15-03-2008, 06:48 PM | #1 | ||
Hi all...
This post is directed towards the fellow aussies in the group. The engine in my 1986 bubble back ford lazer seized in hot weather last week after a heater hose burst. I now have an oportunity to buy a engine from a wrecked 1985 bubble back ford lazer. My question is, are the engines interchangable between 1985 and 1986 model ford lazers? Any help you can give will be much apreciated. Regards Nina in Geelong Last edited by NinaGeelong; 15-03-2008 at 06:53 PM. Reason: spelling mistake and wrong year |
15-03-2008, 07:21 PM | #2 | |||
let it burn
Then theres EFI or carbie. Im assuming neither are TX3 or 4WD as some of these had B6T (1.6 turbo) and I think even BPT (1.8 turbo, although I think these were only in later models) engines. If the two you have are the same, then yes its an easy swap as Im fairly certain all bubble backs were unleaded, 85 was the change over year. |
04-04-2008, 12:03 PM | #3 | ||
What a performer!
The BPT came out in the the turbo TX3s from 1990 onwards but do fit the hatch with mods.
Be easiest just to go B6>B6 if it's just a runabout.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
05-04-2008, 06:04 PM | #4 | |||
let it burn
Can you just shove the efi gear on a carb motor and run it, or is there crank differences/cam etc? Last edited by fmc351; 05-04-2008 at 06:13 PM. |
01-05-2008, 06:21 AM | #5 | ||
fmc351 wrote:
"There are B6 (1.6), B3 (1.3), and B5 (1.5 which arent common) engines." Where do I find the info on whether it's a B3 or B6? On the compliance plate all it has under 'engine' is a 'B' |
Thread Tools | |
Display Modes | |
