lovemyfocus
hi, i am very happy with my new focus apart from the lack of interior lighting. has anyone put lights in the back for the back seat passengers and/or footwell lights in the front? please let me know where you tap into the wiring if anyone has done it. cheers
Just an update on this:
http://www.european-parts.net/catalo...7816620229396d This is the front lighting in the ST, not sure if its in the XR5 as well. It should be a fairly direct replacement for the current unit. |
I wanna XR5
Yeah I feel the same way about the interior lights, the back is dark as.
Zoom Zoom
Yeah XR5's have those. They also fit Focus Mk I. I'm looking into a price from Ford locally to see if it's cheaper here. Direct plug in.
2012 Mazda3 MPS
2006 Focus LX Hatch
Does that light do any more for the dark rear section of the cabin than the stock one?
lovemyfocus
yes lights it up really well
That does look the same as the XR5 one....
But we have the same issues.... the back you cant see jack all. Ive got the black leather and at night I need to grab a torch to find anything in the back.. even sitting on the seats. |
#8 | |||
2006 Focus LX Hatch
I think the best way to resolve the rear cabin darkness is to find the centre pillar lights that go in those slots. |
#9 | |||
Focus on my Focus
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
Ford Australia has priced these at $350, so euro parts should be the better option if anyone wants to purchase this
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
Im totally confused.... What slots are we talking about?
Is this a square type shape that is above the seatbelt pully system thingy in the pillar? Cause if it is thats the side airbags? Mine clearly says airbag there. Someone wanna take a piccy so we can see where we are talking about? I've been looking for spots to fit a light.... i was half thinking about maybe agling something up from under the front seats pointing backwards if that makes sense. |
#12 | ||
Zoom Zoom
In Europe, or in the ST170/Ghia here I think it was, there was a similar light right in the centre of the roof that lit up the back seats. Not sure if there are any lights, I'm not touching the roof lining to find out... anyone seen a wreck?
Otherwise it'd be dead easy to rig up a simple positive/negative wire tapped into the ones that run into the front light... the only issue is getting into the roof lining.
2012 Mazda3 MPS
#13 | |||
2006 Focus LX Hatch
#14 | ||
I just had a look.... only the XR5's have the side curtain airbags... so you guys should have no dramas putting a light in that spot above the seatbelt pretensioner thingy.
Would be fiddly getting the wires and stuff down the pillar though. Would be better putting one up in the headlining like previously mentioned. |
#15 | |||
2006 Focus LX Hatch
#16 | ||
I wanna XR5
I pulled one of the square shaped plugs out and its a cover for screws that hold the b pillar plastic on. In the ghia still only plastic plate. The side air bags are in the backrest of the seat on the side bolster. Which are a saftey pack option for the CL and standard on all the other models (ford focus brochure)
#17 | |||
Wiring is never a problem so long as you can fit coathanger wire from 1 hole to another, and that there isn't any moving parts in there. I'm going to check out the Ford dealer on Saturday and have a close look in the Ghia. If anyone had detailed pics of the Ghia interior, that would greatly be appriciated |
#18 | |||
#19 | ||
I put in one of these in the interior light, LED Festoon Light Globe 12VDC 41mm
Cheap solution light's up the cabin a lot better, but also looking to do something with the rear and boot as well.. FYI: The cover on the piller above the seat belt just hides a bolt that holds the plastic panel on.
Murph 2005 Focus Zetec |
#20 | ||
Ive been looking for one of these in red for agggggges
I got a 36mm one (which the Brits use) it didnt fit... too small. Anyone know where i can get me a red one of these? The Super Flux if possible. |
#21 | |||
Hello Koni's!
The same one in the rear would be great, the entire cabin would be lit up very well.
2006 LX FOCUS SEDAN Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit Lower airbox removed, K&N Panel filter Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles JVC KW-XR816 Headunit + more to come... |
#22 | ||
I have a blue one in mine. I can't see **** but it looks good
![]() Check out Dick Smith and Jaycar. |
#23 | ||
I wanna XR5
going to put led lights in the rear pillars over the weekend to fix the bad light in the back
![]() narva item push light to turn on/off, about $20 each, 75mm dia will flush mount them |
#24 | ||
Similar to how I fixed the boot light problem. Household halogen downlight from the boot lid interior lol
#25 | |||
Would like to see some photos of this once your done, will you be able to change the battery once there mounted? It's a real down fall of the focus and a large oversight in this day and age, considering it's dark for a large proportion of most days in England you would think they would have got it right.
SZ Territory Titanium |
#26 | ||
I wanna XR5
these will be hard wired so they will come on with the doors and be swithed on by the switch at the front
#27 | ||
Whistler
I bought a Focus XR5 and was told by the sales guy that there were submarine lights. This is supposed to be a light that shines down from the ceiling on to the gear stick/centre console. It wasn't working when I picked it up and was told to advise the service guys on the first service and they will fix it. When I asked service to fix it they said it was not part of the Australian model and does not exist. It's stated on the Australian website and I want to know if anyone else has come across this problem. I know its only a light but its disappointing that the sales or service guys don't know their cars.
#28 | ||
Whistler
The brochures/website state that submarine lighting is only on the XR5 model. Are they special lights or just a fancy name they've given them for standard lights?
#29 | ||
Tricolore Tard
![]() Join Date: Dec 2004
I was told the same thing when i looked at the car
If its on the website, id be pushing for them to fix it. Ford service are usually pretty crap IMO anyway, and dont know much if its not a falcon.
#30 | ||
Tricolore Tard
Nah its meant to be the bit that shines down onto the gearstick that is all.
