
  • Legal due to direct in tank replacement.
  • Eliminates the of external surge tanks.
  • No noise, no smells, no fumes.
  • Direct replacement / fuel lines and plugs fit like standard.
  • 100% Australian manufactured
Suits BA-FG Falcons
ALL models*
With the ever increasing power levels extracted from the XR6/F6 Turbo and the Coyote S/C 5.0 we are starting to see ever increasingly high fuel demand from these amazing Ford vehicles.
Streetfighter have met the need to deliver cool dense fuel reliably, easily and efficiently, for both petrol and even more demanding E85 fuels at power levels over up to and over 1500hp.
KPM Motorsport and Streetfighter Stockists Australia Wide are ready to release our direct replacement 1500Hp Twin In tank Pump Fuel Module.
We have utilised 2 whisper quiet premium Walboro 460 E85/Petrol compatible fuel pumps. The capacity of this module is able to deliver 650 litres per hour of cool fuel at 4 bar standard fuel pressure.
This means 1500hp!!
Either Streetfighter 1000 or 1500 hp Twin in tank Pump modules are a direct replacement to the Standard factory or after market in tank modules. Simply remove the standard unit and fit the Streetfighter Module. We also have a direct replacement loom kit that makes for easy connection to your standard wiring.
The Streetfighter modules are a once only replacement fuel pump solution that are capable of delivering either standard power levels or 1500 hp with whisper quite OEM in tank style standard operation.
Streetfighter in tank modules eliminate the need for surge tank set ups and have the proven advantages of supplying cool fuel reliably, with perfect retention, and the over abundance of refill volumes, all at standard fuel pressures. All carried out in tank.
This means no continual overheating of fuel or excessive fuel pressures which is an inherent design problem with external surge tank designs.
Correct lower fuel pressures allow for maximum boost capabilities delivery vs. fuel system capability.
The Streetfighter 1500 hp fuel system can support cool dense fuel for engine boost levels of up to 30 psi perfectly!
• Includes complete direct fit Twin In tank Pump Fuel Module
• Patch loom and relay for easy connection to standard wiring.
• Premium adjustable high flow fuel pressure regulator.
Enquire for details.*
Streetfighter Specialist Workshops exclusive 3 Year Driveline Warranty
New Zealand CTB Performance N.T. Atic Performance A.C.T. Roadway Mufflers New South Wales City Performance Centre, Rapid Automotive, Tunehouse, Streamline Auto
Queensland Dyno-Link, Insane Performance, Hunter Automotive
Elite Automotive, AHT Performance Victoria , Pitlane , BPR
Western Australia
Pro-Auto South Australia KPM Motorsport Tasmania Gowans Performance and Tuning
KPM Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2014, 05:37 PM   #2
Buttnekid
Default Re: Streetfighter 1500HP Fuel System
pricing please Dave?
Buttnekid is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2014, 01:28 PM   #3
KPM Motorsport
Streetfighter 1500 hp Twin In-tank Module kit
BFMk2- FG $1995
BA-BFMK1 $2195
Includes
  • Direct replacement In-tank Fuel Module inc. 2 x Walbro 460 Fuel Pumps
  • Premium Inline High Return Flow and Adjustable Fuel Pressure regulator
  • Direct fit Plug and Play Relay/Wiring kit
On the BA-BFMk1 Models, included is a direct replacement FG fuel tank with module fitted ready to go.
Western Australia
Old 11-08-2014, 03:40 PM   #4
T4ME
T4ME's Avatar
Is this system rated at theoretical HP or HP that you guys have seen with it?
03 BA Turbo
6466 external gate
Hi comp motor
Built BTR 4k TCE stall
FG inlet and exhaust manifolds
T4ME is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2014, 09:16 PM   #5
phantom_87
phantom_87's Avatar
I wish this came out awhile ago before I got my surge tank setup.
I could possibly go this setup later on down the track.
Just one thing. I'm running -8 feed and return could the fitting be changed from the standard fuel line fittings to an fittings.
Yes . Easily.
445RWKW of kennebell goodness
phantom_87 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2014, 09:00 AM   #6
KPM Motorsport
Yes . Easily.
Yes, Easily
Western Australia
Old 27-08-2014, 11:26 AM   #7
T4ME
T4ME's Avatar
Bump
03 BA Turbo
6466 external gate
Hi comp motor
Old 28-08-2014, 09:44 AM   #8
KPM Motorsport
Bump
This is rated by engineering methods to system flow. 650 lph of fuel delivery.
We have tested vehicles over 1000HP , however yet to find and field test on a vehicle with a true 1500 hp.
Would be more than happy to utilise a said vehicle for demo purposes.
Western Australia
Old 28-11-2014, 03:18 AM   #9
Vader869
Vader869
Vader869's Avatar
Any updates on this Dave? Are these available to buy yet?
* Bluestreak 1L forged long motor
*Bluestreak level 2 transmission
*Circle D 2B turbo converter
*Lundy Race Fabrication/Bluestreak 1200hp turbo kit Precision 7675 Gen 2
686rwkw, 1300+nm
Carbon fibre tail shaft (Final Drive Engineering)
Kpm stage 2 intercooler [/B]
Kpm 1500hp in tank fuel system
Vader869 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2014, 11:35 AM   #10
KPM Motorsport
We have a production run nearly ready with several test units being finalised on the field. Not long.
Western Australia
Old 24-01-2015, 04:16 PM   #11
Jihad jack
Did you guys end up testing with a 750 rwkw car?
Jihad jack is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2016, 04:34 PM   #12
KPM Motorsport
As you can imagine , there are not many 700-750 rwkw cars to test on.
It has been run by a workshop in W.A on a vehicle with a claimed 700 rwkw .
I suspected that it would be at its full supply at that level.
The workshop owner thereafter told me that it did make 730 rwkw.
I would suggest that this would be its absolute maximum.
Western Australia
Old 09-03-2016, 06:51 PM   #13
Charliewool
Snoozing away in Summer Bay
Charliewool's Avatar
How close is 730kw to 1500hp?
Current vehicles.. Yamaha Rhino UTV, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2016, 07:00 PM   #14
pottery beige
GT.. not.. gt..
pottery beige's Avatar
Dave, its a little un settling when customers are maxing out your products well below their claimed hp rating
R n D should be in house / not customer related / throwing a product out there
pottery beige is online now   Reply With Quote Multi-Quote with this Post
Old 09-03-2016, 07:19 PM   #15
XR8menace
730kw is under a 1000hp but Dave is in this instance talking 700-750rwkw which through a ZF trans is still well short of 1500hp.
XR8menace is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2016, 08:57 PM   #16
Ratmick
The Tickinator Lives!
Ratmick's Avatar
...yes 'well short' by a significant margin
Maybe they were really small horses?
New measurement RWPP
Ratmick is online now   Reply With Quote Multi-Quote with this Post
Old 10-03-2016, 03:11 AM   #17
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
My post here wouldn't help them one bit, but it's as honest as the day is long. Read my thread (link below) and you'll see I think more of KPM's product then they do... The issue is it isn't without its problems- something that should be easily fixed and addressed.
Go on Dave, delete another one that doesn't help you sell your stuff...
Btw, tell me a car you've built that has made anywhere near 750rwkw, let alone that you've tested your system on?
Let alone deleting my post as "useless" but still want to use my numbers to push your product...
Whatever helps you sleep at night, Dave, I have no agenda here at all.
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2016 Ford Falcon XR6 Sprint #203/500
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2016, 10:52 AM   #18
KPM Motorsport
R and D is definitely done in house, with the support of correct customer vehicles with full knowledge that they are first to test..
Our calulations to claim 700- 750 rwkw on E85 were made clear to Dan before he purchased, with the understanding that he would be pushing to this limit for us.
This was never an issue to Dan or customer with this understanding.
Western Australia
Old 10-03-2016, 11:14 AM   #19
KPM Motorsport
As per most fuel systems quoted world wide, we have quoted on the power out put of petrol usage.;
As advertised the Streetfighter 1500HP Fuel system support approx.
Petrol 1500 Hp at the flywheel
E85 1200 hp at the flywheel
Western Australia
Old 10-03-2016, 09:52 PM   #20
jimt3te50
jimt3te50's Avatar
R and D is definitely done in house, with the support of correct customer vehicles with full knowledge that they are fisrt to test..
And we did push it to the limit. It made a max first run of 733rwkw and we settled on 725rwkw. And it ran faultlessly.
After a while, we began to experience issues that were diagnosed as a lack of fuel. At that time, during the diagnosis, it was struggling to make 700rwkw and at that, it wasn't consistent or reliable. When presented the issue, You personally said that's what you expect, it's within your "claims" and maybe back off the fuel pressure to extract a little more from it.
But, me being me, asked the question- it made 725rwkw before with ample fuel supply at the recommended (and tuned to suit) 58psi base fuel pressure. Now it suddenly doesn't have enough fuel? What's changed? Something had to change in the ability to deliver fuel as it had done it comfortably before.
So, I rang KPM myself to order a service kit thinking nothing more than maybe I'd picked up a bad dose of fuel and the socks are gummed or its hurt a pump. But oddly, I was the only one who thought this throughout the process...
Rest is history. And its irrefutable- my photos and measurements etc are all in my thread.
That's why I say that I believe in the capabilities of the product more than KPM do- I think I'm well entitled to that as the above is certainly indicative of that.
I just think it's bloody rich of you to say what more could be have done? All of this, the R&D, the diagnosis, the repairs, replacement pumps, replacement regulator, rewiring, removal/refitting, time, travel and the all expensive initial tuning and retuning. You wanna claim numbers off the back of me doing all this, then you can openly share the responsibility of some shortcomings in the setup in the first place.
Offering to fly over for damage control after the horse has bolted isn't really going out of your way Dave. Not by a long shot.
Anyway, your business, your decision. But at least give me the credit I deserve, not write me off or make your insinuations in your passive aggressive, never at fault, style of posting.
2013 Audi SQ5
Old 11-03-2016, 09:24 AM   #21
KPM Motorsport
Thank you Jim.
I have tried to answer your every question, and have also tried to give you the help needed the best I can.
I apologize if this has not been to your satisfaction and also apologies if it seems I have not given any credit to yourself or car.
Sincerely
David
Western Australia
Old 28-04-2016, 05:34 PM   #22
2muchkw
Originally Posted by jimt3te50 View Post
After a while, we began to experience issues that were diagnosed as a lack of fuel. It made 725rwkw before with ample fuel supply at the recommended (and tuned to suit) 58psi base fuel pressure. Now it suddenly doesn't have enough fuel? What's changed? Something had to change in the ability to deliver fuel as it had done it comfortably before.
So has the KPM 1500HP Fuel module been reengineered yet to address the troublesome filtration design causing the poor fuel delivery issues experienced above?
Is a KPM 1500hp Mk II fuel module for sale now?
Cant see any updates to this product on KPM's website
2muchkw is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2016, 06:00 PM   #23
KPM Motorsport
There has never been a problem with this system or the filtration design.
The Streetfighter 1500hp module has always and is still working perfectly at the power levels quoted.
Western Australia
Old 29-04-2016, 10:03 PM   #24
Sparrowfart
Really ... what's this mate?
He said "There has never been a problem with this system or the filtration design."
That is a photo of a filter design doing its job perfectly. You have a problem with crap in your fuel tank. Show me a photo of that debris getting through the pump and fuel filters before you flame someone. It's a real shame some of you guys post before you think.
Common sense is all to uncommon in parts of this forum.
Sparrowfart is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2016, 07:34 PM   #25
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Earth to KPM...............
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2016, 09:39 AM   #26
KPM Motorsport
What can you say to someone that is dead set intent on making nonsense out of a situation. All the pictures and slander will never account for the fact that Jim was offered help and advice and chose not to take it, Rather he chooses to continually slander and try to discredit a product that has had fantastic results when used as instructed.
Very easy to dis-assemble yourself with no understanding and then throw rocks. I also spoke to several involved with this gentleman's project and was assured there was no real problem other than running the pumps beyond capacity.
Other than a now resolved relay and wiring issue this system has been flawless to all that have followed advice and instructions.
Western Australia
Old 02-05-2016, 09:41 AM   #27
KPM Motorsport
Sensible comment
Western Australia
Old 26-05-2016, 08:16 PM   #28
blwn_290
5.4 330
blwn_290's Avatar
Is this module still available? I need a fuel system to reliably handle 700rwhp on e85. Could i get away with the streetfighter 1000?
KENNE BELL BLOWN BOSS 290
BF Xr8 in Toxic Green
blwn_290 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2016, 09:11 AM   #29
KPM Motorsport
Yes, this system is available.
You will not support this level with the 1000Hp.
Let me know your exact vehicle details so I can best advise on expected power levels from this module.
Give us a call
08 82999 998
Western Australia
Old 27-05-2016, 07:36 PM   #30
blwn_290
5.4 330
blwn_290's Avatar
5.4 modular with a pd blower, in a b series sedan.
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
