Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Mainline Dynolog Dynamometers
Mainline Dynolog Dynamometers Mainline Dynolog Dynamometers. Website Link
Old 28-11-2010, 10:54 PM   #1
Fireblade
Wizard Member
Fireblade's Avatar
Default Can the mainline be fudged
Hi,
I was at a Dyno day here in Adelaide today that my Holden mates were at, the shop in question ran a few cars and then ran off the list of my mates, the first mates car was rolled up on the dyno and we were left standing for 10-15 mins while the tuner/operator/owner of the dyno played with some dyno settings prior to running my mates cars. He didn't do this prior to running any other cars and he changed the settings back once all of my mates cars were run (they were all run back to back). Now all of my mates cars were down on power compared to previous mainline dyno runs, what we witnessed to the best of our knowledge through the secondary dyno screen was the operator/owner playing with ramp rates and loads. My question is can the mainline be fudged, and can playing with ramp rates and roller loads provide inaccurate dyno readings?
Thanks for your advice.
Frosty and FPR - Bathurst winners 2013
Fireblade is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2010, 11:05 PM   #2
ratter
ratter's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful.
the ramp rate can be adjusted but the rate is shown on the dyno printout.
Normally a ramp rate is selected that should suit the acceleration rate of the car being tested, a turbo six would have a faster ramp rate than say a NA 6 or sometimes even an NA 8, the ramp rate may have a small affect on power output.
Do not believe roller load can be adjusted, the load is set by the ramp rate, it allows the roller to turn i.e 13 km per sec, again it is printed on the dyno sheet.
The dyno correction formula, but not the settings can be adjusted to a different formula, this may have another small affect on power but again is printed on the sheet.
Tying the car really loose may allow wheel spin and loose power or tying to tight may rob power from tyre deflection
If the cars were left idling for a while, they may have suffered from heatsoak which will drop power compared to possibly left with dyno fans on them on previous runs ????
Pit Lane Performance
ratter is online now   Reply With Quote Multi-Quote with this Post
Old 28-11-2010, 11:30 PM   #3
Fireblade
Wizard Member
Fireblade's Avatar
No print outs were provided for any competitor so we can't get the complete ins and outs of what was changed, and we only got a quick glimpse of it. No car was left idling. Some of the figures are way low from what I can gather, would be handy to know what these would likely run from your experience ratter.
For example,
VY Clubsport running 1 3/4 extractors, 3" cats and twin 2.5" exhaust, VCM OTR, valve springs and tune 218rwkw.
VY Calais running 1 7/8 extractors, 3" cats, 2.5" twin exhaust, VCM OTR, 224/224 cam, 3000 stallie, built trans, 3.46 diff gears 225rwkw
Thanks for the info Ratter.
Old 28-11-2010, 11:35 PM   #4
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well. Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship.
Did you guys pay to attend this dyno day? if so I think its a bit harsh not getting a dyno sheet.
I cant remember seeing a dyno day where the owner of the car never got a sheet..
2017 GT Mustang ET:11.10
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2010, 11:37 PM   #5
Fireblade
Wizard Member
Fireblade's Avatar
cost was $50 for members and $70 for non-members, was going to give mine a run but decided against it and for $70 definitely not worth it. Also why we think it could possibly be fudged, but with no evidence
Old 29-11-2010, 11:12 AM   #6
ratter
ratter's Avatar
There can be several things which will determine final rwkw, i.e wheel size, tyre type, engine condition etc etc, but the first car I would think is close to where it should be possibly up to 225 rwkw, the 2nd one depnds on how loose te convertor is, who's cam it is etc but that may be 230-250 rwkw.
Please do not make my guess's as gospel to what they should be, they are just guess's, I see more Fords than Holdens
Old 29-11-2010, 02:04 PM   #7
Fireblade
Wizard Member
Fireblade's Avatar
Thanks Ratter, just trying to get a better idea of the positioning of these, both of these have good low km engines, but both run 20" wheels, converter is a tight new one. Now that you have given me some advice from what you have seen, it is now a dropped matter for me. Thanks.
Old 29-11-2010, 02:33 PM   #8
ratter
ratter's Avatar
No worries mate, hope I helped
The 20's do affect power at the dyno but it would only be a difference if the other runs were done with smaller wheels and now later runs were done with the bigger wheels.
We have seen some hi stalls in XR6 Turbo's rob around 20 rwkw while others with the same or similar stall rob none, convertor age is not the problem, it is how it is built
Old 29-11-2010, 02:44 PM   #9
Fireblade
Wizard Member
Fireblade's Avatar
Main concern was money payed and then getting fudged on runs, those two cars were the lowest runs of my mates, 7 cars in total of my mates were run, all down on power from what we thought and knew.
thanks again ratter, and I will pass this info on to them.
Old 29-11-2010, 09:25 PM   #10
KW XRT
KW XRT's Avatar
The VY sound very close to a mate of mine who spent 5k getting right exhaust and lower diff to get the magic 300 RWHP 301 I believe, I put a 600 tune box through my turbo and even on the economy tune {could not run 10 because of plug gap too large** car went 306 = unhappy mate.Had I run the ten and used 98 ron instead of woolies fuel he would have done himself in with a butter knife,lol
Ambrose driving in Nascar and joining RPM Murphy somewhere in the V8'S.
XR6 Turbo.Championship winner.
KW XRT is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2010, 09:53 PM   #11
Fireblade
Wizard Member
Fireblade's Avatar
Those were just the lowest ones, there was a WK Stato running everything the VY Calais had but larger cam 238rwkw, VX SS with 1 7/8 headers, full twin 3" stainless exhaust, ported ls2 manifold, 90mm TB, 248/??? cam, ported ls2 heads in a manual went 302rwkw, VX Senator with all the same bolt ons as the VY calais, largish boost cam, magnacharger, running 352rwkw. And last and least was a VX SC6, 10psi pulley CAI and exhaust running 139rwkw.
I have had mine on a dyno dynamics running 352rwkw and I think this has been fudged a little, I had a drive of the VX SS yesterday and it doesn't feel as fast as mine, but I reckon it would be with me in a race. I'm not interested in racing my mates as it can cause all sorts of silly grief but all of the numbers seem out for all of our cars, point is you can't rely on a dyno figure, MPH on 1/4 is the best way.
By the way these are all my best mates cars, I am the only one with a Ford lol
Old 13-12-2010, 11:27 PM   #12
awddynotodd
Mainline Dynolog
awddynotodd's Avatar
A Mainline DynoLog Dyno has the inbuilt option of a workshop based version of the software, as well as a "Horsepower Challenge" mode which simplifies vehicle and owner details entry.
The Horsepower Challenge option has no bearing on the result when compared to the normal workshop version, all it does is offer the user some tools to view the cars tested in a highest to lowest HP for each catergory, and be able to print out these results for clubs etc.
We install some base catergories in this setup for a variety of cars such as 4cyl, 4 cyl turbo, 8cyl, 8cyl FI etc etc, but the operator still has full control of the Ramp rate to be used as commonsense should be used when testing vastly different cars that happen to be a "V8" for example.
The operator may just of changed from a slower to a faster ramp rate when going from a manual car to a high stall auto car, as this will reduce the time taken to perform the test and not have the owner of the car cringing when their high stall car sounds like it is being flogged to death if using a slower ramp rate.
When a high stall car is dyno tested, it very early on during the test will be at, at least whatever the stall speed is, so even though the dyno test may go from 80kph to 180kph, the engine may only go from 4000 to 6000RPM in this period. Compare that to a manual, where it may be only doing say 1800rpm at 80kph and 6000rpm at 200kph, so in this case you will hear a nice pull from a low to high RPM, where as the high stall will sound harsher as more overall engine revs will take place in the same amount of time.
Changing from a slower to a faster ramp rate on say a 200kw plus car won't have much if any effect within reason.
Just because the operator change a ramp rate doesn't mean he's fudged anything, you may be used to another brand that takes any intelligence away from the operator and doesn't allow him to think for himself and mandates he use a particular Ramp rate for a car just because it is a V8.
Hope this helps.
awddynotodd is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2010, 11:40 PM   #13
Fireblade
Wizard Member
Fireblade's Avatar
Thanks Todd, they all received their dyno sheets last week, some of the figures are different but from my own judgement (no bias) I can't see anything outstanding to make me think he has gone out of his way to fudge them. After seeing some footage of the day I tend to think he has let them idle for long enough to introduce some heat into the equation. As with some forms of sport, tempers flare and some people look for ways to say they been screwed over.
Thanks again Todd, by the way, one of my mates involved is looking into buying his own Mainline dyno in the near future.
Old 23-05-2012, 09:23 PM   #14
memnoch
memnoch's Avatar
Default Re: Can the mainline be fudged
i put my BF phoon on a mainline dyno about a month ago, $50, 3 runs and a print out, i was happy of my reading, she is dead stock and got 232.5 RWKW
BF F6 Typhoon
1 of 17 DeJa Vu build # 0499
running 15psi @321.7 RWKW
memnoch is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
