Wanted Car bits and other general items If you want it and it's not in the For Sale section, post it here |
Pursuit 250
I'm, chasing a TS50/Pursuit 250 5.6 piston. New or used.Must be in good working order.
HODGIE Pursuit 250 |
Ill have a look around but standard bore have a left and a right piston (TAU3 6108 B & TAU3 6108 A respectively). Which side where you after? You could also get genuine oversize as well at either 0.002 or 0.20" according to the catalogue although they were full 8 x piston kits not individual. The standard bore were individual.
AU XR8 220KW OWNER
![]() Join Date: Apr 2009
PROUD OWNER OF A NAROOMA BLUE AU3 XR8 220KW |
Pursuit 250
Thanks for the reply GT LEDGAND it’s the drivers side. Will look for the stamp on piston when I get home. But definitely the drivers side.
CHEERS
Pursuit 250
Had look at the piston & it has a R stamped on it.I'm not sure of the part # but it's definitely got R stamped on it.What catalogue did you get the part numbers from. ACL or Ford ?
Thread Tools | |
Display Modes | |
