Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > KPM Motorsport
KPM Motorsport Leading BA-FG Performance Development Adelaide/Australia. Website Link
Old 03-05-2013, 11:24 PM   #1
KPM Motorsport
Home of Mustang in Aus.
KPM Motorsport's Avatar
Default Streetfighter Oil Breathers
Over the last 2 years and after removing countless Coyote plenum covers we have noticed oil build up in the manifold and plenum areas.
This oil contaminates the incoming air bringing oil into the combustion chamber.
The results of this are oil usage and contaminated air/fuel mixtures.
If intercooled this oil builds up around the heat exchanger fins and tanks causing less cooling efficiency for the incoming air. On a supercharged engine this is especially important.
This need led KPM to engineer and manufacture oil and air separators.
The separators are easily fitted in line with the engine breathing system.
The oil is caught in the separator filters rather than contaminating intercooler and air fuel mixture with unwanted oil.
When the engine is not running the oil caught in the filters drains back down into the sump rather than the manifold.
This keeps the intake and intercooler clean and stops the oil burning through the engine.
Less oil usage and the plenum and intercooler is always clean.
Not only do they serve a purpose but they enhance the look of your engine bay with a racey OEM style finish.
We have manufactured our Streetfighter breathers out of billet aluminium and utilise high quality washable filters to ensure life time reliability. All Australian made.
The Streetfighter breathers are sold as a pair and will be ready for release next week.
Streetfighter Oil Breathers kit Price $395
Available direct from KPM Motorsport
08 82999 998
david@kpmmotorsport.com.au
Streetfighter Specialist Workshops exclusive 3 Year Driveline Warranty
New Zealand CTB Performance N.T. Atic Performance A.C.T. Roadway Mufflers New South Wales City Performance Centre, Rapid Automotive, Tunehouse, Streamline Auto
Queensland Dyno-Link, Insane Performance, Hunter Automotive
Elite Automotive, AHT Performance Victoria , Pitlane , BPR
Western Australia
Pro-Auto South Australia KPM Motorsport Tasmania Gowans Performance and Tuning
KPM Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2013, 09:46 PM   #2
Kometes
Default Re: Streetfighter Oil Breathers
Any offerings for the 5.4?
PX XLS 3.2L Manual
ARB Deluxe Bar, Safari Snorkel, Ironman 9500lb winch, Icom 440 UHF + 6dB Aerial
Kometes is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2013, 10:21 AM   #3
KPM Motorsport
No sorry. Herrod may be able to help out.
Western Australia
Old 10-06-2015, 03:34 AM   #4
bionic2006xr6t
bionic2006xr6t's Avatar
I have question on this product. Are they a complete clip in fitting and I don't need to modify any existing hardware whatsoever?
Cheers Ryan
bionic2006xr6t is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2015, 11:50 AM   #5
KPM Motorsport
Hi Ryan
Yes direct OEM style clip on fitting.
Only need to easily re-route / modify the breather tube itself.
Full instructions provided.
Western Australia
Old 25-07-2015, 04:36 PM   #6
Pilko FNQ
Pilko FNQ's Avatar
Fitted my breathers this morning and it's a fairly straight forward job. I think there may be a slight difference between the FG GT and the FGX XR8 however. Had to trim 10 mm from the supplied joining pipe on the LH bank where it connects to the short section entering the air intake spigot for better alignment. Cheers Chris.
Pilko FNQ is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2015, 04:49 AM   #7
CQB-241
Car tragic
CQB-241's Avatar
Has there been a change FG to FGX with breather lines or snorkel dimensions?
Problem
Solution
Result
CQB-241 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 10:55 AM   #8
KPM Motorsport
Sorry no images??
Western Australia
Old 07-03-2016, 02:01 PM   #9
KPM Motorsport
Originally Posted by CoyoteGS View Post
as per other thread please answer all said questions reguarding kpm products.
Originally Posted by jimt3te50
For the purpose of the thread Id just love to know the scientific explanation as to how the oil drains back? And how the separator actually seals against the PCV fitting to prevent oil going down between it and the neck of the separator like mine have?
CAT600
And the many customers with the old components been upgraded to the new ones?
As I mentioned Nick had a very close call
Also have you revised the systems capability down from your 700-750rwkw claim?
What of the supplied Edelbrock regulator that was having issues on Jims?... As we have since found out it's flow rating is 180gph and not quite as high as 2 x 460's at the base fuel pressure rating
and many more
Ok, I will answer all questions in between our daily work routine.
I will start with as many as I can now.
"For the purpose of the thread Id just love to know the scientific explanation as to how the oil drains back? And how the separator actually seals against the PCV fitting to prevent oil going down between it and the neck of the separator like mine have?"
Answer:
A per the pic below the breathers have always been designed to catch and either return oil from the filter element back down into the PCV or act as a catch can for heavier breathing cars without the return of oil down the PCV.
1) To act as a oil return system the valve is simply removed from the original PCV and oil caught in the filter returns naturally down the filter element into the PCV . To avoid built up and flooding this filter needs to be serviced approx every 7500 or according to engine breathing.
Extended use on heavily breathing engines may flood the canister if not serviced.
2) To act as a catch can the PCV is left with the valve in it and the catch can acts as a reservoir for excess oil. Due to the separator holding approx 200ml of oil, engines with excessive breathing need to service this style more frequently.
The nitrle o ring acts as a perfect seal on the PCV when installed correctly . We have had several instances of the o ring not coping with overfilled canisters , that are generally contaminated with blow by fuel in the oil. This creates excessive pressure build up against the PCV valve on the exit side of the canister.
We do not recommend fuel breathing engines to use a separator style canister and rather a dedicated catch can.
Due to more and more instances of vehicles breathing heavier amounts of oil and flooding the canister, due to either lack of servicing or unsuitable intervals between servicing, we have in prototype a heavy usage return filter that will be for the purpose of the thread in all canisters once finalized and tested
pictured.
We have now decided to change filter separator style due to petrol contaminating the foam style UNI filter. We are currently looking at suitable alternatives that both allow the engine to breath and also separate oil and fuel from air correctly.
Prototype Filter Element R/H bank
Western Australia
Old 07-03-2016, 02:18 PM   #10
CQB-241
Car tragic
CQB-241's Avatar
The breather filters were said not to require servicing as they returned oil. Based on this post, it appears they do require servicing. How frequently?
This is of interest to me as I have a stock Miami ('15 FGX) and while it's only got 4265km (filters on in 1st 2500km) the aim is to keep the intake plenum clean. The choice of KPM over Herrod was the lack of servicing said to be required with the KPM product. What is needed now in your estimation?
Old 07-03-2016, 02:34 PM   #11
KPM Motorsport
Hi
Servicing has always been required, that is why we have a cleanable/replaceable filter installed.
I do understand however the annoyance of more regular servicing should it need to be done more often as is often becoming the case.
Keep an eye out for our new returnable design filter once finalized.
I will be happy to supply at no cost existing customers that require increased oil return.
Western Australia
Old 07-03-2016, 03:01 PM   #12
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
Nice work Dave, the revised design looks to address a few issues I have seen with mine.
Fantastic that you're upgrading existing Customers with the new updated design at no cost. Great to see. It's this continual improvement and evolution of products that us consumers love to see. Making it retrospective too, is just fantastic.
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2016 Ford Falcon XR6 Sprint #203/500
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 03:15 PM   #13
KPM Motorsport
Thank you Jim
Forums are a great tool for discussing.
However as a business I always ask to be contacted as most concerns are addressed accurately, promptly and efficiently when I have someone contact us.
Quite often we even re-develop if the need arises.
Thanks again.
Western Australia
Old 07-03-2016, 06:41 PM   #14
Xr8freak
STKBTL
Xr8freak's Avatar
when my breathers were fitted almost 12 months ago, was told that as long as service with main service will be ok. Which is 15,000km intervals. Are you now recommending 7500km? Also what should I use to clean the filter? FYI prev ones had disintegrated when I opened the passenger side at 10,000km with vis able oil buildup. Drivers side was intact, brittle but no visible oil.
Xr8freak is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 06:50 PM   #15
KPM Motorsport
We carry out engine oil servicing every 7,500,
I would suggest then servicing your filter at this interval if you service your car every 15k.
Use a de-greaser or kerosene type solvent. Rinse with water and ensure you blow them out and dry thoroughly.
If they require replacement, they are reasonably inexpensive.
Western Australia
Old 07-03-2016, 06:55 PM   #16
Xr8freak
STKBTL
Xr8freak's Avatar
Too easy, thank you for prompt reply and info. Ps I'm still a happy customer!
Old 07-03-2016, 07:10 PM   #17
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
I'd have to say I've had no probs with my breathers on my little putta-bomb, I haven't even really looked at them much at all, I would use them again if I have a chance
2011 FPV GS315 s/c nitro- #158, -355rwkw's tune, BMC airfilter, KPM exhaust, Breather filters, Herrod tail-shaft, 6/4 Brembo's, Koni shocks, king springs, 19'' Staggered wheels, Tints- pb 12.4 @ 117mph.; - New toy '15 Dyna Wide-Glide
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 07:18 PM   #18
mitelsx2000
mitelsx2000's Avatar
Me to.
No issues to date
Current ride: 2011 FPV GTE colour Edge 6-speed Auto, Build #019
BMC Twin air filter, street fighter oil breathers, Window tints & paint protection. CTB Tuned 364 rwKW
Previous ride: XR8 Black Lux pack 2004
Daily ride to work Fiesta trend 2017
mitelsx2000 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 08:05 PM   #19
LASGT8
450rwk
LASGT8's Avatar
I checked out my breathers on the weekend and couldn't see any everything looked good.
But i must admit the possibilty that my 1500hp fuel system electirics could possibly melt and cause possible engine failure does concern me some what.
R-spec rear rims 275x35x19RE050A, Street fighter twin air filter, Street fighter full exhaust/ceramic extractors,1500hp twin fuel pump, 1500cc injectors,street fighter big intercooler, street fighter snout 58mm pulley, 65mm throttle body, street fighter oil breathers,6 speed manual, Carbon fibre tail shaft 450rwk
LASGT8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2016, 01:58 AM   #20
kempy311
BEN
kempy311's Avatar
How do you stop it from rubbing on the airbox as mine does?
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2016, 03:55 AM   #21
CQB-241
Car tragic
CQB-241's Avatar
I gently moulded mine with a heat gun and gentle pressure from a 1" socket on extension that was also warmed a little. OEM finish and no abrasion.
Old 10-03-2016, 12:01 PM   #22
adrianb
There wasn't any mention of servicing the breathers with the documentation that came with them or on the website for the product (apart from saying there's washable filters).
Could you please post a howto or something similar on what steps KPM recommends to keep the breathers in optimal working order? Something with recommended interval, method of servicing, equipment needed etc.
Probably my own naivete, but I had no idea I should be pulling these apart and cleaning an element inside them when I change my oil. If it wasn't for this discussion I would probably have never considered it so please keep up the engagement with customers on forums!
BLUFGX | 2015 Kinetic FGX XR8 KPM Oil Breathers, Koya SF06 20x9/20x10s, Michel Pilot Sport 4S 245/275, G6E Chrome Front Grille/Foglights/Window Trim, Disabled Bi-Modal - More to come!
adrianb is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2016, 12:28 PM   #23
KPM Motorsport
I will ceratinly do so.
Stay tuned.
Western Australia
Old 12-05-2016, 04:04 PM   #24
KPM Motorsport
New Improved drain mack Oil Separators MkII Now available
Suits all 5.0 Coyote engines both N/A and Supercharged. Falcon and Mustang
Western Australia
Old 12-05-2016, 04:38 PM   #25
geobar
Is there an upgrade option for those who have the MKI kit?
George
geobar is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2016, 01:34 AM   #26
CQB-241
Car tragic
CQB-241's Avatar
George
Beat me to the question.
How many km before a filter change on these? Spirited but non-track use.
Old 18-05-2016, 10:22 AM   #27
KPM Motorsport
I would check and clean the filters every vehicle service to start to get an idea on how much your engine breathes.
From there you will start to get an idea of how often servicing is required.
We normally see service to service as no problem.
Western Australia
Old 22-05-2016, 09:49 PM   #28
MitchP91
So of we order a set now are we guaranteed to get the mk2 style or is there still stock of the mk 1
2011 FPV GS Ute in Silhouette
MitchP91 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2016, 09:54 AM   #29
KPM Motorsport
Yes guaranteed.
All new MKII breathers are now being supplied.
Western Australia
Old 11-07-2016, 01:54 PM   #30
PaulXR50
Can anyone tell me how many ks travelled before you would expect to see some oil in the oil breathers or the filter.
I disconnected / dismantled the driver's side yesterday and found nothing in there & the filter had no evidence of oil either.
Breathers were installed by mechanic & done correctly as there is no leaking etc.
(i read somewhere the driver's side seems to get more than the passenger side - may have even been in this thread).
Thanks.
PaulXR50 is online now   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
